    Reputation: pressed001's Avatar
    Jan 2014
    DT Swiss 190 freehub bearing swap? Campy-->Shimano
    Hey I just bought a great custom made wheelset with 190 hubs. Only problem is the freehub body is campy splined. I want to buy a cheap used shimano splined freehub body and then purchase/install the hybrid ceramic bearings separately. Mainly because a new 190 freehub body costs $350.
    Anyone know if I can simply swap the bearings that are currently in my campy body into the empty shimano splined body? Or is that worthless, even after using a proper bearing puller/press?
    Jul 2003
    Shouldn't be a problem. The only thing "Campy" about the DT Campy freehub body is the spline configuration. From what I recall the bearings are the same.
    Good Dirt
    Jan 2014
    Good dirt indeed. Thanks! I will post results after swap.
    Jan 2014
    Well I didn't end up swapping the bearings. I found a used shimano freehub body with ceramics for a good price. anyone need a campy 190 freehub body?
  1. 1x10 using Shimano and Campy
    By Carver96er in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-12-2013, 03:35 PM
  2. shimano x campy. good stuff>Durango worlds> Furtado & Yeti.
    By colker1 in forum Vintage, Retro, Classic
    Last Post: 09-09-2012, 11:25 AM
  3. Shimano CX70 Fr. Der. - compatible w/ Campy Ergo
    By Erik_A in forum Cyclocross
    Last Post: 07-07-2012, 10:37 AM
  4. Fulcrum power 29 sl wheels with a campy freehub
    By pulser in forum Wheels and Tires
    Last Post: 11-23-2011, 05:28 PM
  5. Replies: 2
    Last Post: 06-25-2011, 08:54 AM
