Results 1 to 2 of 2
    Turn off the TV
    Reputation: SMT42's Avatar
    Nov 2006
    Easton XC ONE rear hub noise
    I get an odd grinding like sound when in the 4th cog up any one else have any issues like this.
    trail "cleaner"
    If only in one gear...
    Probably is not the wheel but either a shifting issue or a worn out drivetrain. If you spend a lot of time in that gear the cassette cog could be worn and then be amplified if you changed your chain recently.
