Results 1 to 6 of 6
    May 2012
    New question here. Geax TNT WTB Frquency Blow-Off
    I was trying to seat my Geax TNT Saguaro onto my WTB i19 rim today. It had a stubborn dip in the bead and I couldn't work it out with my hands. I figured I would try to put 60 psi with a tube into it to try and get it to seat (I know, probably not the best technique). Well, at 60, it blew off the rim.
    I inspected the tube and it had a long gash typical of a blowout. I've been running it for a few weeks, so I don't think it's defective. The tire bead looks completely normal and when I tried to mount again to asses the damage, it still required a plastic tire lever to get the final bit onto the rim.
    One ting should add - I was using a 26 inch tube (gotta use them up, right ). I've been using them for a while now with 29" wheels with no problems. Not sure if this could have contributed to the blowoff.
    My question is, do you think there might be a problem with the rim? And, given how the tire is still tight (its Geax TNT), would you consider it safe to run it tubeless? I know that if this occurs with a tubeless install it is not a good idea, but given that this might have come from the tube, might this be different (wishful thinking, perhaps)?
    Thanks in advance!
    I have been running a Geax Gato tubeless on an i23 rim and a Geax Saguaro tubeless on a WTB LaserDisc rim for some time. Both were a bit tight to get on the rims but have been trouble free. And I really like these tires -- high volume, good tread patterns, durable. Both running with Stan's liquid. Hope this might help you a bit in deciding how to proceed.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by vincavinz View Post
    Thanks in advance!
    Sounds typical of getting the tube caught under the tire bead rather than a tire/rim problem.
    mtbtires.com
    May 2012
    Shiggy, do you think it is safe to use tubeless now?
    Dec 1998
    No idea. I can not inspect the tire.
    mtbtires.com
    I personally won't run a tire that has had the bead blown off on an install. I run only tubeless.
    I only have great things to say about Geax TNT setting up tubeless. I will admit they are a tight fit. I'd rather have a tight fit than a loose one.
    Lead by my Lefty............... right down the trail, no brakes.
  1. Blow out
    By tdg63 in forum Passion
    Last Post: 03-16-2012, 03:36 PM
  2. Blow it Up
    By ronski in forum Trail Building and Advocacy
    Last Post: 02-16-2012, 12:22 AM
  3. Fox F29 RLC blow off
    By thecanoe in forum Shocks and Suspension
    Last Post: 07-28-2011, 08:29 AM
  4. Fox F29 blow off
    By thecanoe in forum 29er Bikes
    Last Post: 07-26-2011, 07:19 PM
  5. Joe Blow Pro Gauge Fix?
    By anchskier in forum Tooltime
    Last Post: 04-21-2011, 05:51 AM
