Results 1 to 7 of 7
    help me understand rear wheel axle / hub " spacing " please
    i was going to get an extra set of wheels for a cyclo cross bike that has discs.
    this is so i can have a set of wheels with road bike tires on it.
    for weekly training rides .
    so i can get used to the bike and keep up on road bike group rides.
    i am unsure about 700 c and 29'er size wheels that accept disc brakes.
    and how to know spacing
    is spacing an issue for front wheel too ?
    the extra wheel set is for this bike
    2013 Jamis Nova Sport
    Quote Originally Posted by lunna View Post
    Front wheel spacing is almost certainly 100mm if it's a reasonably new bike.
    Rear spacing is probably either 130mm or 135mm (road or standard mtb spacing.)
    Bicycle Frame/Hub Spacing
    Cross bikes and hybrids come in both flavors, so you'll have to measure.
    i would like to be able to just look and know.
    but that is not so easy then.
    i need a wheel the fits the needed spacing
    and also accepts a disc.
    this is so i can have the wheels ready to throw on
    with just a quick release process.
    Sure looks to be 130mm from the specs:
    "Formula alloy disc road hubs"
    ... so you need road wheels, with a hub that supports discs. Unless there's a spacer in there or something. Best bet is still to look at it and measure.
    Ditto on measuring. From Jamis' site, they specifically say that the Supernovas have 135mm spacing in the rear. Makes me think that the other ones do not.
    Go to this site for a "how to measure" and a picture Bicycle Frame/Hub Spacing
    urmb ]-
    “Nothing compares to the simple pleasure of riding a \mountain or fat/ bike.” ~ John F. Kennedy
    Not sure if you can do it with Aluminum and succeed, but I stretched my steel cross bike to 135mm rear spacing so I have a wider selection of rear disc hubs. If you're interested in set of Bontrager Select Disc wheels (with 130mm rear), shoot me a PM.
