Results 1 to 5 of 5
    D93
    D93 is offline
    Oct 2011
    Difference between Specialized Purgatory Control and Purgatory Armadillo?
    I can't seem to find any detail on the website, both have the same description. Is the tread pattern and performance the same for both?
    Former Bike Wrench
    Same tread pattern and dual density knobs, the Armadillo adds a flat protection wrap (bead to bead) and a belt (under the tread). This will add a little weight and reduce the casing suppleness but increase flat prevention. Both are 2Bliss Ready as well.
    D93
    D93 is offline
    Oct 2011
    Would the differences between them affect cornering in the loose gravelly over hardback stuff?
    I can't find a Purgatory Control anywhere but the Armadillo is fairly available.
    Quote Originally Posted by D93 View Post
    Not on that. The extra protection makes the tire less supple. So, those small rocks at slower speeds can be felt a bit more.
    You get a little weight penalty too, but only 40-50 gr IIRC.
    Lead by my Lefty............... right down the trail, no brakes.
    I'm with stupid
    Reputation: hitechredneck's Avatar
    For the conditions you mentioned I didn't like that tire at all it was very drifty feeling. Take a peak at the eskar for that type of trail.
    I tapped that
  1. Replies: 38
    Last Post: 02-22-2014, 03:57 PM
  2. Specialized Purgatory?
    By ProjectDan35 in forum Wheels and Tires
    Last Post: 09-07-2011, 12:20 PM
  3. Specialized Purgatory
    By ts818 in forum Wheels and Tires
    Last Post: 08-01-2011, 05:42 AM
  4. Tire Question - Purgatory Control 2.4 Front & Back?
    By jjpowell76 in forum All Mountain
    Last Post: 08-27-2010, 08:47 AM
  5. Specialized Purgatory
    By robinta in forum Wheels and Tires
    Last Post: 02-06-2009, 02:29 AM
