• 01-26-2013
    ozzybmx
    ENVE wheel nipple corrosion.
    Anyone had any problems with UST ENVE wheels regarding nipple corrosion ?
    My wheels are just over 18months old and have never been ridden in water, i live in the driest state on the driest continent on earth :p (actually a fact) so its not even moisture and rain is not an issue either.
    So approx at the 12-14 month mark i start hearing this rattling noise inside the "nipple chamber" on both wheels and think to myself its only some dirt thats got in there.
    But its taped tubeless so nothing can escape into the wheels or stans escape out. The nipples seal the hole from the inside so no dirt can get in.
    So then during a ride (November) i notice my front wheel is way out of true, when i get home i see that a spoke is loose but undamaged, i untape the wheel to see that all the nipples have a dusty white appearance (corroded), and 3 of them are nearly disintegrated but theres so little left of them i cant even get them off without cutting a perfectly good spoke.
    The rattling noise was shards of alu from the sides of the nipples and obviously the disintegrated one from the loose spoke that is nowhere to be seen. The shards looked to be stuck together in little balls as if they had picked up some of the sticky glue from the Gorilla tape that is sticky side down on the underside of the spoke access hole.
    Has some stans fluid possibly escaped into the "nipple chamber" and done this ?
    Gorilla tape IMO is crap so wont be using it again.
    Back wheel i stripped tonight has also 4 nipples in advanced state of corrosion. Cant do much about it as i dont have replacement Sapim CX ray spokes to replace the ones i would have to cut. I have replacement nipples but cant get a nipple driver to grab a corroded nipple :confused:
    So ive rinsed the chamber out on both wheels and will retape them with Stans tape tomorrow.
    Is there any fluid i could put in there to help reduce corrosion that WOULDNT damage the carbon fibre.
    I have no idea if this is an ENVE wheel design problem, nipple issue or what.
  • 01-26-2013
    crux
    I've never heard of this happening on a set of ENVEs but then again they are still a young company. If possible please take a pic of the white corrosion. From the sounds of it might be the aluminum it self corroding.
    With carbon composite layups I've seen where it will start to corrode an aluminum BB or head tube from the old school carbon frames. Wonder if this is the same reaction you are seeing.
    Very curious as I just finished building up a set of ENVEs myself.
  • 01-26-2013
    ozzybmx
    Ive cleaned both wheels so no pics. Its definately is the alu corroding but its what has caused the reaction thats beyond me.... i'd see though it if i rode on a beach or through salt water.
    I have not taped them up yet but will be next to impossible to take a pic of a nipple down inside the "nipple chamber".
    The other strange thing is that theres only 3-4 nipples in each wheel that are badly corroded, the rest have the fluffy white corrosion look but it rinsed off with cold water and they look relitively undamaged whereas the others are completely fu%*ed including the one that let go without any trace.
  • 01-26-2013
    DWill
    The white is AL Oxide. The AL is reacting to the dissimilar SS and possibly the carbon.
    There's no reliable way to stop it that I know of, you can slow it down by using some sort of lube or something to create a barrier; but that likely will create other issues.
    I also have a new set of Enve wheels my plan when I bought them is to check the nipples at least every 6-9 months and have them replaced at the first sight of any corrosion.
    You might give Enve a call (assuming you got them built from Enve) and see of they'll help you out with a rebuild under warranty; but I doubt they will as this is probably considered normal wear and tear. Does seem like it happened pretty quickly though.
  • 01-26-2013
    The Beater
    I live in Kamloops BC and the climate is similar what you described. The dust seems to kill Alum nips all of the time. Most bike shops will not build wheels with Alum nips unless specified by the customer and event then they will warn people that the disentigrate over a season or 2.
    I had the nipples on my nomad do the same as you have described over 2 seasons. The rims were DT 500.s
  • 01-26-2013
    customfab
    I've been dealing with Enve for about 5 years now, built a bunch of their rims, and I've seen this a couple of times. However the only times I've seen this is on bikes that spent a lot of time in coastal areas. I would imagine in your case that the stans has massively accelerated the oxidation process and made a mess of your wheels. Might try something other than stans. I know some of the other formulas are supposed to be less caustic.
    Enve is a pretty stand up company, I'd give them a call and see what they can do for you.
  • 01-26-2013
    car bone
    Haven't read a single ****ing comment of this thread byt GALVANIC corrosion is something that you might wanna look into. Carbon fiber is a helluva conductor of electricity and you are riding on rubber tires isolating you from earth, and all isolated element build up static electricity by just being isolated, and its no joke e3ither..
    I'm guessing this is the first sign of the galvanic potential of carbon in practical use. You did good man. just get brass nipples from now on, preferably nickel or chromed ones.
  • 01-26-2013
    customfab
    If the wheels were built using a synthetic grease the galvanic corrosion is largely mitigated. If a petro based grease was used it will certainly make it worse.
    Can't use brass nips on Enve wheels, they use a semi-proprietary internal nipple.
  • 01-26-2013
    car bone
    I didn't know that.
  • 01-26-2013
    ozzybmx
    Some interesting points... cheers !
    The wheels were ordered direct from ENVE so what ever lubricants they use to build wheels - if any, is the only stuff put on them. I taped them up with gorilla tape and started riding them with stans added.
    It has to be corrosion from the inside as the nipples are not exposed to the outside air/dust/moisture. Something has gone on inside the "nipple chamber" and the only things i can put it down to is a reaction from Stans fluid, Gorilla glue or now Galvanic corrosion..... though i have never had this happen with any other wheels before AND i build all my own wheel sets so i take good notice of what they are doing as far as nipples, spokes, tension and trueing.
    BTW there was no tell-tale signs that i was losing stans fluid inside the wheel, both wheels had 2 wraps of tightly wrapped gorilla tape on them and apart from sticking to tyres and leaving a mess when removed it had stuck quite well. Even through the tape at the valve hole was stans free.
    I got replacement nipples from my LBS through the Aussie agent, that took 6 weeks and people wonder why we buy everything online.
    Will contact ENVE and see what they think, i actually sent them an email on the 29/11/12 about sourcing new nipples and telling them i had one disentigrate but got no answer. I send a link to this thread too.
    Cheers for the help :thumbsup:
  • 01-26-2013
    geo025
    It's one of the disappointments of Enve rims, I have an Enve rim that I would like to change to brass nipples . Can any point me in the right direction? I'm almost tempted to buy standard nipples & grind out the slot.
  • 01-27-2013
    customfab
    Fwiw, I've got a set of 29 er wheels that's almost 5 years old with no corrossion. I've never even tried to run them tubeless though and I also live in the high dessert.
    Pillar makes enves so called proprietary nipples, if anybody does a brass version, its them. Whatever you do, don't drill out the holes.
  • 01-27-2013
    meltingfeather
    ENVE nipple holes are laid up as well (not drilled) which means that the nipple is not in contact with the fibers.
    Why would petro grease make it worse?
    Internal nipples are available in brass too.
    :thumbsup:
  • 01-27-2013
    customfab
    :thumbsup:
    While it may not be in contact with the fibers it is in contact with the composite. There isn't anything isolating it from contact, like a brass washer. I don't think think the fact they net mold the spoke holes makes a difference when it comes to galvanic corrosion. Could be wrong though as this is pushing my knowledge.
    Synthetic grease is supposed to be low conductivity. I was told by a composites engineer long ago, if you need to grease carbon structures, use a synthetic grease. I've built 70 Enve wheels with it, and I've never had one with nipple corrosion problems, must be something to it.
    Pillar, who makes the Enve nips does not list that nipple as available in brass. Other internal nipples might be available in brass, but these are a little different. They're 7075 in case anybody was wondering.
  • 01-27-2013
    meltingfeather
    The resin, which doesn't conduct electricity, isolates the fibers from the nipple. Testament to this are the aluminum:carbon interfaces all over modern bikes. I was just adding to your point that galvanic corrosion is suspect as an explanation.
    Worth a look anyway. :thumbsup:
    I think Sapim makes 'em.
  • 01-27-2013
    ozzybmx
    Thanks for the replies, ive sent ENVE an email and link to this thread. Hopefully they might have a solution to stop this corrosion going any further.
    I dont want to tape them up and start riding them again if the nipples are going to continue to corrode effectively turning the wheels into a time bomb with the nipples disintegrating and spokes popping out.
  • 01-27-2013
    customfab
    They're Pillars, I've ordered them to build other wheels with directly.
  • 01-27-2013
    patineto
    haven't read a single ****ing comment of this thread byt galvanic corrosion is something that you might wanna look into..
    +one
  • 01-27-2013
    ozzybmx
    Ive just had a look on the sapim website, they make inverted nipples in brass but not pillars. These would need a special tool where as the pillars just need a long series socket.
    EDIT: Just found a website that sells internal brass and the 3.2mm square tool. Will wait and see what enve says then i might rebuild both wheels with brass internals.
  • 01-28-2013
    geo025
    Can you post a link to that website?
    I found the Sapim brass inverteds (Inverted | Sapim),
    but would like to see what you found.
  • 01-28-2013
    ozzybmx
    Here's the site
    $35 for 56 brass nipples and $9 for the 3.2mm tool.
  • 01-28-2013
    geo025
    Here's the site
  • 01-28-2013
    bholwell
    I'm not sure of the root cause of failure, but just to throw this out there- Stan's has been known to corrode the inside of certain Shimano road rims, which apparently have little to no anodizing. I believe there's a lengthy thread on forums.roadbikereview.com.
    I wouldn't discount sealant corrosion, as I've seen multiple leaks through gorilla tape.
  • 01-28-2013
    WilliamK
    Same problem
    Hi ozzybmx, Just so as you donít feel alone in this issue. Iím in Qld and Iíve experienced this problem a lot. First of all was 3 or 4 years ago when I bought a set of DT carbon wheels.
    I found out one time when I banged the rear into a bank and the back wheel broke a bunch of spokes (bike stopped, I kept going and checked out the track more closely). Back at the LBS they pulled it down, the nipples were corroded and this had weakened the wheel (normally a rough roost wouldnít do that Ė the DT Cs were amazing in the rough and tumble).
    Refitted, special attention to taping etc, rode for a few months and the front broke a spoke. Should have pulled that down back then to, it was corroded. Replaced all nipples now, and then I had 3 more broken spoke incidents on 3 more occasions Ė all from corrosion. The downtime was frustrating. Special attention was given to cleaning and fresh tape each rebuild.
    I had a trip to NZ planned, which meant speed, berms, and berms (did I say that already, well there's so many of them....), drops, bumps and jumps. So I was a little worried breaking another spoke/s a month out or during the trip. I stripped both wheels (darn, had to put fresh rubber on Ė gotta love fresh rubber before a big trip), new spokes and new brass nipples. Rode this on the trip and for a good 9 months without a further issue, just the cracks in the rims were growing too big for me to keep running them and besides, I had another trip to NZ planned, more berms and jumps (did I mention that).
    I bought some Enves, and on inspection the same issue occurred a few months in Ė corrosion. Then I bought a 29er as well, and some more Enves, and I have corrosion in those nipples. And, yesterday I heard a rattle in the back tyre. Your thread is a timely reminder and has solved my rattle issue, bloody corrosion has struck again. Iíll be chasing some brass to shut down this corrosion issue.
    From my DT carbon experience, the Enveís have taken a lot longer to corrode the nipples. (The DT were great wheels, off the charts performance, just complaining about corrosion). I am saying this to indicate that I donít think it is a particular Enve specific issue and actually, they are better than another Carbon wheel experience I have had in terms of what I believe is sealant induced corrosion.
    And about the only solution is to go brass nipples. I firmly believe it is the sealant, not saying it is just Stans either as I did run another brand of sealant as well, it is the cost of running AL nipples. AL is hopeless with corrosion. Itís annoying as you want to keep the rotational weight on the outer edge down as much as possible and running brass nipples just feels a little counterproductive with carbon wheels, but, if it works and keeps the wheels together and keeps them rolling, then that will pay in the long run I guess. Besides carbon wheels isn't necessarily about the weight, it's the overal performance of them that is so impressive.
  • 01-29-2013
    ozzybmx
    Cheers WilliamK, just got a reply back from ENVE and the Pillar (brand) nipples that they use are not a hard anodized alu so thats the reason for the rapid corrosion as they are soft alu.
    ENVE think its my climate caused it but im with you on the Stans theory coupled with the crap Gorilla tape that shouldnt be used on wheels at all... its dry and hot here with little rain and the corrosion happened on the inside where it was dry apart from the sticky balls of alu shards.
    Seems im on my own with the issue so i'll buy the brass nipples + the tool and rebuild them myself.
    Also i wouldnt worry about the weigh penalty of brass as the 1 wrap of gorilla tape weights more than the 20g extra per wheel running brass (30g) over alu (10g).
    Thanks for sharing :thumbsup:
  • 01-29-2013
    ozzybmx
    Done ! just bought the nipples and tool, hopefully they wont be too long as ive been off this bike because of the wheels since late November.
  • 01-29-2013
    Adroit Rider
    I am struggling to understand why ENVE would use a nipple that has not been hard anodized. Could anyone speculate for me?
  • 01-29-2013
    customfab
    The inside of the rim is shaped specificaly for the pillar nipples. Using something else might give reason to void your warranty. If thats a concern to you, you could have a set of nipples anodized and that shouod cure your corrosion woes.
  • 01-30-2013
    ozzybmx
    Im kind of over a barrel anyway as i wont ride the wheels in the current state. ENVE have stated they are quite aware of the problem in some enviroments with the pillar nipples and said "its likely has something to do with the Stanís as well" and have advised me to rebuild the wheels with "Sapim internal nipples or something similar" so i should be good to go.
    They are also "developing a lightweight brass nipple to address the solution"
    Quoted"" above are exact words from the email.
    The new nipples are on the way Fedex Priority, i'll have the wheels rebuilt in a couple of days after recieving the new parts. I waited 5 weeks to get the Alu nipples ordering here in Oz so its probably the best solution for me to do it myself anyway.
  • 02-01-2013
    customfab
    Because they don't make them and they don't want to have them made.
  • 02-02-2013
    car bone
    As far as I know, and I know quite a lot about composites, it would take a lot of extra work to just get resin in the interface, its most likely as the rest of the composite, 50/50 fibers/resin at the contact area.
    Somehow the mold this right, and they stick some pin or something in there and just lay up the fibers as usual or in some type of special pattern around the holes, maybe a different fiber orientation but I'm guessing you would still have contact between the actual fibers and the nipple when done. I just can't see this happening with the actual fibers isolated from what they put in there when making the hole. Sure it could be done. But I'm kinda sceptical to that since the resin itself is not at all strong/hard/creep resistant (its plastic, epoxy plastic), the strength in the composite comes from the ablity of the resin/matrix/binder or whatever you wanna call it having good adhesion to the fibers and their molecular bond.
    could be wrong though.
  • 02-02-2013
    car bone
    If you could find brass nipples you can have one sacrificial alu nipple in there and you only change that one since it will attract all the corrosion just like sacrificial anodes on boats.
    Anodized alu have a coating of alu oxide, thats a ceramic, and its nonconductive, and unless the oxide is removed while assembling, the nipples would be somewhat isolated galvanically, which the goo inside I don't know. Test the resistance of the goo with a multimeter and find out if its a good conductor.
    If you can o0nly find alu nipples I suggest stocking up on them! AND using synthetic grease just as customfab recommended, and lots of it too., preferably some waterproof grease. Marine grease. OR anodizing the nipples yourself or have someone do it properly. Black Type 3 hard coat or something.
  • 02-02-2013
    ozzybmx
    I have 64 brass internal nipples (only needed 56 but got a few spares) currently in the local Fedex depot to be delivered to me on Monday morning. Not taking a chance on alu again, they are absolute nightmare, i still dont know how im getting a few of them off without cutting spokes... im hoping the remaining few will come out when the tension is off and the "dish" of the wheel is relaxed.
    Will then set them up tubeless with stans rather than gorilla tape.
  • 02-02-2013
    meltingfeather
    I'll defer to you if you have direct experience. My understanding is that the structural stuff is covered with cosmetic layers and typically some kind of protective coating.
    I didn't mean to imply that when it's laid up they somehow keep the fibers from the surface.
    In any case, why hasn't my carbon bar destroyed my Thomson stem or my carbon post destroyed the aluminum frame of my FS? There has to be some isolation. It seems to me that it's likely on the carbon rather than aluminum side.
  • 02-02-2013
    qbert2000
    so envy is hands off on your problem??? kinda $h!tty considering they are $800+ a rim and they use proprietary nipples. they warrantied them for someone else with the issue
    Originally Posted by 29or6to4 View Post
    My original Edge rims had a problem with the old Pillar nipples they use to use. They were all corroded and falling apart within the rim. So wheelset went back to them and the UST just were made available. I might have got one of the first sets, any way for a small amount extra I could have the hubs built with new UST's and keep my Edges. Sold the Edges to pay for the new Enves. Worked out pretty good. I like not having to use the Stans rubber strip to keep tubeless.
    http://forums.mtbr.com/turner/enve-r...ml#post9111453 from that thread
    lol, they have obviously figured out a way around it
    LIMITATIONS OF WARRANTY:
    Warranty does not cover parts that have been incorrectly installed, serviced, or otherwise adjusted respective to the ENVE installation manual.
    Warranty does not cover damage sustained to parts used for applications beyond the scope of their intended design (ex. Using All Mountain rims for Downhill).
    ENVE Grey brake pads are provided with ENVE rims and complete wheelsets. Failure to use the ENVE Grey brake pads will void the warranty.
    Warranty does not apply to damage related to a crash, impact, unauthorized alteration, abuse of product, and normal wear and tear. See ENVEís Lifetime Crash Replacement. Normal wear and tear refers to:
    Worn out braking surface
    Worn or damaged brake pads
    Damaged spokes from crashing or poor shifting adjustment
    Nipple corrosion
    Superficial chips and scratches on rim or components
    Warranty does not apply to parts manufactured by other manufacturer (ex. hubs, spokes, nipples). Consult the individual manufactures for issues related to these parts.
    Warranty for ENVE tubing and other molded frame parts such as seat stays, chain stays and head tubes covered under standard two year warranty.
    kinda sucks for the end user when they currently have only one real option for nipples and they obviously do have corrosion issues. would make me feel pretty sick dropping that kind of cash on a product where one of the main components can corrode and it's on you.
  • 02-02-2013
    flyinmike
    Until they sort this out I wouldn't consider using ENVE rims
  • 02-02-2013
    ozzybmx
    $800 rim, the wheels were built by Enve and shipped to me direct... $2700.
    Yeah it sucks a bit that I got no help to rectify the issue apart from Enve saying it happens and they are aware of the problem and I should rebuild them with brass internal nipples.
    But hey, it's a $50 fix I can do myself and I hadn't even looked at the warranty limitations.... I just wanted a solution or help to fix the problem.
  • 02-02-2013
    qbert2000
    what happens to your warranty when you rebuild with a brass nipple then? it is voided? if they know of the issue you'd think at $800 per they'd be working on a solution
  • 02-02-2013
    Fix the Spade
    The warranty specifically exempts them from nipple corrosion, so I'd say that they have a solution already, just not a very nice one.
    It seems odd that on a $2000+ wheel set the manufacturer is too cheap to pay for anodised or brass nipples. Guess they've been talking to Fox about customer service...
  • 02-02-2013
    ozzybmx
    Heres the extracts from the email i posted above.
  • 02-02-2013
    qbert2000
    Props to you, you are an incredibly understanding and patient man. I hope the rebuild goes well
  • 02-03-2013
    derby
    Maybe ozzybmx's wheel set was exposed to tropical salty air conditions during shipping to Australia? This could explain such rapid corrosion too. Salty film on the nipples never washed away would continue to attract any moisture, and oxidize quickly.
    I've always used alloy nipples, DT brand, building my own wheels for 15 years. One wheelset did fail after 3 or 4 years from nipple corrosion, using Mavic's first UST aluminum rims, the special nipple adapters failed. But I can't recall a DT nipple fail from corrosion. I do frequently wash my bike after most rides, because I don't have a garage and must keep my bike in my house, and when the bike is sitting in the sun I have often seen a little water drip out of the rim at a low spoke hole. For me 3 to 4 years is satisfactory life for an aluminum wheelset, the rims are pretty beat by then. I hope my carbon fiber rims hold up much longer, like cf frames usually do... time will tell.
  • 02-04-2013
    ozzybmx
    Heres the box.... the proud day it arrived, wheels were perfect and completely sealed. Absolutely no signs of anything either contaminating the box or anything getting inside.
    This is something that has happened since i got them, some reaction with tape, stans or whatever.... its beyond me and ENVE are not exactly clued up on what caused it yet either BUT they have acknowledged its happened before, they have an idea whats causing it, and they have gave me a solution which i cant see any reason why it wont fix the problem.
  • 02-04-2013
    29or6to4
    Wow I can't believe this is still a problem with Enve/Edge wheels. I would have hoped they had changed the nipples by now. Time to peak in my wheel and see how they look.
  • 02-05-2013
    ozzybmx
    Heres the nipples from the rear wheel, its now finished and fitted with brass internal nipples.
    I'll get the front wheel done tomorrow hopefully, it was the one that spoke came loose and the nipple disintigrated.... now its became clear why.
    9 of the nipples on the rear were too corroded and couldnt be undone by the socket. It took a bit of time but the only other alternative is cut the spokes
    Also in the pic is the alu pillar nipple, what the rest of them should look like and the other one is the new brass internal nipples im fitting to the wheels now. Pictured at the bottom was the worst nipple on the rear wheel, looks like it was ready to let go at anytime.
  • 02-05-2013
    Fix the Spade
    Begs a serious question, why don't/didn't Enve put any fibreglass round the rim bed?
    Fifty grams of E Glass, problem never happens.
    Another question, what tool are you using for the new nipples?
  • 02-05-2013
    ozzybmx
    Click here, scroll down the page to spoke tools, its the 3.2mm square one that i got.
    The nipples came from there too, pretty good as he sent it fedex priority and were here in 5 days for $6 shipping.
  • 02-05-2013
    29or6to4
    Just a look at your pic. The brass nipple does not seem to be the same OD as the pillar. Can you confirm that the brass sets squarely in the molded carbon nipple slots?
  • 02-05-2013
    car bone
    car bone feels your pain ozzy. what a bunch of f***ing jokers they are. did they really think this through? they thought this was going to work? when building something; if you spend less than 95% of time thinking about how it should be done, all possible ins and outs, then you're doing it ****ing wrong and thats it. this is proof.
  • 02-06-2013
    RiverSurfer
    Enve
