Results 1 to 5 of 5
    Help Converting 15mm to 24mm Maverick DUC32
    I want to convert a 15mm hub, to a 24mm axle so that I can use the wheel with my DUC 32 fork.
    Does anyone make a conversion kit? Not much luck searching the internets.
    Thanks in advance.
    Church of the Wheel
    Reputation: mtb143's Avatar
    The only hub that I know that can do both of those is a Hope Pro 2. Unless you have that particular hub or another similar one, you're probably out of luck.
    "I thought you'd never love me without my Mojo." -Austin Powers
    The Bubble Wrap Hysteria
    Reputation: mtnbiker4life's Avatar
    First off, what hub do you have? If you have a Chris King LD hub it's convertable between 15, 20, and 24mm
    ISO 15mm | Chris King Precision Components
    Not sure what it is... I pulled the trigger on a 650b front wheel I found on eBay without first thinking it through. My mistake.
    I'm tying to do a 650b up front, 26 in back on my Maverick Durance. I guess it's not as simple as I thought it was going to be.
    Velocity P-35 27.5" Front Wheel, 15mm x 100mm, Pacenti NeoMoto 2.3'' Tire. 650B
    Help Converting 15mm to 24mm Maverick DUC32-screen-shot-2013-03-16-7.58.30-pm.jpgHelp Converting 15mm to 24mm Maverick DUC32-screen-shot-2013-03-16-7.58.37-pm.jpg
    Reputation: Bike Whisperer's Avatar
    If you're lucky, the Maverick hub and the Velocity hub have similar hub flange measurements and you can simply rebuild the wheel.
  1. Replies: 7
    Last Post: 02-21-2013, 05:41 AM
  2. Maverick DUC32 Forks V Fox 150
    By mazspeed in forum Maverick
    Last Post: 06-14-2012, 12:08 PM
  3. Maverick DUC32
    By modifier in forum Shocks and Suspension
    Last Post: 09-19-2011, 06:58 AM
  4. Replies: 0
    Last Post: 03-31-2011, 05:56 PM
