Results 1 to 17 of 17
    Merendon Junkie
    Reputation: abelfonseca's Avatar
    Dec 2011
    Even tension on repaired rim?
    Hello everyone,
    A cousin took a dive the other day (on my bike) and bent the rear wheel. He was able to ride it back home but there was a very evident wobble although it didnt hit the stays, about 8 mm side to side and a 2mm dip. I was able to get it true but the tensions were all over the place. Some spokes were really tight and some really loose. I then tried loosening all the spokes till they went slack and true and retention from there. I basically got the same result, some very tight and some very loose spokes. If I tried to even out tension, trueness went out of wack. I reached some sort of middle ground where the tension was not so uneven but the rim still has a small wobble.
    Did I do something wrong? Is there a way to true back a bent wheel and get acceptable tensions between the same side spokes or is this just not posible once a rim is bent in a crash?
    Cheers
    Abel
    Reputation: fefillo's Avatar
    Jul 2014
    Get a new rim, then a new cousin!
    Oct 2013
    I do have a couple or rims like that, there's absolutely nothing you can do, "bending them back" is not an option. ^^ that suggestion or live with it until you replace the rims/ wheels
    2014 Kona Process 111a FS (29er)
    2013 Trek Fuel EX7 FS (26er)
    A wheelist
    Reputation: Mike T.'s Avatar
    Quote Originally Posted by abelfonseca View Post
    It's junk.
    Mike The Bike's home wheelbuilding info - dedicated to providing Newby wheelbuilder information and motivation.
    I Tried Them ALL... Moderator
    Reputation: Zachariah's Avatar
    +4 toss it out.
    The uneven tension exists....because certain spokes has to constantly keep the compromised rim somewhat 'straight."
    "The mind will quit....well before the body does"
    Merendon Junkie
    Dec 2011
    Thanks for the replies guys. I was planning on replacing that rim with a carbon rim (chinese). Im gonna go ahead and order it sooner than I thought. My front rim is carbon, it been great. In the meantime, how would you ride it? true but with tension all over, or more or less trued and more or less evenly tensioned? Or would you not ride it at all? It gonna be about 1.5 months till I get my rim here.
    Cheers
    Jul 2014
    Cheers
    What kind of riding does this wheel see? I would go for the more or less approach unless you can feel the wobble. You really don't want to have some spokes that are very loose or you risk starting to break spokes for tension cycling.
    Merendon Junkie
    Dec 2011
    Its a 29er hardtail, rearwheel. Basically rocky terrain, some roots. Very little air if any. My kid cousin is riding this bike now, he is visiting his parents before starting his phd. He is a very strong rider, 210 pounds geared up, very little fat. We do XC rides mostly, 30 to 70 kms per ride.
    Jul 2014
    Yeah, so as I said before... unless you're racing and it's super critical, I would go with the middle option between tension and trueness to try to prolong the life of the rims/spokes until you are ready to replace.
    In the end though... There is no one "correct" choice here.
    Oct 2013
    ^^^+1, good advice
    Reputation: J.B. Weld's Avatar
    Cheers
    If it were me and I was going to ride it for awhile before it was replaced I'd re-bend the rim to even out the tensions. Not the stomp on it or throw it on the ground methods I've seen on U-tube, you can be really precise if you have a solid slot you can insert the rim into and bend it back at the same place it got bent in the first place.
    I've re-bent tons of wheels with great success.
    Jul 2014
    Quote Originally Posted by J.B. Weld View Post
    Where do you find good quality but cheap solid slots nowadays?
    Oh, the huge-meh-nity
    Aug 2013
    Quote Originally Posted by fefillo View Post
    You might get lucky with a sewer grate, but I bet the city paid WAY too much for them.
    Jul 2014
    Quote Originally Posted by Zowie View Post
    I guess that would work fine if you are ok with dirty slots.
    Ok... I'm done! Sorry.
    Aug 2013
    Hey, no jumping the gun, I said you might get lucky with a sewer grate.
    A sewer grate is no good, the slot needs to be solid at least 6" deep. I built one on the underside of my workbench.
    Oct 2013
    I do not have the slot available to me but I do have a square frame I use for my wheels. I stood up on the WTB i23 rim, and it looked like it bend back a bit but nowhere to making it close to the original shape. My conclusion is that if it gets bent to the point where the spoke tension is all over the place, with huge deltas between spokes, then it is time to replace the rim
  1. What does max spoke tension for your rim mean? Average tension?
    By happyriding in forum Wheels and Tires
    Last Post: 03-23-2014, 12:03 PM
  2. Is this rim all done, or can this be repaired?
    By Seventh-777 in forum 29er Components
    Last Post: 10-15-2013, 04:30 PM
  3. Need Wheels Repaired
    By ronbo613 in forum Texas
    Last Post: 10-03-2011, 07:09 AM
  4. Can this be repaired?
    By kzoo_cyclist in forum Frame Building
    Last Post: 09-17-2011, 06:17 AM
  5. Can this be repaired ?
    By jpeters in forum Frame Building
    Last Post: 07-05-2011, 04:04 PM
