    2OFME
    Crossmax SL and Bontrager TLR tires?
    How well do the new bontrager tires work tubeless with a Mavic Crossmax SL wheelset? I'm looking at the XR2 or XR3 specifically.
    I know I need sealant. Do I need the rim strip or just tire and sealant?
    I've read a few vague references to the TLR tires not playing well with UST rims. Is my other option Specialized 2Bliss?
    I tried searching, couldn't find any definitive answers to the Bontrager with UST rims. Obviously I could go straight up UST tire, but as many have pointed out, the weight penalty is a little high.
    Thanks,
    -Pete
    Most tires work just fine .... if they have a sufficiently strong bead.....Since the tire is TLR it should be fine...
    I have used Mavic UST rims but not that specific tire.
    I run a Maxxis Ignitor non-tubeless tire...tubeless jsut fine.
    Former Bike Wrench
    No rim strip needed, the TLR and 2Bliss tires should work just fine on Mavic UST rims.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by onrhodes View Post
    Thanks,
    -Pete
    Bonty TLR tires are UST compatible. Mount as you would any UST tire. I have used them on Mavic UST rims with no issues.
    mtbtires.com
