Results 1 to 13 of 13
    29er for the Soul
    Reputation: teachndad's Avatar
    Differences between Shimano SLX hubs M665, M675, M678
    HI,
    I had narrowed down my search for a new hub to a Shimano SLX M665 hub, but came across the M675 and the M678.
    Can anyone note the basic rideable differences and technical diffs in the hubs, and even share quality issues if known.
    I do know that the M665 has 32 POE and that the M675 and the M665 are supposed to have 10 mm threaded axles.
    So Cal Rod
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by teachndad View Post
    HI,
    So Cal Rod
    The 678 is a 142/12 through axle hub
    mtbtires.com
    Reputation: VuDoo11's Avatar
    May 2012
    The 665 model is the standard quick release. The others are the 15 and 20mm axles. I can't say much about any quality issues between the hubs, but the axles will provide a digger and stronger front end. If you are wanting to purchase the 665 slx i have a set of these I'm trying to sell on Craig's list as well as the center lock rotors. Everything is brand new and still in the box.
    Dec 1998
    Quote Originally Posted by VuDoo11 View Post
    15 (678) and 20mm (667) axles are front hubs only.
    The 665 and 675 rear hubs are both 10mm QR
    Front 675 is 9mm QR
    mtbtires.com
    29er for the Soul
    Quote Originally Posted by shiggy View Post
    Front 675 is 9mm QR
    Okay, this helps a lot!
    What is the difference between the M665 and M675 rear hubs? Shiggy and Vudoo seem to have different info for these two hubs. Are they both 10mm or is one 10 and the other 12? The diffs with the other hubs have been answered for me.
    Sorry, just looking for clarification.
    thanks again.
    SoCal Rod
    Dec 1998
    thanks again.
    SoCal Rod
    VuDoo missed that you were asking about the rear hubs. My info is correct.
    The 665 and 675 the same design and part numbers. The 675 is just part of the 10-sp group.
    Shimano
    mtbtires.com
    29er for the Soul
    Shimano
    Excellent!
    Thank you,
    So Cal Rod
    Dec 2010
    I'm also considering some SLX hubs for a build I'm doing this winter and am debating between the M665's and the M675's. I can get the M665's for a cheaper price because they are on closeout, should I go for them? Aren't they basically the same thing as the newer models? I'll be running 10 speed, which will be fine on either hub, right?
    Dec 1998
    Quote Originally Posted by sasquatch rides a SS View Post
    Well, I think this still applies:
    Quote Originally Posted by shiggy-in this very thread
    Shimano
    mtbtires.com
    Reputation: 006_007's Avatar
    Yes you will be able to run a 10sp cassette on either hub.
    Dec 2010
    Thanks 006_007, major brain fart. Like when you add 2+2 in your head and still feel the need to double check with a calculator to make sure it is 4.
    Nov 2012
    Hey VuDoo11, do you still have those SLX hubs and rotors you mentioned awhile back?
    May 2012
    Yep... Still have them sitting in my closet.
