Results 1 to 7 of 7
    Oct 2011
    Gravity Light, Revolutions, Outlaws, etc
    ~200lbs in gear, riding evenly divided between trail, FR, and bike park. Main concern is durability and longevity, probably don't need complete boat anchor. 135mm rear and I'd like to look into converting to solid axle, so if it comes with a kit thats a plus.
    First thought is Gravity Light, I was offered a good deal at $200. 2300g
    Azonic Outlaws- 2244g, ~$350
    Transition Revolution 32 - 2510g - ~350
    Bicycle Wheel Warehouse has a variety too, I'm thinking something with mavic 721s...
    Any opinions on the above or other suggestions?
    Oct 2011
    OK a little more research in the 200-350 20mm FR department.
    BWW MTX/XT $205 2450g 33mm Welded Rim
    Bluesky XT/325 $250 2400g 33mm Pinned Rim
    Kore Torsion EXSB $250 2150g 28mm Pinned Rim
    Gravity Light $250 2300g 28mm Pinned Rim
    BWW 721/Pure/XT $300 2300g 32mm Welded Rim
    Transition Rev 32 $320 2500g 32mm Pinned Rim
    Transition Rev 28 $320 2277g 28mm Pinned Rim
    Azonic Outlaws $350 2250g 32mm Welded Rim
    Outlaws have best specs used to be able to score em for $250...
    Any opinions?
    meow meow
    Reputation: b-kul's Avatar
    what kind of front axle are you looking for? that should narrow it down a bit.
    Oct 2011
    All of these are 20mm, the ones mentioned with XT have no-name hubs (quando).
    meow meow
    if conversion options are important to you go for the revs or outlaws.
    Oct 2011
    Can an xt be easily converted to solid axle? I know the 12-10 stepdown option on the outlaws/tbc would be stiffer w/all else equal...
    meow meow
    its not that hard, search for highdellls thread on how to clean a xt hub, follow that but replace the stock axle with a longer solid one and reassemble. it should be as stiff as a rev or outlaw.
  1. azonic outlaws vs transition revolutions
    By NEWBIErider in forum Wheels and Tires
    Last Post: 12-13-2009, 08:15 PM
  2. Are azonic outlaws really light enough for xc riding?
    By Destin in forum Wheels and Tires
    Last Post: 01-13-2009, 12:36 PM
  3. FSA Gravity/Gravity Light?
    By suicidebomber in forum Downhill - Freeride
    Last Post: 07-15-2008, 09:08 AM
  4. Gravity/Gravity Light stuff...
    By Prettym1k3 in forum Downhill - Freeride
    Last Post: 03-31-2008, 10:28 PM
  5. Transition Revolutions or Azonic outlaws?
    By Pistol2Ne in forum Downhill - Freeride
    Last Post: 06-07-2007, 03:42 PM
