Results 1 to 5 of 5
    Does Mavic Crossride Disc work with Sram 11-36 casettes?
    Want to be sure before ordering
    What bolts do I need to get for installing the 6-bolt disc brakes for those wheels?
    Can anyone confirm?
    Reputation: kingbozo's Avatar
    As far as I know all of the "new" cassettes use the same size standards so no special hub is required. Those wheels should not cause a problem.
    If you have six bolt rotors make sure you are getting six bolt hubs and not centerlock. If you end up with centerlock hubs there are adapters available to use six bolt rotors.
    Most rotors come with the bolts. If you are swapping existing rotors on the new wheelset, just reuse the bolts (use some Blue LocTite on the threads)
    The discs are mounted now on DT Swiss X1600 wheels. The wheels are centerlock and the discs are 6-bolt and they are mounted with adapter. I don't see any bolts anywhere:
    http://i.imgur.com/afrpl.jpg
    http://i.imgur.com/Oxybj.jpg
    Reputation: in the trees's Avatar
    Mar 2005
    The cassette should work fine.
    You will need some rotor bolts, however. Remove the DT Swiss adapter and use the just the rotors on your new wheels with rotor bolts. Your LBS should have them if you don't.
