Results 1 to 7 of 7
    Reputation: targnik's Avatar
    Jan 2014
    Hans Dampf Doppelganger?
    Looking for a similar tire to Schwalbe's Hans Dampf...
    Similar girth/height/weight.
    One proviso, slightly wider lug spacing i.e. better self cleaning.
    T.I.A
    PS - pics would help ^^
    'We'll all make it to the top... Some of us, might not make it to the bottom'
    "Mountain biking: the under-rated and drug-free antidepressant"
    Mar 2012
    No pic, but I have run WTB Vigilantes in 2.3. Over stated size and under 800 grams in the light and fast casing. Pretty similar tread to the Hans.
    Quote Originally Posted by targnik View Post
    T.I.A
    The HD tread pattern is quite unique and I haven't seen any copies, but, the Bontrager XR3/XR4 might work.
    Jul 2017
    I'm running the Michelin Wild AM as a front tire.
    Rolls similar enough to a HD for me. Was also given feedback by another local rider that it is similar to the HD.
    Unable to provide any statistics though, sorry.
    Jan 2014
    Thanks for the posts...
    I've run the XR4 in the past & sold it after half a dozen rides o_0
    Currently run Wild AM out back on both my whips, particularly for Autumn/Winter trails.
    WTB Vigilante 2.3 could be an option ;-)
    Hear they blow up bigger than stated ^^
    Jan 2014
    For WTB Vigilante users...
    Does the tire blow up larger than the stated etrto? 57-xxxx
    Rear tire(s) are 58-60 etrto & my ocd won't allow a narrower tire up front.
    If it actually blows up to 60mm across, I can live with that ^^
    Forecaster or Mavic Quest should clear a little better. Trade-off is that knobs aren't quite as high. Might loose a little dry grip.
    You could also run a cut Mary. Trim down the center knobs for a little rolling speed.
  1. Hans Dampf 2.35 vs Nobby Nic 2.4
    By Unbrokenchain in forum Wheels and Tires
    Last Post: 05-30-2014, 11:16 AM
  2. Schwalbe Hans Dampf
    By gticlay in forum Wheels and Tires
    Last Post: 04-24-2012, 12:39 PM
  3. Hans Dampf Q's
    By itchyjesus in forum Wheels and Tires
    Last Post: 06-30-2011, 11:16 PM
  4. Schwalbe Hans Dampf
    By Severum in forum Wheels and Tires
    Last Post: 03-31-2011, 07:02 AM
  5. New Hans Dampf tire.
    By ProjectDan35 in forum Wheels and Tires
    Last Post: 03-08-2011, 07:19 PM
Members who have read this thread: 108
