Results 1 to 10 of 10
    Professional Crastinator
    Reputation: Fleas's Avatar
    Does [Too] High Spoke Tension Lead to Catastrophic Failure?
    I would like confirmation/dismissal of my anecdotal evidence that an over-tensioned bicycle wheel is more likely to collapse ("implode"). That is, under excessive tension, if the wheel is impacted such that it is deflected beyond whatever balance point provided by spoke tension ("kick over" if you will), that it will collapse rather than rebound. Whereas a wheel under normal tension is more resilient and will snap back into shape, at least approximately, without failing entirely.
    Thanks,
    -F
    It's never easier - you just go faster.
    Reputation: Lupob6's Avatar
    RE: Does [Too] High Spoke Tension Lead to Catastrophic Failure?
    I'm curious of the same thing
    Sent from my RM-860_nam_usa_100 using Board Express
    transmitter~receiver
    Reputation: meltingfeather's Avatar
    Confirmed
    Quote Originally Posted by pvd
    Time to stop believing the hype and start doing some science.
    29er Tire Weight Database
    Quote Originally Posted by meltingfeather View Post
    Confirmed
    Good enough for me.
    /thread
    -F
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by Fleas View Post
    Good enough for me.
    /thread
    -F
    Of course. If a wheel fails because the tension was too high, then the tension was excessive.
    mtbtires.com
    Yes it's hard to do but if you keep tightning a wheel during a build it will potato chip. There is no permanent damage at this point just back off the tension. I think this is a buckling failure 32 spokes times 200 pounds is 6400 pounds compression force in the rim at right angles to the spokes. A small amount of force added to this will put a permanent bend in the rim.
    "Dish is illogical." Spoke of Vulcan.
    Yes, definitely
    Quote Originally Posted by shiggy View Post
    Yeah, but...
    At the time that it fails, one doesn't actually know that it was over-tensioned. One just ponders back to the time when someone was tweaking on it and whether said tweaking was contributory or merely coincidental. So we try to determine: is it the cause or the symptom.
    It's always in hindsight that we discover these things.
    Thanks everybody. Confirmation is fairly conclusive.
    -F
    I put it to the test and built a new wheel using mobile 1 transmission oil and high pressure oil additive on the nipples. It also buckled while building and I backed off the tension a half turn. The wheel failed when I hit an oil slick causing the wheel to go sideways into a 2 inch bump ion a curb ramp. The wheel was more buckled than the wheel caused by a hit and run driver hitting my rear pannier. There was not much difference in the wheels other than the tension. https://www.flickr.com/photos/633739.../in/photolist-
    Quote Originally Posted by zerodish View Post
    Wheels aren't designed to withstand the lateral loads from a sideways slide. It's not possible to compare the failure due to an oil slide and a car hit and say the results were due to spoke tension.
    I've found it impossible to buckle a 26" rim during building. I took the lightest rim I had (a ZTR Olympic) and kept tightening it with the intention of destroying it. The tension went off the scale on my DT Tensiometer at over 1900N and by then spoke stretch was the issue.
  1. Catastrophic Failure DT Swiss 36 point Hub
    By flyag1 in forum 29er Bikes
    Last Post: 06-03-2014, 12:41 PM
  2. Catastrophic failure Niner Carbon Fork
    By CupOfJava in forum 29er Components
    Last Post: 06-28-2012, 06:15 PM
  3. Sudden catastrophic failure PARANOIA
    By bloodpuddle in forum General Discussion
    Last Post: 01-31-2012, 01:32 AM
  4. Catastrophic failure of seatpost clamp!!!
    By miwuksurfer in forum General Discussion
    Last Post: 10-19-2011, 07:39 AM
  5. Scott Ransom Catastrophic Failure.........
    By JeffSkisMontana in forum Scott Sports
    Last Post: 10-02-2011, 07:23 PM
