    Force 135 hub on a smaller frame?
    Hello,
    I have an extra wheelset and wonder if I can fit the 135 rear hub on a Litespeed Unicoi ST without problems. (I want to keep the current Crossmax SL with narrow and slicker tires for commuting, then swap the other wheelset with beefy tires for trails)
    Ti is flexible and doesn't fatigue much so I should be able to force it...
    Any experience / thoughts / advice?
    THanks!
    transmitter~receiver
    Reputation: meltingfeather's Avatar
    you'll need to realign the dropouts or you'll stress the axle and likely break it after a while.
    seen it happen.
    Quote Originally Posted by pvd
    Time to stop believing the hype and start doing some science.
    29er Tire Weight Database
    new name, old member
    Reputation: Bike Whisperer's Avatar
    The Unicoi is 135mm spaced...why wouldn't it fit?
    Single and loving it (single speed bike that is)
    http://mtnbiker72.blogspot.com/
    http://www.ccfa.org/
    Ha... mine is an older model, the hub on the current Mavic wheel looks narrower than the 135 that I have lying around but I guess looks may be deceiving
  1. Replies: 12
    Last Post: 02-02-2013, 09:51 AM
  2. Benefits of smaller-vs-larger frame for FR?
    By edenger in forum Downhill - Freeride
    Last Post: 08-22-2011, 06:26 PM
  3. BMX Background: Is it weird to want a smaller frame?
    By veloryan516 in forum Bike and Frame discussion
    Last Post: 02-20-2011, 12:07 PM
  4. FS Carbon Frame 15" or smaller?
    By JimmyNeutron10101 in forum Bike and Frame discussion
    Last Post: 02-01-2011, 10:14 AM
  5. Replies: 2
    Last Post: 01-11-2011, 09:04 AM
Hot Deals
Contests
Latest Mountain Bike Articles
