Results 1 to 6 of 6
    DT 240 Conversion Question: 1x11 freehub to 11 speed road 142x12
    I haven't been able to talk to DT Swiss directly about this yet. I've got a DT Swiss 240 rear hub on a wheel set up for 1x11 but I need to set it up for 11 speed road with 142x12. Tell me if the following plan will work:
    1- Replace the free hub body with this 11sp road free hub:
    DT Swiss 240 Freehub Body Shimano 11 Speed
    Now, I've got a 135mm hub.
    2- Then I should be able to replace the end-caps:
    DT Swiss 240s 135 to 142 Conversion End Caps Only - Modern Bike
    This should work, right?
    Mar 2015
    I just found your question from several months ago and I now have the same question. Did you ever find a solution?
    Jan 2014
    DT Swiss now makes a road specific 240S hub, 12 x 142 with 11-speed road freehub:
    DT Swiss - 240s straightpull db
    Hope this helps!
    Reputation: bigdrunk's Avatar
    it is simply a matter of choosing the correct end caps for the spacing and axel size + proper free hub body.
    DT 240's are ultra flexible. I am doing a similar conversion with a set of my wheels and am going to order the same free hub body in the link above for an Ultegra 11sp build
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    Quote Originally Posted by russmcb View Post
    Yes, this works fine.
    Mar 2005
    Quote Originally Posted by mikesee View Post
    But the end cap pictured with the 11 speed free hub is for a qr, not thru axle, and says ''11 speed'' on it. Does the regular 142x12 end cap work will 11 speed, or is there a special 142x12 11 speed end cap that's needed?
    thanks
    DT 240 Conversion Question: 1x11 freehub to 11 speed road 142x12-rs.php-path%3Ddts24fhbs11-1.jpg
  1. Shimano 1x11 conversion question
    By Eric Marshall in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-30-2014, 06:05 AM
  2. 1x9 or 1x11 conversion questions
    By Riding In Israel in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-25-2014, 09:46 AM
  3. 142X12 conversion kit
    By Paris Galanis in forum Trek
    Last Post: 09-08-2013, 03:59 PM
  4. Replies: 4
    Last Post: 02-12-2013, 03:58 PM
  5. 8 speed to 9 speed conversion question
    By GiantClyde01 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-16-2012, 07:28 PM
