Results 1 to 7 of 7
    igz
    igz is offline
    New question here. DT Swiss X1800 <OR> Mavic Crossline???
    Hi all
    Just can't decide between the two. Crossline set is somewhat less expensive but 200-300g heavier. It's not the money anyway. I'm planning to run 2.3 - 2.35 tires and aggressive XC/AM.
    Some say Crossline internal width is too narrow for 2.35 tires. What is, then, X1800 internal width, apparently external is 24mm.
    Any other thoughts on these. I weigh 200 if that helps. Which set would be tougher?
    Please help if you have any info.
    Many thanks.
    Former Bike Wrench
    One is a XC wheelset and one is Enduro/All Mountain. The Crossline is 21mm wide internal, plenty big for 2.35" tires and the more durable wheelset.
    igz
    igz is offline
    Thanks for that. Crossline it is. I was kinda leaning towards is it. Cheers.
    igz
    igz is offline
    Just one more question. If my frame is designed for 10mm rear wheel, does that mean that I can only buy wheel that is 10mm?
    Cheers
    Former Bike Wrench
    Quote Originally Posted by igz View Post
    Cheers
    10mm is the standard rear axle size, so a QR or 10mm thru bolt will work fine. You will not be able to fit a 12mm rear axle through, though there are some "step down" axle kits to fit 12mm rear hubs into 10mm dropouts.
    igz
    igz is offline
    Thank u so very much. What about 9.5mm rear - like new Mavic Crossride? Will that be ok for 10mm dropout? Half millimeter doesn't seem to be much, just thought I'd ask.
    Those numbers are pretty annoying, where the f*** did they get 9.5mm.
    Many thanx again.
    Former Bike Wrench
    I've seen some Taiwan hubs use 9.5mm axles and they work fine, so I don't think it will be an issue.
  1. Dt Swiss X1800
    By morrisgarages in forum Weight Weenies
    Last Post: 10-17-2011, 10:20 PM
  2. DT Swiss X1800 or Mavic Crosstrail
    By jrsbike in forum Wheels and Tires
    Last Post: 03-24-2011, 01:48 PM
  3. DT Swiss X1800 or Mavic XM317 disc
    By Caeden in forum Wheels and Tires
    Last Post: 09-06-2010, 04:24 AM
  4. XT/Mavic X317 vs DT Swiss X1800
    By jasevr4 in forum Wheels and Tires
    Last Post: 05-07-2009, 01:34 AM
  5. Dt Swiss X1800
    By supersleeper in forum Wheels and Tires
    Last Post: 06-24-2008, 02:25 PM
