Results 1 to 5 of 5
    help with DT240s hubs. took it for service and now it doesn't seem right.
    hello all, I have a set of wheels built by dave. dt240s hubs, they're about 4 years old and i've noticed an increase in sound from the rear hub and less free roll. I figured they needed regreasing after so many miles and years. took it to a bike shop and the tech said he took out the the rear hub and noticed it was dry so he greased it and said the bearings were fine in the rear and he stated he replaced the bearing in the front hub. So I got the rear wheel back on and the clicking sound is hardly there now(the dt240s hum) and the free roll is way less now. Did the tech damage my hub?
    A wheelist
    Reputation: Mike T.'s Avatar
    Re-greasing lots of rear hubs, especially the DT 240, quietens them down lots. So that's not a problem. Remove the wheel from the bike and turn the axle with the fingers. That will tell you whether the bike shop person did something wrong.
    You should re-lube that 240 yourself as it's a 2-minute (tops) no-tool job. I could do it trailside while you had a pee if I had a blob of grease.
    Mike The Bike's home wheelbuilding info - dedicated to providing Newby wheelbuilder information and motivation.
    Formerly of Kent
    Reputation: Le Duke's Avatar
    What Mike T. said. The DT is not a loud hub if properly greased (with a small dab of DT's pink grease, slick honey, whatever).
    If it's dry, it will buzz fairly loudly.
    Regarding the rolling resistance, I'm guessing that's just a new bearing that needs to break in for a bit.
    Commit or eat sh!t
    Reputation: Cable0guy's Avatar
    Make sure he used DT grease or something equivalent. If he used heavy grease it will feel like there is tons of drag.
    Save Jesus
    Reputation: beanbag's Avatar
    Sounds like too much or too thick grease
  1. XTR Hubs Recommended Service Interval
    By TwoHeadsBrewing in forum Wheels and Tires
    Last Post: 12-22-2012, 09:57 PM
  2. dt240s hubs. 3 years old does it need service?
    By bisdakr in forum Wheels and Tires
    Last Post: 08-28-2012, 10:25 AM
  3. Easton Haven hubs service
    By jazzanova in forum All Mountain
    Last Post: 07-09-2012, 10:19 AM
  4. DT240s hubs - how to change skewer/axle adaptors?
    By awai04 in forum Wheels and Tires
    Last Post: 03-28-2012, 03:01 PM
  5. Hadley hubs and getting service and or parts. A solution
    By Boyonadyke in forum Wheels and Tires
    Last Post: 07-27-2011, 06:49 PM
