Results 1 to 8 of 8
    May 2013
    Difference between shwalbe ORC and DC compounds?
    I ordered a set of nobby nics from chain reaction and when they got here I noticed that the tires were slightly different, one of them has the DC compound and one has ORC compound.
    The boxes were also slightly different and the manufacture numbers were different by a ".01" added to the end of one of them.
    I couldn't find any info on schwalbe's website, does anyone on here by any chance know what the difference between these tires is?
    Thanks, Chris.
    Reputation: MSU Alum's Avatar
    I don't know what ORC is...DC = Dual compound? Man, these guys are out of control, TL or no TL, Evo Vs Performance line, Pacestar, Trailstar, Vertstar compounds, Snakeskin or no snakeskin... in Black, graphite, white stripes. I have a headache!
    May 2013
    The tire says "offroad racing compound" on it but that doesn't help me know what/if the difference is.
    Are they in the Evo line or the Performance line? The Evo line is their premium line. If it's in the Performance line it's a lower tier tire. It may be that these are OEM tires, also. I know, TMFA!
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by hardup View Post
    Thanks, Chris.
    ORC is a basic compound, longer wear, decent grip. Single compound. Generally used on the Performance line tires with different casings.
    Looks like all current Performance NNs are dual compound. No single compound offered
    There have been 3-4 different Nobby Nic treads over the years. Schwalbe does use tread design ID numbers, which are molded on the sidewall. Current design is HS 411.
    http://www.schwalbetires.com/bike_ti...obby_nic_hs411
    mtbtires.com
    May 2013
    I ordered the performance line and they are both HS 411. The DC tires art.No is 11600097.01 and the ORC is 11600097. They were the cheapest folding nobby nics available from chain reaction at $33 a tire, but I'm still unsure why they sent me two different tires.
    Would the ORC be similar to the harder compound in the center of the DC tires?
    May 2013
    I decided that the orc ones must be an older version, thus the additional .01 in the product number of the dc tires which usually indicates a revision.
    This shouldn't matter to me as much as it does, but if I put the tires on every time I see the mismatched writing on the sidewalls it will drive me crazy. I sent CRC an email to see what they can so about this, hopefully they can fix it and the process isn't too painful.
    I'll keep anyone watching this updated.
    COMPOUNDS
    Allround: The Marathon Compound. It achieves everything expected of a Marathon tire: High durability, low rolling resistance and excellent wet grip.
    Black'n Roll: Special rubber compound for wheelchairs. Leaves no unsightly marks on indoor floors and lasts much longer than a normal grey wheelchair tire compound.
    Dual Compound: Two different rubber compounds for optimal performance: The center tread is friction resistant for longer life. The sides are a soft Silica mixture for maximum adhesion (STELVIO).
    Endurance: Compound extremely resistant to friction for maximum mileage (MARATHON XR).
    Energizer: Extremely grippy rolling compound for E-Bikes.
    Gooey Gluey: Extremely soft compound for ultimate control on both hard and loose surfaces (e.g. BIG BETTY)
    GRC: Grey compound for wheelchair tires.
    ORC = Offroad-Racing-Compound: Special rubber mixture for area application on offroad tires.
    Roller: Special rubber mixture for roller use. Indoors only!
    Qualifier Compound: Special rubber mixture, developed specifically for low rolling resistance.
    Magic: Our latest rubber compound. For us it is magic, because it combines outstanding wet grip with very good rolling characteristics. Magic Compound is the ultimate on wet, slippery roads.
    SBC: SCHWALBE Basic Compound: Versatile quality compound for all applications.
    Silica: Special filler in the rubber mixture that positively influences the rolling resistance.
    Speedgrip: Multilevel Dual Compound (SUPER MOTO)
    T45: Special compound for tubular tires (e.g. Montello).
    Triple Compound: Three different rubber mixtures in one tire for the best possible performance (e.g. Ultremo).
    Triple Star Compound: Our best and most sophisticated compound. Triple compound. Perfectly adapted to the specific purpose. MTB (GateStar, PaceStar, TrailStar, VertStar), Roadrace (RaceStar, WetStar), Tour (RoadStar, TravelStar).
    Winter: Special compound for spike tires.
  1. Deity Compounds
    By kubo in forum Downhill - Freeride
    Last Post: 03-04-2015, 06:07 AM
  2. Has anyone tried the Schwalbe Performance compounds
    By cesalec in forum Wheels and Tires
    Last Post: 09-13-2012, 10:11 PM
  3. Lighter alternative to Shwalbe Rocket Ron UST
    By Vasiliyg in forum Wheels and Tires
    Last Post: 07-12-2012, 04:41 AM
  4. Schwalbe compounds vs Maxxis compounds
    By ban in forum Wheels and Tires
    Last Post: 10-17-2011, 02:01 PM
  5. Shwalbe Tires on ZTR Stan Wheels
    By k^2 in forum Wheels and Tires
    Last Post: 04-12-2011, 03:17 PM
