    Reputation: rallymaniac's Avatar
    Oct 2011
    Easton EA70 XC hub problem
    Hi all.
    I recently purchased a set of Easton EA70 XC 29er wheels.
    They are nice, true and the tension is great but the very first ride came back with a concern.
    I've put about 70miles on the wheels now and the problem is intermittent and happens every few miles. Basically, when I coast and then continue to pedal, sometimes there is a loud crackle from the rear wheel, with also the cranks skipping a bit. It only happens under fairly light load. I'm suspecting that it's the freehub not engaging right away and skipping some teeth before it engages but can't tell you that this is it for sure.
    the wheels have Easton's X2 hubs.
    Is this something to worry about? I don't want to get stuck in the woods when the hub explodes but my warranty options seem to be limited as the wheels were purchased online from what appears not to be one of the official Easton's dealers.
    Oct 2011
    anyone?
    Reputation: jjmtb1's Avatar
    Take them apart and see if anything catches your attention or to a take thm to a shop.
    Oct 2011
    Ok. so the issue is finally fixed after 2 services.
    first the LBS serviced it and got an entirely new cassette body from easton. This didn't help so month later the shop sent out the entire wheel to Easton.
    it took them 30 days to fix it but finally they rebuilt the entire rear hub with new internals and the noise is gone so far.
    I put about 50 miles on it since service and I hear no noises.
    fingers crossed or i'm selling them for something else.
