Results 1 to 36 of 36
    Continental Baron 2.3 Review
    I haven't seen too many reviews on these, so I thought I would give my thoughts to the community. Bottom Line: This is the best performing winter conditions tire for the PNW that I have come across yet.
    Setup: I got this tire from my brother in law for Christmas to go on my Ibis Mojo HD. I'm currently using a Mountain King II Protection 2.2 in the rear, but have used many others in the past. I mounted the tire w/ stans on my Easton Havocs (new style UST rims) with an air compressor. Being a continental and not being designed for tubeless, the tire was a typical pain to seat and seal up. But they are holding air very well now and I run them from about 25 psi to 32 psi.
    Trail Conditions: Anyone that lives on the wet side of the mountains in the PNW knows that our winter conditions are generally very wet and greasy. We don't get much in the way of deep peanut buttery mud that would benefit from a narrow mud specific tire. Its more that we have lots of wet leaves and an inch of greasy mud on top of good hard pack and slippery roots.
    Impressions: I have been on the lookout for an ideal winter tire for quite a while. I thought these looked interesting when I read the review of them on bikeradar. Well, in person, I can say that this is exactly what I was looking for for trail riding from November to March when I have the most problems with my minions. The grip on these things is truly amazing and I have not had them slip once on a number of fast tight twisty descents. In fact, the tire is so much grippier than the MKII that I need to find something better for the rear because the disparity between the two tires is too great. They also never pack up with mud at all even when it is at its stickiest. The only real downside so far is that they are quite slow on hardpack/pavement. Not nevegal slow, but noticeable nonetheless. But, that's the price you pay for so much confidence in the conditions where they shine.
    Bottom Line: If you ride in wet greasy wintery conditions, but don't have a lot of deep mud, I would highly recommend this as a front tire. It's the best that I have tried among Nevegals, Minions, High Rollers, Mountain Kings (I and II), WeirWolfs, Purgatory, Trail Kings, etc.
    Bicyclochondriac.
    Thanks for the review. I have wondered about these.
    Reputation: shapirus's Avatar
    Any info regarding actual size and weight? Photos, etc.
    Quote Originally Posted by shapirus View Post
    Don't have a scale or calipers. Comparing sizes, I would say they are pretty comparable to other 2.3s. They're slightly smaller than my 2.4 Mutanos and 2.5 minion--actually pretty close to a 2.2 Trail King. They do have a wider tread compared to the casing than other Conti tires that I have used.
    thorkild - any thoughts on a good rear match to the Baron?
    I have been riding the Baron front for the last 6 months and in the last 2 I adopted it on the back too. I love them!
    I ride in the UK usually in wet rocky terrain (with a little lit of mud too), weight 225lbs all geared up and use 30psi f and 35psi r. I use them on a Titus El Guapo and am very happy with their performance. They are tough and very grippy going uphill or dh. Not exactly the best rolling resistance but I don't mind as I am not in a hurry to get to the top.
    Would certainly recommend them as general winter tyres!
    Quote Originally Posted by seleniak View Post
    Still working on one. Trail king is not a bad choice. I definitely would not recommend the mountain king II (good tire, just doesn't pair well for wet). I'm interested in the 2.3 spec ground control, and maybe a muddy Mary, but I haven't tried either yet. Maybe another baron would work nice.
    Quote Originally Posted by thorkild View Post
    what's bad about it in the wet?
    earide
    Is that the "cheap" version of 2.3 Der baron you're using? wire version?
    ok I'm doing some pretty dirty freeriding and DH, and I'm running all my tires in tubeless.
    Can you confirm that this 2.3 Baron has strong sidewalls and casing to fit these as rear ghetto tubeless tire?
    thanks for the review
    Mr. Knowitall
    Reputation: hssp's Avatar
    Quote Originally Posted by ehrhard View Post
    It is the single ply, lightweight version of Der Baron. Mine are folding, black chili and so far I like them for fall riding in Norway. Would be normal Conti hassle to set up tubeless, but I haven't tried mine yet (running 2,35 Ice Spiker Pros for the moment )
    This is the lighter version of the Der Baron and unfortunately is not any cheaper. As for hssp I am also using the Black Chili foldable version and I paid 45 ($68). I am using it ghetto on a Mavic 521 and so far so good, but I will keep it only on the rear wheel for a while till I trust it enough to use it on the front too. It is a very porous carcass and it took me 3 days to seal it, quite hard work.
    The tyre is not light weight for AM (850g) and in spite of being very robust with a solid feel, it should not be as robust as the heavier DH version Der Baron (1200g).
    Continental Bicycle -Baron 2.3
    It's actually a pretty good wet conditions tire. It just doesn't pair with the baron well at all due to a significant disparity in grip. The baron has a tremendous amount of wet/loose cornering grip, while th mkII is average. So, when you really push the baron up front, you tend to lose the mk in the rear. I want something grippier in the rear to match the baron. MkII would be fine paired with a more similar tire.
    Then probably RQ, 2.2 or 2.4, whatever you prefer, may be just what you need (in case you're in search for one ).
    Just tuning into this thread as I'm interested in picking up a pair of 2.3s for DH in wet weather. The wire bead versions are rather cheap at about $20. Are those the tires that you're using, and do you think they'd hold up?
    Reputation: Hikers Only's Avatar
    Oct 2010
    Just got a baron 2.3 for the front and a trail king 2.2 for the rear. I can't wait to try them out tomorrow!
    I just received a pair of black chili Barons yesterday after waiting ages for them to come back in stock.
    Have not riden them yet, but initial thoughts mixed:
    They seem very small for a 2.3". Noticably smaller than the 2.25" Nobby Nics I was replacing.
    Carcass width measurement on an XM719 was 53.6mm for the NN and only 51.1mm for the Baron.
    Are the NN's big for a 2.25"? Or are the conti's small?!
    The sidewalls are much more solid looking than the NN's, but then you'd expect this given the extra weight. I dont know what conti are on about with the Apex elastomer sidewall however, I cant feel any difference!
    I only fitted with with tubes for now so cant comment on tubeless, however the tires were very easy to fit with no tools.
    I hope they live up to their reputation of being a good wet/loose condition trail tire however (especially here in the UK), looking at the tread it certainly looks like they should be.
    I had one on the front for almost two months in summer and i was impressed. For a 2.3 is very small but the tyre or the black chili is awesome, i was afraid of a bad choice because is a winter tyre but it stick like glue to every kind of terrain (rocky, loose, etc). Much better and confident than a 2.35 high roller. Not cheap anyway.
    Currently running trail king (rubber queen) with black chili 2.2 (another awesome tyre) and as soon as the rain start i'll put back that f*cker again on the front and see how it handle the wet/mud.
    Reputation: Heretic Skeptic's Avatar
    Mar 2012
    Quote Originally Posted by juan_manuel View Post
    How did the Baron end up handling the rain/mud as a front tire? Besides the width issue, I'm highly considering having this as my standard winter tire, instead of Hans Dampf. Considering going with a UST tire and UST rim system, to keep things simple, but still be able to run low pressure without flats.
    Has anyone bought the cheap wire bead one yet?
    What is the compound like?
    Quote Originally Posted by Heretic Skeptic View Post
    Sorry for late answer, well the baron is still on my mojo hd, as front tyre.
    Many tires were used in the past months and the baron was my wildcard every time that the others tyres fail, including a high roller 2.35 exc and two trail queens (the folding cheaper ones, good grip but sidewall are like paper). The winter was very soft so even i've try to ride it in bad conditions but the good mother nature only give me like 5 rides with mud and snow, and the tyre was awesome, even in the worst mud in a pretty steep downhill it keeps tracking and throwing mud, allowing me to pass were other riders just can't pass, of course some times is something about skills but in similar bikes with friends you can see where a tyre could make a difference.
    Now i'm looking to purchase another baron for the rear tyre and run a series of local enduro races here (is spring and in the summer the trails gets very loose) but this very same tyre was purchased in summer and i was very surprised how it performs on rocky loose trails.
    I don't remember exactly which version i have but is not the UST (even i'm using as tubeless) and that is what surprise me, because the trail kings were much more softer and i cracked two of them; i think even the cheaper baron has more glue or reinforced sidewalls due to it's nature as an enduro or freeride tyre.
    Update: Reading my old post i see that my baron is a 2.3 black chili, folding (non-ust).
    Mar 2012
    Thanks for the update! How was the Baron as far as mounting it tubeless? I know you said you didn't go UST, but I am now considering running tubeless with sealant, but am concerned about reports of Contis being difficult to mount tubeless.
    I'm still considering running a Hans Dampf up front, and Baron in in back, but am looking for more Baron feedback first.
    No problem with the baron or the trail king, just try to mount the tire with the quantity enough to seal it, then you can add more sealant trough the valve.
    Baron in the back is a good choice, now that the trails are getting dry i'm looking to put the baron in the back and install a 2.4 high roller 2 in the front.
    Jun 2012
    Running Conti Baron 2.3 Black Chili's Tubeless..
    Hi, I've been running the 2.3 Baron's with black chill tubeless front and back in Devon goo (mud on flint, etc..) for a year and a bit now with very pleasing results.. I find them extremely trustworthy/confidence inspiring in greasy horror as the reviewer states.. I agree with the consensus that the sidewalls are v'porous and the main issue (if there is any with the system) is getting Stan's fluid (or any liquid) to bathe that part of the tyre sufficiently, there is also the issue of the sealant bonding to the 'Black Chili" material and/or the mould residue/film on the new tyre.. to avoid the achingly arduous run-in process (which has worked after great effort) I've been painting a thin layer of Plasti Dip (with a thinner layer of Plasti Dip primer) on the inside of the sidewall only (down to the bead) and it's been holding pressure a treat and sealing the bead against the rim (Stans Arch's) better also.. Might seem like a lot of effort but these beasts go up better and down more aggressively than any tyres I've had previously (WBT WeirWolf 2.3's and the discontinued Conti Vertical Pro UST's most recently).. Thx for your time,
    Further views on this?
    A quick google and they are now VERY cheap here in the UK - is that right? The right tyre? I'm talking 15 when the original bikeradar review said 49.00.
    Which one should I go for? Its too replace my beloved Swampthing on the rear and will be used almost exclusively on rocks.
    Are you sure it's the black chilli model you are looking at for 15? The non chilli ones are often cheap, but rarely the BC ones.
    Quote Originally Posted by billysan View Post
    Ah eurika!
    Is the BC version waaay better than the non? Its a rear tyre only and doesn't need to be ultra grippy- just follow the front.
    Stick with the Black Chili version, the compound is superb, good on both grip and durability... The non-BC rubber is crap, plastic...
    mountain biker
    Reputation: slyfink's Avatar
    I just thought I'd add my voice to the crowd. I mounted my Baron (Black Chili) up to my Flow EX and took it out for its inaugural ride yesterday. It's on the rear wheel and paired with a Hans Dampf Pacestar mounted on a WTB i23 on the front. Conditions were wet snow, frozen snow, a little bit of ice, frozen dirt, wet dirt, and a few unfrozen puddles. Lots of rocks, lots of roots. It was a little below freezing, and they performed superbly. This was mostly a pedally ride, very few DH sections where I could really test for cornering and rolling resistance, but I was quite happy with them. There was a few sections where my buddies on Nobby Nics and Specialized Captains were spinning out, but the Baron just gripped and monster-trucked ahead!
    A note on mounting. I rode them tubeless. I had to set them up in two steps. First I inflated it with a tube to set the beads, then unhooked one side, pulled the tube out, added the stans, removed the valve stem core and hit it with a compressor. This isn't a UST tire, and the Flow EX isn't a UST rim, so it was a really tight fit. Not sure I could have done it with a floor pump, but the result seems pretty solid.
    I'm looking forward to more rides with this knobby beauty!
    continuous growth is the strategy of a cancer cell.
    Reputation: Whip Chop!'s Avatar
    Any reviews or thoughts on the Baron's as an all-around/year round tire? I would think that if they are great in the wet and loose they may do well in dry, really loose dirt like we experience here in Utah. After a while of no rain we get this powdery moondust on a lot of trails. I am currently running Trail Kings 2.4 front and 2.2 rear tubeless and they are fantastic. Just looking for other options.
    mountain biker
    when I was down in Sedona, hanging around the shops, it seemed that the Hans Dampf and the Trail Kings were the hot ticket. I'd say the Baron is like a Hans Dampf on steroids in that the blocks are bigger and chunkier. You'll loose in the rolling resistance department, but those knobs are spaced out enough that they should cut through the loose dirt pretty well. My uneducated guess is that they'd probably work pretty well in the kinds of conditions you describe, but you can probably do better. Ever thought of the specialized hillbilly? or even the swampthing from Maxxis? Heck the Hans Dampf or even Nobby Nic might work well for you. Either in the ORC or Pacestar compound (anything softer and you'll tear them to shreds in a matter of hours on the kinds of rock you have out there).
    Quote Originally Posted by slyfink View Post
    Good to know. I will most likely give the Hans Dampf a whirl this summer. Thanks!
    Singletrack Addict
    I was running 2.4 Schwalbe Fat Albert front and Nobby Nic rear but wanted something for fall/winter/spring in the Pacific Northwest. I put Conti Baron 2.3 BC's on, front and rear, and took them out today on damp/wet trails with packed berms and forest/leaf litter, roots, rocks, and a little mud. They look narrower and ride a little squirrely than the fatter Schwalbes, but they hook up with everything. I have more confidence in turns and I can lay the bike over more. Climbing was great, they didn't slip out, and descending was fine, but not as bomber as the wider tires (to be expected). I will be running Barons all winter.
    fat & decripit old guy
    Mar 2011
    I have the Barons front & rear on my Knolly Chilli, run them all year round.
    I will not use another tire on my bike as these are so fantastic!
    This is my 2nd year running them now and on my second set. First set lasted over a year and only had to replace then due to side wall tears.
    They still had 50% tread left on them with 4 good Whistler days thrown in for good measure.
    Yes they are the 2.3's with the "Chilli" compound.
    I just love the tenacious grip that they have in all conditions, so I will live with the VERY miner rolling resistance that they have.
    Other tires that I have run, I had problems with the side knobs tearing off. Not with these tires.
    I'm not saying that I am a fast rider, (more of a brutal hack) but when spending good money on tires and knobs tearing off, it did not sit well with my pocket book.
    Singletrack Addict
    I'm running the Baron 2.3 black chilis on front and rear in Hood River, Oregon. The tires are 800g each. The casing is narrower than the Schwalbe Fat Albert 2.4 it replaced, but the actual usable tread width isn't that much narrower IMO. The tires are way more nimble and provide great grip on the mud, clay, leaf litter, logs, man-made ramps, etc. They climb well when standing out of the saddle. I've been running these for 5 weeks and I'm very happy with them. I rode Sandy Ridge which is more rocky/gravel covered, and I had to drop the tire pressure quite a bit. I'm 195 lbs all geared up and I run around 26 lbs in the front and 30 in the rear, with tubes. I will be running these tires for a long time, they're perfect for my local riding.
    Jan 2014
    replaced a torn nobby nick 2.35 on the front with a baron 2.3 but my back is still a nn2.35, which is way more wider than the baron, should i leave it like this or swith the wider to the fron and let baron 2.3 at the back?
    Singletrack Addict
    I run Barons front and rear (older Baron on the rear so it still grips when climbing). They are perfect for PNW riding. Another option would be the Trail King 2.2 on the rear.
  1. Replies: 0
    Last Post: 12-30-2011, 08:01 PM
  2. Continental Speed King 2.1 Supersonic Review
    By RecceDG in forum Wheels and Tires
    Last Post: 06-02-2011, 07:38 AM
  3. Continental Mountain Kings - my review
    By pedro_sandchez in forum All Mountain
    Last Post: 01-19-2009, 02:38 PM
  4. Continental Mountain King Protection - quick review
    By frdfandc in forum Wheels and Tires
    Last Post: 07-03-2008, 10:28 AM
  5. Continental Diesel 2.5 mini-review
    By bear in forum Wheels and Tires
    Last Post: 03-15-2005, 11:33 AM
