Results 1 to 8 of 8
    On MTBR hiatus :(
    CX-Rays vs. DT Aero Speed...
    Building up a new 26" wheelset and ran into a little snag.
    I want to go with CX-Rays, but with a spoke length requirement of 238mm on my rear wheel, I'm 10mm shy of Sapim's shortest length (248mm).
    How do the DT Aero Speed spokes stack up? Better yet, where do I find them in a 238mm length in black? (They're supposed to go all the way down to a 215mm length, but I don't see them in QBP in that length.)
    The bigger question: Am I best off mixing and matching, running CX-Rays on my front wheel (where they will fit) and Aero Speeds on the rear?
    FWIW, the Speedhub has a 100mm flange with symmetric 30mm offsets, and makes a stable, even tensioned base to build a rear wheel around, but due to the large diameter requires only a 2x lacing pattern which shortens up my spoke length requirement.
    Thanks for any input!
    Reputation: divve's Avatar
    May 2002
    CX-Rays are available in standard sizes all the way down to 182 mm.
    sadly, like the element
    Sep 2004
    Er, I think you want to be looking at the DT Aerolites.
    On MTBR hiatus :(
    Quote Originally Posted by Leadghost
    Why??
    Sep 2004
    They're the more direct competitors to the CX-Rays. My current disk wheels are built up with them and the weight is right around what the CX-Rays would be at with the same build, durable so far as well.
    According to DT's website, the Aerospeeds are heavier than the super comps (a standard disk wheel spoke, super strong too).
    DT aero speed -
    Weight(64pcs/264mm) 355 g
    DT super comp -
    Weight(64pcs/264mm) 318 g
    DT aerolite -
    Weight(64pcs/264mm) 278 g
    On MTBR hiatus :(
    Can I get them in a 238?
    On MTBR hiatus :(
    Quote Originally Posted by divve
    Do you know who else lists them on their website? I can only find reference to the longer lengths.
    May 2002
    If you're in the US contact www.thorusa.com. They should be able to point you in the right direction.
    Otherwise in Europe:
    http://www.brennaborshop.de/auja/index.php
    According to their info they have them in stock down to 226 mm.
  1. CX Rays - how to use tensiometer???
    By Circlip in forum Wheels and Tires
    Last Post: 02-14-2006, 01:22 PM
  2. Everything you need to know about the PIKE's Motion Control Damping!
    By MicroHuck in forum Shocks and Suspension
    Last Post: 02-21-2005, 10:25 AM
  3. Questions for you homers
    By Steve from JH in forum Turner
    Last Post: 02-13-2005, 02:18 PM
  4. Very Old Shimano 7 speed replacement
    By NFields in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-27-2004, 04:30 PM
  5. DT Aerolites or Sapim CX rays
    By eurorider in forum Where are the Best Deals?
    Last Post: 04-02-2004, 03:35 PM
