Results 1 to 3 of 3
    umm...yea
    Good job! Duct Tape: Emergency Glueless Patch
    Here's a simple tire tip:
    Tear off 2 or 3 small peices of silver duct tape and tape them to the inside of your tire (both front & rear). Apply the tape in layers to maintain the adhesive's "gumminess".
    If you are out on a ride with no spare tube, simply peel off a piece of the tape and use it as a patch. You'll be suprised how well it will stick and hold air. Works equally well on tubes and on tubless tires.
    I always keep three 1"x 1" pieces on the inside of my tires, because you never know when you might get "stranded" out on a ride........happened to me this morning. I got a flat only to find out that my spare tube had a hole too.
    Thank God for little things like duct tape!
    A wheelist
    Reputation: Mike T.'s Avatar
    I keep 3' of duct tape wrapped around my pump and around two CoČ cylinders (taped back to back) and so far it's saved three torn sidewalls - and thus three rides.
    umm...yea
    Works well as a patch for tubeless tires too.
  1. Advice with Stan no tubes sealent ?
    By Johny Rotten in forum Singlespeed
    Last Post: 02-13-2004, 03:39 PM
  2. time for lightweight rim tape....
    By danK in forum Weight Weenies
    Last Post: 01-28-2004, 07:06 PM
  3. Suggestions for WW FAQ section
    By Trevor! in forum Weight Weenies
    Last Post: 01-19-2004, 01:22 PM
