Results 1 to 3 of 3
    dt swiss 340 xc wheel set
    Hi to all,
    I have a 2008 Rockhopper disc and just bent the rear rim to the point where it will not true. I can get a dt swiss 340 xc rear wheel at the LBS. Is this an up grade from the stock Alexis rim that is on the bike? Just looking for info. Thanks.
    This would be an upgrade. The 340 hubs are solid performers and quite reliable using DTs star ratchet freehub mechanism. How much for the 1 wheel at the LBS?
    There are some available in the classifieds.
    http://classifieds.mtbr.com/showprod...t=36693&cat=10
    The rear wheel set is going to be $120.00 installed. That is in Canadian dollars. It seems like a pretty good deal from what i am checking out?
