Results 1 to 11 of 11
    DT Swiss 240 / Hugi 240 -- 20 mm?
    In the history of these hubs...what models ever came in 20mm (front, obviously) options?
    Twin Six METAL Team
    Reputation: chrisgardner73's Avatar
    Not sure exactly what you're asking, but the current 240s hubs are available in a 20mm. That's what I am using on my R.I.P. 9.
    Didn't they make a non-s 240 a few years ago? And back when it was the Hugi 240, did either of these come 20mm?
    Twin Six METAL Team
    Ah OK, gotcha! That, I'm not sure of off the top of my head. I took a look on BikePedia, and I didn't see one listed. However, that site's not always the be-all, end-all of info though...
    Chris
    I Tried Them ALL... Moderator
    Reputation: Zachariah's Avatar
    Can the 2005 Magura Pro disc hub(DT 240) front run a 15 or 20mm thru-axle, with newer 240s end caps?
    "The mind will quit....well before the body does"
    The larger 240s oversize can be 20MM the rest of the 240 line cannot be ,they can be 9mm quick release,9mm thru axle or 15mm thru axle.
    Quote Originally Posted by wizardB View Post
    Where and how can I do this?(15mm)...
    Reputation: DJ Giggity's Avatar
    Quote Originally Posted by Zachariah View Post
    You just need end caps. Any shop can order them. DT has a US based service center but I am not sure if they will sell direct or not.
    Only two infinite things exist: the universe and stupidity. And, I am unsure of the universe
    - Albert Einstein
    Reputation: shiggy's Avatar
    Dec 1998
    Considering that 15mm forks and hubs did not exist until late 2008, no, your hub was not designed to be converted to 15mm TA.
    mtbtires.com
    Reputation: flyxaos's Avatar
    There is a kit you can find on ebay and youtube that will convert a standard 240s into 15mm. Not 20 though.
    Quote Originally Posted by shiggy View Post
    Thx. That is what I was wanting to know...
  1. Dt swiss....HELP!
    By cabbgage in forum 29er Bikes
    Last Post: 01-12-2012, 04:35 AM
