Results 1 to 12 of 12
    Electrical Tape as Tubeless Rim Strip?
    So I had to remount a tire after having a broken spoke replaced. Forgot that I didn't have any rim strip material at home (my lbs is 15 miles away) In a pinch, I used two wraps of black electrical tape as a rim strip & I'm thinking that I'm a pretty resourceful dude. Then I get to worrying that the black tape won't hold up to the Stan's goo and will dissolve.
    Has anyone used such tape as a rim strip and has it held up? I've got a three day trip planned this weekend and don't want to deal with a tubeless failure caused by stupidity
    There are three kinds of people: those of us that are good at math and those that are not.
    I tried it once. It lasts short-term, but the 'glue' isn't as strong as whats on stans yellow tape so the latex will eventually penetrate and you get air leaking out the spoke holes.
    Giant Anthem
    Reputation: 2fst4u's Avatar
    I used some thin weather strip tape on 2 wheels works fine for 6 months! I think anything that has a good seal would work.
    Racing and Training Blog
    http://dirtandgears.blogspot.com/
    SPECIALizED
    Dec 2010
    Replace it with Gorilla tape. It'll last and is $3 a roll. If I remember correctly one roll yields 3-4 wheels.
    Oh, So Interesting!
    Reputation: davec113's Avatar
    Quote Originally Posted by UPSed View Post
    ^^^This. E-tape will not last that long....
    Cleavage Of The Tetons
    I like strapping tape.
    BOMBER.
    "We LOVE cows! They make trails for us.....
    And then we eat them."
    Reputation: lunatic fringe's Avatar
    I've had great results with Gorilla tape also.
    I'm super, thanks for asking...
    Gorilla Tape
    How wide does it need to be other than covering the holes? For example, if you have a very tight fit between tire/rim then adding a layer of tape on the bead seat shelf is going to make mounting a PITA. Is it acceptable to just fill the lower center channel between the bead seat shelves?
    Fred
    SPECIALizED
    Dec 2010
    You need a least one layer. That's what helps seal the tire to the rim. Do a search on YouTube for ghetto tubeless.
    In most cases you are probably correct, but I'm asking specifically about a tight fitting tire/rim combo. The fit is so snug that when the tire is mounted but not inflated it cannot be spun on the rim even without tape installed. I didn't attempt to spin it with only one side of the tire mounted to the rim, but I suspect it still would not spin on the rim as long as the bead were resting on the bead mount shelf and not in the recessed center channel.
    Fred
    SPECIALizED
    Dec 2010
    Well I guess another way to look at it is the bead contacting the tape will create a better seal than the tape just covering the holes. The Stans will eventually work its way under the tape.
    HA! Must remember that one for a short term solution..
  1. ZTR 355 Rim: Rim strip or tape for tubeless setup
    By BitterDave in forum Wheels and Tires
    Last Post: 06-23-2009, 09:30 PM
  2. Ghetto Tubeless with a Gorilla Tape rim strip
    By PB Matrix in forum Wheels and Tires
    Last Post: 06-28-2008, 08:08 AM
  3. Electrical Tape, Tubeless, and Stans
    By benm5678 in forum Wheels and Tires
    Last Post: 05-23-2008, 08:01 PM
  4. Tubeless - rim strip vs. tape
    By WindWalker in forum Wheels and Tires
    Last Post: 11-12-2006, 03:54 AM
  5. Electrical tape used as rim strip??
    By notenoughtime in forum Wheels and Tires
    Last Post: 08-16-2005, 01:53 PM
Members who have read this thread: 10
