Results 1 to 3 of 3
    Reputation: lukey's Avatar
    DT Swiss 440 / Hugi FR front hub bearing life?
    I'm running this hub with a 20mm through-axle.
    Kind of expected bulletproof performance, but I'm suddenly on my 3rd set of brand-new bearings in under 6 months. Oddly, brand new bearings seem to go only about 5 rides before a tiny bit play develops. The free play doesn't progress too quickly from there, but it's there.
    I've got good fit with the axle end-caps and through axle. The play is definitely coming out of the bearings.
    All three times, the play seems to develop on the disc-brake-side bearing first. The fork itself has been replaced, and the second set of bearings went quickly on a brand new fork with a carefully set up brake.
    Wondering if I'm just running into a batch of bad bearings, or if anyone else has experienced low bearing life with this model of hub?
    Any other experiences?
    Nov 2006
    surprising. this hub is supposed to be bullet proof.
    Have had a set of these hubs quite a while, still on their original bearings!
    Saying that, you probably ride more than I do, especially as these aren't on my main bike, but even still I'd definitely recommend them to anyone. By contrast, I've had hub bearings last only a dozen rides or so myself, and my DT's have done lots more than that and are still as smooth as the day they left the factory.
  1. DT Swiss Hugi 240 front hub Vs. 240s hub?
    By rc51kid in forum Wheels and Tires
    Last Post: 04-05-2011, 11:25 AM
  2. Difference between Hugi and DT swiss?
    By climbingbubba in forum Wheels and Tires
    Last Post: 01-07-2010, 08:13 PM
  3. Dt Swiss/Hugi Front Hub
    By Pisgah in forum Wheels and Tires
    Last Post: 11-11-2009, 11:06 PM
  4. DT Swiss/Hugi hub problem?
    By Voodoosix in forum Wheels and Tires
    Last Post: 12-22-2008, 02:04 AM
  5. Does anyone have a DT Swiss Hugi 440 FR?
    By Bobby Peru in forum Downhill - Freeride
    Last Post: 10-22-2005, 08:11 PM
