Page 2 of 2 FirstFirst 12
Results 101 to 106 of 106
  1. #101
    Quote Originally Posted by mjw View Post
    They can't give you instruction on how to do so?
    Sometimes a helpful forum thread and fellow bike enthusiasts is far quicker than waiting to hear back from a warranty department.
  2. #102
    Jun 2013
    Quote Originally Posted by BluePitch View Post
    Okay, I have only worked on the left type. It looks like a stronger design anyway.
  3. #103
    Still Stinky
    Reputation: stinkydogfart's Avatar
    Mar 2018
    I was able to pry it out. I put a little pick under the edge of the engagement ring and pried it up a bit, then moved to the opposite side and did the same thing. slowly it wiggled out. I switched to a flathead screwdriver as soon as it was possible. It came out with relative ease. Pressing in the new one, I used a large socket and a small hammer.
    Hope this helps.
  4. #104
    Still Stinky
    Mar 2018
    Quote Originally Posted by MudSnow View Post
    If it is the screwed in type, you use a 27 point star socket that fits into the teeth, then unscrew it out counter-clockwise.
    But if it is broken like that, you can just take it out in pieces.
    Novatec has a specific tool that fits neatly into the serrated teeth. It can be used to install and remove the threaded engagement rings.
  5. #105
    Quote Originally Posted by stinkydogfart View Post
    Hope this helps.
    Good to know thanks!
  6. #106
    Hope this helps.
    What a pain to pry that thing out!
  1. Novatec Hubs any good?
    By Jason Boi in forum Wheels and Tires
    Last Post: 07-12-2017, 10:32 AM
  2. Any experience with Novatec Hubs D711SB / D712SB?
    By CrozCountry in forum Wheels and Tires
    Last Post: 03-27-2015, 08:53 PM
  3. Novatec 4 in 1 Hubs?
    By NH Mtbiker in forum Wheels and Tires
    Last Post: 01-17-2012, 11:19 PM
  4. Any experience with Novatec hubs?
    By Haystack Calhoun in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-04-2011, 07:50 PM
Members who have read this thread: 342
