FAT BIKES
WINTER APPAREL
TRAINERS
Page 10 of 12 FirstFirst ... 6 7 8 9 10 11 12 LastLast
Results 226 to 250 of 292
  1. #226
    Huckin' trails
    Reputation: David C's Avatar
    ENVE wheel nipple corrosion.
    Lol ^^
    Quote Originally Posted by NicoleB28 View Post
    topless. that's what all mtb girls do. we go ride, get topless, have pillow fights in the woods, scissor, then ride home!
  2. #227
    Huckin' trails
    Anyway, 006_007 you'll be pleased to learn that I just finished installing all the 32 nipples on the front rim after 1.5 hours. All 12mm brass in electroplated black and gold, with lube on the nipples head.
    Then later I was up till midnight lacing the wheel. Now I have to do the rear one.
    Oh, and that I had pancakes for breakfast.
  3. #228
    Huckin' trails
    Well rear wheel is done too.
  4. #229
    meow, meow.
    Reputation: J. Random Psycho's Avatar
    These are hookless, right?
  5. #230
    Only took an hour and a half per wheel? That is pretty cool. Any pics of how you actually did it?
  6. #231
    Huckin' trails
    Quote Originally Posted by AKamp View Post
    Well to be honest it was more like 6 hours total for both wheels to install the nipples, then lace them up.
    You can't really take pictures of how-to, but it's easy to explain. Just take a long derailleur cable with both ends cut clean, then solder the tips so they don't fray. Next you need cable crimps that you will cut open so you can slide them onto the cable and crimp them on and off later. Then you insert the cable trough the farthest spoke hole and push it in till you can see it by the valve hole. Proceed to grab the tip of the cable with needle nose pliers and pull it out off the rim by the valve hole. Pull enough cable so you can slide in a nipple and a crimp and pull everything back to seat the nipple in the hole, making sure the cable will be long enough not to be pulled back into the rim. Next tie a rubber-band around the nipple to prevent it from falling back into the rim. Then pull back the cable till the crimp comes out and remove the crimp by pinching it the opposite way you first pinched it. Then pull the cable back out from the nipple and start over again with the following farthest hole, etc. Also I put some lube on the nipple head before pulling it into the rim so it would lube the nipple seat on the rim. Use silicone or teflon lube on the cable if it doesn't slide easily.
    It's just painful when you're doing it all over again for the third time because of bad spoke lenghts and other planning issues. But this time it's for good. Tires, rotors and cassette are mounted, nect step is to ride to the bike coop where I'll have the pro Park trying stand and the tension meter so I can bring them up to high tension and perfectly round and straight.
    Quote Originally Posted by J. Random Psycho View Post
    Nope, they are the 30mm wide by 33mm deep 26" DH rims from LB. They are UST compatible and have a nice profile, but aren't hookless. They were originally intended to be hookless, but many people told LB they wanted clincher rims afterward. I wish they would have kept going with the hookless design though.
  7. #232
    meow, meow.
    David, thank you for clarification. But why did you want them hookless? What are the advantages vs hooked besides easier manufacturing?
  8. #233
    Huckin' trails
    2 main advantages, first is stronger sidewalls and easier/cheaper to manufacture (big deal in carbon tech) and second is the possibility of higher sidewalls to prevent burping even more and easier to seat the tire tubeless.
    But stronger rims are the real deal with hookless.
  9. #234
    Reputation: 006_007's Avatar
    Quote Originally Posted by David C View Post
    Ok, but I was never concerned about how you installed your nipples (nor did I learn anything from it)
    Looks good - hope you have the right size spokes this time!
  10. #235
    Huckin' trails
    Quote Originally Posted by 006_007 View Post
    Thanks. While we're at it, let's keep it on the corrosion topic. I also switched all my bolts and nuts to stainless, as well as my cables and spokes are stainless too. I'm gonna hit the snow trails with this bike in a few weeks once it's packed down.
  11. #236
    Dec 2013
    agreed.
  12. #237
    FYI, just weighted the difference between 32 pillar internal brass nipples and 32 DT external aluminium nipples and it is 8.1g...
    I can live with the extra weight
  13. #238
    Is that the rattle sound?
    This is my bike... a 2013 F29 Ultimate. The noise is getting louder and louder...
    Enve front wheel rattle sound. - YouTube
    Already checked... and thetre's nothing to do with the tire or sealant.
    The sound comes from inside the rim.
  14. #239
    Quote Originally Posted by eduluke View Post
    That's what mine sounded like with the nipple corrosion issue, however, when I removed the rim strip in addition to corroded nipples I also found little balls / clumps of hardened spoke prep compound rolling around inside which I believe was also causing some of the noise (like ball bearings rolling around inside the rim). Easy enough to check. Pull up the rim strip and look at each nipple with a bright flashlight. It will be quite apparent if you have a nipple corrosion issue.
  15. #240
    Jul 2014
    I have the same problem.
    (sorry about my english)
  16. #241
    Jul 2014
    ENVE solves the problem under warranty???
  17. #242
    Sadly my Enve's suffered the same corrosion. Thankfully my LBS is awesome and taking care of it for me. I believe this is covered under Enve warranty.
    Santa Cruz Tallboy LTc
  18. #243
    ~ B A D A S S ~
    Reputation: car bone's Avatar
    If you push for it. it will probably be covered. otherwise not.
    Rule #9 // If you are out riding in bad weather, it means you are a badass. Period.
    Quote Originally Posted by iheartbicycles View Post
    Specialized sucks ass.
  19. #244
    I Tried Them ALL... Moderator
    Reputation: Cayenne_Pepa's Avatar
    Enve was high on my carbon wheel list. But when I found out about their internal nipple design - the made in USA and "bulletproof" moniker soon became insignificant....having imagined a ride-defeating, trailside wheel straightening session, with tape, tire, tools and sealant all on the side of the trail. No bueno....
    "Don't swallow anything Satan rams down your throat.....Jesus comes first, always" - Pastor Joel Osteen
  20. #245
    dang i just snapped a nipple.
    there goes todays ride...bummer
    probably better i catch it now i guess?
    I have enve am 29er with 28 spokes and love em.
    tbc
  21. #246
    transmitter~receiver
    Reputation: meltingfeather's Avatar
    Quote Originally Posted by Zachariah View Post
    How many times have you or anyone you know done this?
    It's not unusual to break a spoke in a wheel like an ENVE and not even know it or wrap up the spoke and ride out without issue.
    A spoke wrench isn't going to get you what you need on a disc wheel that is so out of true it is unrideable.
    Quote Originally Posted by pvd
    Time to stop believing the hype and start doing some science.
    29er Tire Weight Database
  22. #247
    Fat & Single
    Reputation: ozzybmx's Avatar
    The issue with the corrosion problem is that all the nipples are damaged badly, the stump of nipple that's left is severely compromised. The nipple giving way is because there is nothing left of it and it pulls through the spoke hole, at this stage there is probably half a dozen others with 10% left holding.
    I had a rim fracture when un-sewing one of my wheels, took off the first few nipples and there was too much tension on the next few compromised nipples, they pulled through and fractured the rim.
    I have had zero issues since ENVE fixed me up.
    Trek 9.9 Superfly SL
    Ti O'Beast
    Fatty
    FM190 Fatty
    Indy Fab Deluxe 29
    Pivot Vault CX
    BH G6 Roadie
  23. #248
    Quote Originally Posted by ozzybmx View Post
    Each spoke should be detensioned little by little.
  24. #249
    Fat & Single
    All well and good when you can actually get the nipples off, mine were so badly corroded that the spokes needed to be cut or the nipples needed to be taken right off to de-tension the other side to allow the nipples to be removed using pointy nosed pliers.
    Both wheels were a big mess.
    Ti O'Beast
    Fatty
    FM190 Fatty
    Indy Fab Deluxe 29
    Pivot Vault CX
    BH G6 Roadie
  25. #250
    Reputation: 4slomo's Avatar
    I'm rebuilding a wheel set that has carbon rims (Reynolds) and internal alloy nipples (Pillar). The rear wheel nipples were corroded to nearly nothing, and I needed to use needle nose pliers to remove the nipples. The front wheel nipples are in fine condition, with no corrosion evident.
    Hey everybody, ride my wheels! They ride good, real good.
    I'm a wheel builder. SRLPE Wheel Works. Send me a PM.
Follow MTBR on Facebook
