Results 1 to 9 of 9
    Freshly Fujified
    Reputation: Call_me_Clyde's Avatar
    New question here. Is this dangerous?
    This is from a set of NOS Pana Trailblazers I just took off a wheelset. Not sure how I did this, but I need to know if this now makes the ire structurally unsound before I sell it. I don't want to sell someone a potential catastrophic failure.
    Thanks in advance for your thoughts.
    Bob
    'If Wal-Mart sold parachutes, who would jump?' Frank Havnoonian (quoting his father) Drexel Hill Cyclery
    Reputation: shiggy's Avatar
    Dec 1998
    If it is just the rubber lip and does not expose the bead cords/wires it is fine.
    mtbtires.com
    Freshly Fujified
    Quote Originally Posted by shiggy
    I'm pretty sure it's OK. I'll double check.
    Bob
    Reputation: EDDIE JONES's Avatar
    Mar 2005
    I did the same thing on some Kenda Kinetics a couple of years ago and those tires are still being ridden by a buddy of mine with no ill effects
    Former Bike Wrench
    Its below the bead...should be fine
    Freshly Fujified
    Bonking ... not feelin' well Bead is exposed
    As I run my finger along the area in question I can definitely feel a spot about 2cm long were I feel the distinct feel of a wire bead, much like a brake or shifter cable. Is there anything I can use to seal up this exposed are, or should I just write off the tire?
    Thanks again.
    Bob
    Spanish rider
    Reputation: Pableras's Avatar
    Most of my tires have their beads like that and I've never had a proble; the missing "rubber" is just a "burr", which is usually torn by the tire levers when you remove the tire
    A pessimist is an experienced optimist
    Dec 1998
    Quote Originally Posted by Call_me_Clyde
    Thanks again.
    Bob
    Do you still see casing fabric over it?
    If so, use it.
    If not trash it. It is a blowout waiting to happen.
    mtbtires.com
    It looks OK. I know my tire levers have chewed on their fair share of tires. With that said, it if is bothering you- TRASH IT! New tire= piece of mind!!!
