Convert Rear Maxle To Bolt-Thru
Is there an axle available to convert a 142mm QR Maxle to a regular bolt-thru axle? Just looking to ditch the QR aspect on the rear of my frame.
Drill out the drive side threads with a 12mm drill... Possibly not a good idea, but that'd be the way to convert a threaded frame to a thru bolt frame.
If you could put the rear triangle in a good drill press or milling machine it probably wouldnt be a terrible idea. Doing it with a handheld drill would be a bad idea...
Once you're done can you find a 142x12 axle that is the right width for the frame. Also is the outside of the driveside where the through bolt nuts will not sit an appropriately flat/clear area? can it withstand the clamping forces?
By Frankie Figs in forum Shocks and Suspension
Last Post: 08-06-2013, 11:20 AM
By schlim in forum Wheels and Tires
Last Post: 05-02-2012, 12:08 AM
By joehspicer@msn.com in forum Shocks and Suspension
Last Post: 04-29-2012, 05:19 AM
By Green Giant in forum Wheels and Tires
Last Post: 02-11-2012, 10:40 AM
By connolm in forum Wheels and Tires
Last Post: 12-05-2011, 10:08 AM
- You may not post replies
- You may not edit your posts
Forum Rules
