Results 1 to 2 of 2
    Reputation: charging_rhinos's Avatar
    DT Swiss FR600 + Hope Pro2 Evo spoke length problems/solutions
    To all those that might be thinking of building up this combo, I thought I'd post my experience with them so that you might be able to avoid wasting time and money as I had to do.
    I plugged in all the rim/hub/spoke data into DT Swiss' spoke length calculator, and it spit out the proper length spokes. 259mm, 260mm, and 261mm Comp spokes with 12mm standard alloy nipples was the result. Fantastic so far.
    Lacing went fine, but when tensioning them it became apparent very quickly that something was wrong. Almost all the spokes are running out of thread before pulling any amount of tension at all. Did I blow the data in the calculator? Both I and another person used multiple online spoke length calculators on separate occasions and we both came up with the same 259,260,261mm lengths. Dimensions of the hubs were checked, and they were spot on. Something else was amiss, but I didn't have a large enough set of calipers to accurately measure something like ERD.
    After having a friend who has worked in the industry and built hundreds of wheels for racing teams look at it, he determined that a set of 258mm spokes all around would work well. So I ordered a full box of 258mm DT Comps. They worked perfectly! 258mm for all sides, front and rear, gave the proper dish, proper spoke thread engagement, and all pulled to the specified tension.
    So anyone looking to build up an FR600 + Hope 32h wheelset, take heed!! 258mm all around worked well with the standard 3-cross lacing and standard 12mm alloy nipple length. I hope this will help someone out there avoid making the same blunders I made.
    tangaroo: What electrolytes do chicken and turkey have again?
    rck18: All of them, because they're meat.
    Reputation: 4slomo's Avatar
    Did you use your own measurements of the rim ERD and the hub dimensions for the spoke calculator data?
    Hey everybody, ride my wheels! They ride good, real good.
    I'm a wheel builder. SRLPE Wheel Works. Send me a PM.
  1. spoke length for Hope EVO 142
    By skyboss in forum Wheels and Tires
    Last Post: 07-10-2015, 07:53 AM
  2. DT Swiss FR600 rims, Hope Pro2 Evo hubs, and screwy spoke lengths
    By charging_rhinos in forum Downhill - Freeride
    Last Post: 07-27-2013, 07:46 AM
  3. Spoke length for DT Swiss E540
    By Ripn6 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-09-2013, 07:52 PM
  4. I9 rim vs DT Swiss 5.1 spoke length
    Last Post: 08-17-2012, 11:09 AM
  5. Spoke Lengths Velocity P35s and Hope Pro2 hubs...
    By vikb in forum Wheels and Tires
    Last Post: 06-16-2012, 07:18 PM
