Results 1 to 59 of 59
Thread: Geax goma
    Dec 2009
    Geax goma
    Anyone give these a tires try yet? Who has them in stock?
    Reputation: stremf's Avatar
    Dec 2012
    I just got one to use as a front tire. Went with the 29 x 2.4 foldable version, as it seemed to be the lighest (at a svelt 800g). Just weighed it last night and it was about 900g on the dot. Didn't think margin of error would be at 100g, but oh well. Looks beefier than the Ardent 2.4 it replaces, but haven't ridden on it, so can't comment on the ride.
    change is good
    Sep 2004
    Geax goma
    Scored a pair of 27.5 TNTs for 40 each from bike tires direct. Waiting for them to arrive.
    27.5- 2.2 or 2.25 not sure. Very good traction and direction on loose 1''- 2'' ball bearing rocks and rolls good on soft hard pack. They corner like crazy when condition are good. But they scare the fck out of me(They try to kill me) When wet. Not enough contact patch just the tips of the tread touching the rocks and to skippy on diagonal-roots. had to run then to low on psi for those condition.
    Short-Change-Hero
    Reputation: gregnash's Avatar
    I picked up a 2.25x29 version a few weeks ago. Hadn't had a chance to get it out on the trail until yesterday, riding since then has just been commuting back and forth to work.
    Setup is GEAX Gato 2.3" up front with the Goma 2.25" in the back. Front is set at 15PSI currently (tubed, needs to be raised to 20ish though) and 22PSI rear. I live in No NV so have all of the world renowned Lake Tahoe trails in my backyard. Rode Emigrant Trail (XC/Trail) yesterday for a total of 24miles. This was the first time I had the Goma on dirt and was very impressed with it. Never broke it loose unless I meant to, traction climbing over rock gardens and loose over hard was stellar. When I got it, I had it weighed at my LBS and came in at 820g for the foldable (which is about right from the website). Was hoping that it would come in closer to my Gato (2.3" AM) at 700g but oh well the weight difference from my 2.25Purg Control 2bliss and GEAX Saguaro 2.25" was not noticeable.
    Climbing this thing just grabbed whatever was there, never once did I feel like I was skipping, spinning or missing out. The tire just clawed up whatever I was on and I had some very loose rockgardens to climb on this trail as we have had little wet weather this year so the trails are very dusty. In the loose over hard sections again, the outer knobs just seemed to punch through the dust to the bottom and really grab a hold of whatever was there. Only time I skipped/spun was when I got too much weight off the back tire during a climb but even that was just a momentary spin and then she just climbed.
    Descending this this was a rockstar!!! I was used to the strange void section when leaning the bike over from the Purg as there was that transition between the center and side knobs (which is why I really didnt like the purg). This does have a void, dont get me wrong, but the transition is much more predictable and there is no sudden let loose or grab. When going around loose corners at speed I could feel the tire slowly, predictably starting to let loose and could compensate by adjusting my balance or scrubbing a bit of speed. Even those few times where I would ping off a rock, the tire did not suddenly let loose, I was actually startled by the sound of the rock being shot off as I would slide down it because I never felt any traction loss.
    Rolling resistance on everything was pretty standard. The tire did not feel exceptionally fast but at the same time it did not seem like I was seriously lugging a huge weight behind me. Rolling was smooth and seamless, again feeling the general transition between the center knobs and the outer knobs as the traction would slowly and predictably start to go away.
    Setup on my Stan's Flow (OG) rims was actually quite easy. I am running tubed but have had a b*tch of a time getting my other GEAX tires on and off the rims as the folding bead are quite tight and take irons and lots of cussing to get them on/off. These slipped on fairly easily, still requiring irons but no where near the effort the others had taken. Since these are not the TNT I have not setup tubeless yet as the TNT version WILL NOT fit on BST beadseat rims. Not that big of a deal for me as I am not a weight weeny and do not measure grams for savings.
    One thing that I have found out about GEAX tires is you should ALWAYS run them at low pressures. For some reason they really come alive at lower pressures and I have a feeling that it has to do with the rounded casing profile. Unlike most tire casings, the GEAX tires really use a more round profile so if you run at higher pressures you really only get the center knobs. Other way to remedy this is to run them on wide rims. My Flows measure at 28mm wide so at low 20s, high teens my tires spread out pretty well to involve the entire tread pattern.
    For around here I think my setup of the Gato front and Goma rear is going to be killer no matter where I go. This setup just seems, for me, to hook up on anything I throw at it, drifts predictably when I want it too and otherwise is just a great setup. This will be going on my new trailbike that I am in the process of building (Hammerhead Bikes Thumper) so I am stoked to see how it does on a Full Squish bike vs. my current steel HT (On-One Inbred 29r).
    Some picture stoke.
    Untitled by renofizz, on Flickr
    Reputation: twowheelsdown2002's Avatar
    Excellent tires!
    I agree with a lot that "gregnash" said above.
    I was using the Ardent 29x2.4, and just switched to the standard Goma 29x2.4 tires on Stans Flow EX rims on my R.I.P.-9. I love this tire! It actually rolls better than the Ardent!
    I ride rocky, chunky, technical trails in AZ. The Goma's have a very thick sidewall just like the Ardent 2.4, (which is much thicker than the Ardent 2.25.) They roll fast without resorting to ridiculous ramps, which means in the rear, you get excellent climbing, AND braking traction. Much better climbing traction than the Ardent. Cornering is also much better than the Ardent, as the narrow side knobs on the Ardent would fold over on hardpack. The Goma is very predictable. It also wears quite well.
    I used the standard version because the TNT's are too tight for Flow rims. It went on nice and tight, and sealed excellently. Holds air really well with almost no loss, and no seepage.
    As gregnash stated, GO LOW! They have thick sidewalls and high volume. About one or two mm more volume than the Ardent. I weigh 190 pounds and am using 18psi front, 21psi rear, on very rocky trails.
    Lets see, thick sidewalls, good sealing, excellent braking, cornering, and climbing traction, and very good wear and durability. What else could you want? Cheaper maybe, but $50 is competitive. These will be my go to tire for as long as they make them! Here it is compared to the Ardent. Geax goma-sam_0870_zps2a14ff4a.jpg
    change is good
    Sep 2004
    Geax goma
    So far I like these tires. Roll well for knobbies. The 2.4 on the front has great grip with 16lbs. I punctured the 2.25 rear which surprised me. I blame a combination of my weight and poor style, although now I know why the heavy casing enduro tires exist. The 2.25 doesn't fare as well on wet rocks as I hoped which is typical around here. It does perform well on wet roots. In the winter I'll probably go with a Magic Mary/2.25 Hans Dampf combo.
    Dec 2012
    Quote Originally Posted by stremf View Post
    I've ridden all summer on these and cannot say enough good things about them. Excellent traction, predictable handling and robust construction. I actually just purchased another one locally, as it was a ridiculous deal. The weight was at 790g, so little under advertised. Surprising there is 110g difference between the two exact same tires.
    Short-Change-Hero
    Yeah I have found that GEAX tires usually very pretty largely between tires. Mine came in at 820g so that is not too bad.
    I recently dumped this on my new HH Thumper FS trail rig with the Schwalbe Pacestar Rocket Ron on the rear. So far has been a great tire and running tubed it is doing great at about 25psi. I rode Mr. Toad's Wild Ride in Lake Tahoe a few weeks ago with this setup and it did really well. Actually, a couple days after getting back my buddy and I went for a local ride and I noticed a wobble in my front rim, figured it was just carnage from the Toad's ride. Ended up being that I was running such low pressure in the front that I actually had some rock (granite gravel) get inbetween the rim bead and the sidewall and push the tire out but never caused an issue.
    Thinking of grabbing the 2.4 version for up front with the 2.25 in the back, but since I do a lot of climbing I really appreciate the low weight of the RoRo in the rear. Taking the bike to Steamboat Springs, CO in a few weeks so will give a bit of a report after that.
    Uncle
    Reputation: Entrenador's Avatar
    Bump. Just scored a pair of 29x2.4 "sticky" Gomas (non-TNT version) in a raffle, not long after putting a Gato 2.3 on the rear of my Yelli. They weigh 900g each but look grippy as hael. I suppose they'll be awesome on the front, but I'm intrigued by the thought of adding even more volume and tire compliance to the back end. Anyone measure theirs yet to see if they're a true 2.4"? Gregnash, how did they fair for you in CO?
    Dec 2012
    Mounted on Crest @ ~19-20psi, mine is:
    2.31 @ casing
    2.44 @ knobs
    Yes, they are a true 2.4, as mine were actually a couple mm bigger than a 2.4 Ardent.
    Reputation: inonjoey's Avatar
    Been running a Sticky TNT Goma 2.4 up front for the past 2 months in NorCal. It's been a very dry winter, so mostly dry trails with a lot of rocks. And.... the Goma rocks. Magnificent front tire. Here's a pic of me putting a lot of trust into the Goma (courtesy of Hoolie).
    Uncle
    Excellent news. I've got Arch EX rims, so the tire profile should be pretty good. I guess I just need to wear out my current treads a bit before making the switch. Thanks for the replies everyone.
    I've got the Arch EX rims as well.
    "So you think it's the hat?... A lot of people hate this hat. It angers a lot of people, just the sight of it." - Uncle Buck
    Sep 2012
    Geax goma
    I just stuck a pair of these in 650b with tnt and sticky on the front and rear tires of my Bronson. I waited until I was half way through the High roller 2's that came with the bike and will use those for when it dries out or for emergency as I wasn't a fan as I felt like I was on the verge of the front washing out in a lot of corners, yes I could lean the bike more but I still didn't like that angle where the tire felt like it was going g washout due to the gap btw the knobs on the edge of the tire.
    Moving on, Installation was a breeze. Mounted right up and took air. Beads set at 40psi give or take no and leaks around the rim etc. Was shocked to be honest as I've had a lot of mounting issues in the past with other tires.
    Went for the first ride today here in the PNW and it was a mud pit in some spots on the trails. Lots of roots and wet/mossy rocks. Tire rolled right on over, only had a few slips/slides on angled roots/rocks which I've yet to find a tire which can grip in these conditions. Traction was great and it easily took the beating I gave it on some rocky/roots downhills. Slides were very predictable and the tire handled well.
    Right now I have them set at 25psi but will try 20psi on the next ride to see how they react to my Clydesdale sizing and whether they roll or burp air, fingers crossed.
    So far I'm impressed, time will tell on durability and the longevity of the tire.
    Steve
    I've been running a set of 2.25 folding bead (non-tnt) Gomas on my Norco Range since early April, they replaced the stock High Roller 2. I needed a faster tire for my local trails and was willing to trade off some of the excellent cornering of the HR2 along with its ability to punch into loose blown out terrain and hold traction. Mine are setup tubeless on M9020 XTR Trail wheels, running about 28-30psi for a 150 lbs rider (going below 25psi results in rims getting bashed unless I'm running a 2.5" DH tire).
    So far they work the way I expected. They roll decently well, I'd say about the same as my Conti Mountain King II and definitely better than the Trail Kings. Overall cornering is about the same as the Trail King (better on hardpack, falls behind a bit on sand or deep loam) but requires more commitment in laying the bike over due to the tire's rounder profile and larger gap between the centre and cornering knobs. The Goma also doesn't clear mud as well as the Contis, and doesn't stick to wet things as well as the Trail King's Black Chilli compound, though I'd say it's better than the MKII in that respect.
    Overall I'd say I've found a new favourite trail tire for everyday use. They have good volume on them to provide a good ride and keep my rims safe, and they perform well for the trails that I ride most often. I'll still use my other wheelset with DH tires for bike park days, knowing what my bike can do I'm pretty sure that anything short of a DH tire is going to have a short life.
    Reputation: kevocastro's Avatar
    Just got my hands into a pair of 2.25 TNT 29 Gomas, coming on from narrow Schwalbe the sidewalls on the Goma's are tough, on the other hand they tip the scale at 881 and 888gr.
    Mounting them was a PITA on Notubes, they hold up air pretty well tubeless and the bead popped easily even with my pump, also they're not that wide, 2.18" on Sunringle Blackflag rims.
    The first ride was on hardpack about 25 miles and they roll well, not as my former Schwalbe set but fair enough, non technical climbs is where I could tell the extra weight though.
    Yesterday did a second ride, this time on a very rocky technical trail (28 psi rear/26 front) and the climbing over rocks became easy, I'm no longer afraid of sharp rocks and picking lines, braking was better on steep loose. Cornering was scary though...
    Highball CC
    Ripley 1st Gen
    Quote Originally Posted by kevocastro View Post
    The Goma is a tire that desperately needs a wider rim to square it out so that you can actually reach the cornering knobs at a reasonable lean angle. My rims are 24mm wide (internal) and that's barely enough to get the side knobs down in time, I can only imagine how it must be like with your rims.
    Robertson
    Reputation: rpearce1475's Avatar
    Jan 2015
    Got one of these, 2.25 for the rear on my 29er Yeti. Running a Maxxis DHRII front. I really really wanted to like the Goma, but climbing on it was poor, had wheel slip under power numerous times in places that's never happened with my typical DHRII rear. Also cornering was sketchy, the tire was drifty. For the record, was running it on 25mm internal width rims at 26psi. All in all, I can see how this tire would work for someone, maybe more XC oriented, who wanted something more aggressive than say a Maxxis Ikon. But I've definitely realized I value grip over rolling resistance (and the rolling resistance b/t this and a DHRII rear isn't that much). Going with DHRII front and rear.
    Short-Change-Hero
    Rpearce1475 - really? Not sure where you are riding because I have never had any issues with the Goma in loose terrain. I live in the Lake Tahoe area and have never felt what your are describing but then again I also run my rear at like 20psi tubed on 26mm external rims. I do find it drifts some with very loose or sandy corners but I don't know how hard you put your bike so that may have a lot to do with it. I have also runt the Goma from here to Steamboat Spring CO and never had it break loose on a climb unless it was incredibly loose or I was weight incorrectly.
    Maybe look at the 2.4" version with the Sticky Compound to see if that changes your ride any. I have been running my 2.25 folding sticky for close to 600 miles on two bikes and in Sedona Az to Steamboat Spring to Lake Tahoe. It is finally starting to show some wear so it will be replaced by the end of the season with another version. Currently have a 2.4" version on order for the front to replace my burly ass Geax Sturdy.
    Robertson
    Jan 2015
    In Alabama. Issues were on slightly wet trails yesterday, no traction on wet roots or rocks. Loose here is pine straw. I'm keeping the Goma for the rear of my XC HT that I don't ride as aggressively as my full suss, but for the Yeti I'll need more aggressive tires it looks like. For the record I came to the Geax (sticky compound) from an Ikon rear that gave me similar issues. Again, I bet this would be a great tire for some, it just doesn't really suit my riding style. Ah well, at least it was super cheap!
    SS Pusher Man
    Reputation: mtnbikej's Avatar
    Sep 2001
    I bought a 29 x 2.25 Sticky about 1.5 month ago....it was cheap and I had credits to spend at Backcountry.com
    I have pretty satisfied with it so far here in the loose over hardpack we have in So. Cal.
    It is set up tubeless on a CB Cobalt 11 front wheel(the same size as an Arch EX) around 24-26 psi for my 180 lbs.
    For my conditions, I haven't had any issues with traction. Rolls well, not an anchor. Has nice hook up. I am used to running sketchy tires(closet weight weenie) on the SS. Even ran it for a solo 12hr endurance race last weekend.
    I put it up there right next to the Ardent.....also reminds me of the old Minion DHF.
    I may buy a couple more....especially for the price.
    I resolve to constantly assert my honest opinion on anything and everything - whether it is requested or not.
    Bucky the Cat
    Today is gonna be ride #3 and feel like messing around with the tire pressure.
    Geared at 190lb, how low could I go? Last ride tried 28rear/26front
    Rocky technical trail
    Highball CC
    Ripley 1st Gen
    Sep 2012
    I'm geared up at about 250/260 give or take and I run them at 20psi and hit trails from xc to aggressive AM trails here in the PNW (Vancouver Island) quite regularly (2-3 times a week). Normally I cannot ride with tyre pressures below 26 without burping the tire and getting coated in tyre sealant.
    The only time i have burped the tyre was the other week in Fernie when I was coming down Castle Mountain, slipped on a root on a hard left turn on a DH track, slid a bit and burped the tyre (lost 4 psi).
    The more I ride these tyres the more impressed I am with them. Sure they were a little grease in the wet conditions over the winter time, but I have yet to find a tyre that can deal with the wetness we have here without some slippage/inability to hookup. The sidewall strength of the tyre has impressed me quite a bit as on a few of the trails I do I can cover bad rock gardens and root gardens that have shredded the sidewalls on my original high rollers and one of my HR2's when I first got my bronson.
    I have 26mm rims, 27.5 tyres and the sticky version with a tyre width of just shy of 2.4 (i think). I am a bit concerned with the life/duration of the for the cost of the tyre, but I will strongly debate putting them on again when I kill these tyres off.
    Which I am guessing will be by the fall with the amount of times I ride. although that may change with the recent lay off. Thank you OPEC!!!
    I guess dropping 2-3 psi it's safe enough
    thanks
    Highball CC
    Ripley 1st Gen
    Sep 2012
    I'd say you will be fine
    Regards
    Steve
    I suffer from fat finger syndrome and a tiny keyboard on an iPhone. So I apologize for the typos and misspellings.
    Well I tried 26 rear/23 front
    No more front washout but steep loose climbing lacks of traction on the rear, really enjoying going hard on these tires on the rocks without any concern of tearing sidewalls
    I don't think to drop psi anymore though
    Highball CC
    Ripley 1st Gen
    Sep 2012
    Geax goma
    Give it a try I've run me down to 16 front 18 rear at 250 geared up. Mind you it felt really unstable and the tires started to roll/walk on sharp corners hard corners. 19/21 is where I usually stick and they hook up fine for me in wet/dry.
    Now that the trails are all dried out here these tires are proving to be quite amazing.
    Regards
    Steve
    Short-Change-Hero
    Yeah depending for me I run mine 20/24 ish (f/r). I have run the GATO as low as 15psi before and it did not feel squirrelly or squirmy to me. I am currently playing with the GOMA 2.25 in front (with what tread it has left) with regards to pressures.. thinking I like it between 18-20psi.
    Sep 2012
    So three months in on the tyres and I'm thoroughly in love with them. I've had a few washouts on the front due to severely dry/loose tracks (we haven't seen rain in 6 weeks in my area) but they are predictable and nothing a quick foot stomp or drag won't fix.
    I'm guessing I'm at 60% tyre life but I'm expecting that to drop relatively fast here with our severely dry conditions. Guessing I warm/hot climates 4-5 months tops
    If you do 10-15 miles a ride 3-4 times a week.
    Overall, I'd definitely put theseoin again when they wear out. Although, I'm debating trying another brand/tyre type when they do.
    Regards
    Regards
    Steve
    Aug 2015
    Front : Geax Gato 29x2.3
    Rear: Geax Goma TnT 29x2.4
    Is this a good combo? Or should I swap these?
    Trying to find some rims larger than 25mm inside
    Quote Originally Posted by jacksonlui View Post
    The Goma 2.4 is a very big, high volume tire and I would worry about it dwarfing the Gato 2.3 up front. I prefer a wider tire up front and a slightly narrower one out back (just so it's a bit easier to drive and break loose when needed), and in my experience with the Goma up front, it had plenty of grip for dry NorCal riding.
    Where are you riding?
    Reputation: mtbiker040's Avatar
    I thought about trying out a Goma 2.4 Front, and AKA 2.25 rear on wide rims, looks like it would be a good combo. Has anyone tried that previously? (30mm ID)
    '15 Transition Smuggler
    change is good
    Sep 2004
    The 2.4 is a true enduro tire. Big and heavy with great traction even when damp. The 2.25 suffers when it's wet. The AKA I never fell in love with. The only advantage over the Saguaro IMO is its lighter weight. A set and forget tough fast dry conditions trail combo would be TNT 2.25 Goma front and TNT Saguaro rear.
    Reputation: ColinL's Avatar
    Feb 2012
    Quote Originally Posted by mtbiker040 View Post
    I am not a huge fan of the Saguaro, but I would definitely roll a Goma 2.4 front and rear. If the 2.4 doesn't clear your rear triangle - it's huge, and some bikes it won't - then use a Goma 2.25.
    The Saguaro is way too different from the Goma in my opinion. Now... the new Morsa... that would be interesting to try in the rear with Goma front.
    change is good
    Sep 2004
    The TNT Saguaro is essentially a XC race tire on steroids. Tread life is great but the hard compound contributes to its mediocre dry conditions traction.
    Aug 2015
    hi ininjoey
    I'm in san diego.
    Is the goma almost like a fattie? I've always wanted to try a 27.5+
    maybe rock goma up front and rear?
    Jack
    Quote Originally Posted by inonjoey View Post
    Quote Originally Posted by DrDon View Post
    sounds cool!
    Quote Originally Posted by ColinL View Post
    have to check out the Morsa, thanks!
    Feb 2012
    not available yet, that I have seen. which is annoying considering they showed it way back at Sea Otter...
    hi ininjoey
    I'm in san diego.
    Jack
    It's not a fattie, but it is one of the highest volume tires I've been able to find with firm, aggressive side knobs and a good channel between with the center and side knobs to allow the side knobs to really bite into corners. It also rolls surprisingly well because the center knobs aren't too tall.
    One word of caution on the Goma, however, is that you have to like a tire with a distinct channel and no transition knobs and ride it the way it's designed (trust the tire as you drift through that channel and then lean the bike to engage the side knobs) to get the best out of it. Some people don't like the feeling of the channel and go for something more along the lines of the Hans Dampf.
    For San Diego, I think it would be a pretty rockin' tire, as it has performed really well in the dry for me and the TNT casing is super tough to avoid ripping the sidewalls on rocks and to allow you to run it at low pressures without any squirm.
    Aug 2015
    awesome. thanks
    sounds like i should try a 2.4 goma tnt up front and maybe something around 2.35 (goma ,highroller2, ikon, minion) in the rear
    is there a particular rim that works really well on these type of tyres?
    I'm not a weight weanie but don't want to add more weight to the wheels if I don't have to
    May 2012
    anyone know where to find this tire in a folding 29x2.4?
    I ran the 2.4 Goma on a Stans Arch EX rim with no problems, my buddy currently runs it on a Spank Oozy 295 without problems and I've heard good things on wider rims than that, which makes sense given that the Goma has such a round profile. I still haven't tried it on my Blunt 35s, but it may get a run out on the rear when my HR2 is toast.
    Aug 2015
    these tires are hard to find for sure
    Sep 2014
    Quote Originally Posted by cburgin View Post
    Jenson has them:
    Vittoria Goma TNT 29" Tire > Components > Wheels, Tires and Tubes > Tires | Jenson USA
    Reputation: jon123's Avatar
    Been riding the 27.5 x 2.4 version in front. Love it.
    So far the tallest tire I've found - even a hair taller than the massive Trail King 2.4.
    I've found they grip better and roll better than the TKs.
    If you're looking for 27.5:
    https://www.biketiresdirect.com/prod...-tire?ss=46972
    Anybody weigh their 29x2.4? Claimed is 1080g.
    Feb 2012
    old inventory will be 'geax goma'.
    new will be 'vittoria goma'. make sure to search for both!
    Short-Change-Hero
    Quote Originally Posted by Porch View Post
    My non-TNT version 29x2.4 came in at just over 900g, wanna say 913g if I remember correctly, which I was pretty surprised at ... Also, it looks like Vittoria is changing things up a bit so keep an eye on the version you are buying, their new 4C and Graphene technologies have added a bit of weight but there seems to be 2 if not 3 versions.... the All Mountain version, the E-Bike version (E-Goma, considerably heavier) and I thought I saw a Gravity version but that was back before they added the Morsa and the new tech to their site so it could have been a typo.
    Dec 2012
    As mentioned earlier in the thread, my two tires came in at 900 and 790. Both non-TNT. Still very satisfied with the tire.
    Uncle
    Sticky, non-TNT version 29x2.4
    Oh wow, thanks! Not often that a manufacturer comes in at almost 200g lighter than advertised...
    Short-Change-Hero
    Which version of the tire are you looking at? When I was on their site the 29x2.4 folding was rated at 980g where as the TNT version was 1080g. It is pretty normal for a to be within 30ish-g or so, at least in my experience.
    You're probably right, i bet i was looking at the TNT.
    Not bad for a bit over 1000 miles of riding. Other than June, this year was bone dry in my area so it was mostly hardpack or moon dust over hardpack by the time August came around. Got some nice stress marks on all the knobs and the side knobs are starting to undercut on the stepped edges. The casing has proven to be pretty darn tough, I accidentally drifted the bike into a mess of tree roots at well north of 40km/h which ripped the tire clean off the rim and wrapped it around the brake rotor. It was a hell of a kaboom and put a few dents in my rim, the tire barely has a wobble in it and still mounts up tubeless just fine. I've done this to other tires in the past and they're usually complete write-offs.
    Overall, I'm quite happy with the tires and I'd definitely buy another set when this one wears out. Probably try out the E-Goma which has their new graphene rubber compound, it sounds like Vittoria's version of Conti's Black Chili compound which should help a lot with wet traction.
    Oct 2015
    Did you end up getting the GOMA? I'm wondering if this will fit on the back of a 2015 Smuggler.
    Quote Originally Posted by smokinsnakes View Post
    The 2.4 Geax Goma is huge. I ran it front on a 29 ID rim. Significantly bigger than the 2.3 Geax Gato I ran on the rear at the time. At first glance, several people asked me if it was 29+ tire.
    Oct 2015
    Awesome thanks. I'll run a 2.25 in the rear then, and keep the 2.4 for the front!
    Cheers!
  1. Geax Gato
    By DirtDummy in forum 29er Components
    Last Post: 06-07-2014, 08:45 PM
  2. geax saguaro.
    By AZGroundPound3r in forum Arizona
    Last Post: 07-28-2012, 08:09 PM
  3. Got a new Geax...
    By h2otaco in forum 29er Bikes
    Last Post: 01-18-2012, 03:34 PM
  4. Geax AKA
    By DanB1978 in forum Wheels and Tires
    Last Post: 09-13-2011, 03:27 PM
  5. Geax TNT or non-TNT?
    By kumes12688 in forum 29er Bikes
    Last Post: 08-16-2011, 02:36 PM
Members who have read this thread: 50
