Results 1 to 6 of 6
    Reputation: cackalacky's Avatar
    DT Swiss XM 490 29er rims ??
    Anyone using these? I'm trying to decide what rim to use with some Hope Evo's for an XC hard tail build, and this one caught my eye. Was also looking at Stan's Arch.
    The DT's are a little bit heavier than Arch but also wider, have eyelets and are welded. (are Stan's welded?) I don't mind a little extra weight if it translates into durability. I'm a little skeptical about rims with no eyelets, and I'm not planning on running tubeless.
    Arch EX: 460g, 24.6mm wide (21 inside)
    XM 490: 500g, 26mm wide (Not sure of the inside width )
    Well, I found the inside width of the XM's: 19.6mm. That's too bad, I thought these would be wider.
    Doesn't look like there are a lot of choices out there for a wide, eyeletted and welded rim...
    Mar 2005
    Saw these too. Not sure why they're so narrow either, particularly the inside. Seems like a waste.
    Eyelets and being welded dont add to durability or anything at all. It truly is completely irrelevant.
    Reputation: Bike Whisperer's Avatar
    Pacenti TL28...wide, light, welded, eyeletted, tubeless
    As mentioned above Eyelets and Welded doesn't always mean better quality but the rims I mentioned meet all of your criteria.
    Mar 2005
    Pacenti's look good to me too. My only nit is I wish the 31's were not such a large weight increase over the 28's. They're 50+ grams heavier then Flow EX's but the TL28's are likely what I'll pick. Can't justify Carbon yet and I want something wide, light and strong. I don't see any other option.
