Results 1 to 46 of 46
    Is not amused
    Reputation: Hutch3637's Avatar
    Conti trail king 26 x 2.2
    I recently ordered a set and im wondering the size width because its been said they run big. Now I'm wondering if it will fit on the rear of a stumpy fsr 11. Any input would be appreciated. Thanks. Ps. I.ll be running them front and rear. How is that set up working on your ride?
    parts leftover
    Reputation: schlim's Avatar
    It should fit fine, although they are nicely fat for a 2.2 width. They are hands down the best all around trail tires I have ever used. The tread pattern and black chili compound are optimal for the conditions I ride in.
    Is not amused
    Thanks for information, as I've heard nothing but good about these tires.
    Reputation: shapirus's Avatar
    Quote Originally Posted by Hutch3637 View Post
    Well, to me it seems it would be better if they had slightly more aggressive side knobs. On ZTR Flow (22.6 mm inner), casing runs one or two mm wider than the outermost knobs (57-58 mm at the casing), which makes the RQ not as confident in deep ruts and similar stuff as it could be.
    Otherwise, great tire indeed.
    BTW, does anyone have an idea of any tire which you could call "a better Rubber Queen", considering my side knob preference while keeping everything else close to the RQ?
    parts leftover
    Quote Originally Posted by shapirus View Post
    You might look at the Hutchinson Barracuda 2.3. It's very aggressive with a similar tread pattern, but IMO doesn't roll as well as the Conti RQ/TK. Regardless, my wife won't run any other front tire on her bike.
    http://www.pinkbike.com/news/2006-Hu...da-Review.html
    I love my RQ2.4 but on everything other than wet rock, my Advantage 2.4 is a faster rolling, more predictable, feels plusher as weaker side walls continual run of side knobs pretty much, seems comparable in the mud to, but the RQ2.4's compound wins in wet rock areas.
    Also huge so a 2.25, the 2.4 even rolls okay on the rear where as I think a RQ2.4 would drag.
    * not used the 2.2!!
    Well I forgot to mention that I intend to tun the new tire up front only and during wet periods of time like late fall/early spring. In the rear, I am happy with RQ 2.2, and in the summer I run a pair of Michelin Wild tires in 2.25.
    So it should have good grip in wet conditions, at least not worse than the RQ which it will perhaps be replacing, so probably a fairly soft compound tire.
    Muddy Mary ?? 2.4 it's supposed to be higher volume than the RQ2.4 and softer rubber, but without the BC advantage ( dunno if I believe that anyway ).
    42a maxxis minion Single ply DHF would be softer, 2.5 would likely be similar size to the 2.2 RQ strangely, maybe even the 40a slow rebound if they do 1 for ultimate wet traction!!
    There's always the Nevegal Stickee too...
    Thanks for the input everyone. The Barracuda lacks transition knobs which isn't really good for my desired do-it-all early spring/late fall tire. It also looks a bit too aggressive anyway.
    As for the Schwalbes, I'll better stay away from them for now, since there are reports that their newer models don't run well on ZTR rims (I have Flows) and that their overall quality has dropped noticeably in the last year or so. Also, they're way too expensive to try experimenting with them, so no, thanks.
    Minions maybe, but it looks like they're too heavy for their actual size, even the 1-ply ones. Also, the 42a compound may be way too soft whereas the next option seems to be 60, and that's harder than I'd like. There are a few other interesting Maxxis tires, though, but this time I think I simply want to try a different vendor.
    Kendas maybe, especially something like Excavator with dual compound.
    Anyway, after some looking around, I came across the WTB Prowler MX 2.3 in Super Track compound. Looks just right: proper tread pattern, good side knobs, right compound on the soft side, not too heavy (700g-ish I suppose) and enough volume (if the GMS info on the WTB site can be trusted). Also, it will likely work on ZTR rims tubeless, however, I couldn't find much info on this other than one post on the Notubes board. Last but not least, reasonably priced.
    May also try the Bronson rather than the Prowler, depending on the stock availability at where and when I'll be ordering.
    Will do more searching though. I will not need to install it before it starts raining in the fall, so don't really have to buy it now in a hurry.
    Quote Originally Posted by schlim View Post
    +1
    I love these tires. You give up a little in rolling resistance but the confidence they inspire is downright dangerous
    Is not amused
    Update, just got them on today. IMHO, they roll and have a much better grip then the stock ones that where on my bike. I noticed the side knobs don't protrude to far besides that the grip on these things is unreal. I'll test them out tommorrow. Also for some reason I never got a email or update about this thread...weird...Thanks for the imputs though.
    the 2.4 is amazing great tire, you'll love it, damn good job there a lot of money just for 1 tire, on the front aswell I've got 1000's of miles on mine and the little dimples where the fluffy rubber stuff was is there there, they don't wear at all
    Tire Geek O_o
    Reputation: cesalec's Avatar
    Have you considered the Big Betty Vertstar 2.4" or the Hans Dampf Trailstar 2.35?? both are awesome!
    On the front i only use :-
    RQ2.4 or Maxxis Advantage 2.4, volume is down slightly on the advantage, it roles near silent and gives a very comfortable ride feeling like more suspension than than RQ2.4, very aggressive side knobs but 60a rubber so less useful on wet rocky terrain.
    XK2.4's for very dry hard floor days, although I think the Advantage 2.4 might actually role better.
    I haven't tried the Big Betty or the Hans Dampf as yet, I'd like to ofcourse but had to cut my tire experimentation budget these days
    Just adding my experience with Rubber Queen ... Black Chilli is by far the best tyre compound I've used. I love these tyres, they grip in places most tyres don't, they're predictable when they slide, they don't wear as fast and they feel just as quick rolling as the stock tyre. I've used 2.4" front and rear on a rigid SS for rougher rides, brilliant set-up.
    Just waiting for the 2.2 ad 2.4 29er versions with black chilli now.
    WI. Big Boy MTBer
    Reputation: fattybikejones's Avatar
    I just slapped on a set of Conti Mountain King 2.4s.. talk about your fat daddy-o's!
    TREK X CALIBER 6, MOTOBECANE USA MIRAGE SLX
    Quote Originally Posted by fattybikejones View Post
    I hope your talking about the Mk2's cause the Mk's I'd class as 2.15 area, the RQ/TK 2.4's on the other hand I'd class as 2.6's
    Reputation: BigHit-Maniac's Avatar
    Speaking of these tires.....
    Has anyone had issues with getting the tires to seat on their rims?
    Everytime I have to re-install them after say a flat, or something the bead doesn't wanna' seat. Like... at all. It creates huge wobbles in the tire, and is a complete pain in the butt to get it to "pop" into place. I've had to use my personal air compressor with over 60 PSI just to get it to seat.
    Have had to use soapy water, etc. WTF gives? Last time I got a flat on the trail, I couldn't for the life of me get it to seat... and rode all the way back to the parking lot with a huge "bump" in my rear tire because I couldn't get it to seat.
    Is there some special trick I dunno about ?
    I know the sidewall on these is super flimsy... but damn. I've never had so much trouble in my life with tires seating on rims.
    I've got the stock Alex rims on my Rockhopper...
    Any chance of getting these tires to work with stan's rim strips & stan's tire sealant to go tubeless? Think they'll seal ?
    You in Oklahoma City? If yes, come ride with us.
    WI. Big Boy MTBer
    Quote Originally Posted by Turveyd View Post
    Nope.. MK 2.4.. Compared to my 2.1 something Kendas.. the MKs are Colossal!!!
    Compare them to a RQ 2.4 and you'll think they are barely there.
    There small compared to a XK 2.4 or even a RK 2.2.
    WI. Big Boy MTBer
    Ohhh..to me they are there..
    Oct 2012
    I've had great luck with Trail King 2.2 Black Chili Protection version running as front tire only. One thing to add is that my friend has the regular non-Black Chili version and his is noticeably narrower. I didn't have a measuring device with me and granted they were on different rims but we both have older narrower rims. I agree that they are overall very confidence inspiring and predictable but every once in a while I wish they had some more aggressive side knobs as I've washed out on a few turns. Probably just as much user error as anything else though (probably more, actually)
    I have the MK2 2.4 upfront with a crest rim. It's barely larger than the Ikon 2.2 at the rear. Was hoping it would be noticeably larger. But it's a good tire. For my riding style and skill, it has almost the same grip as a Minion 2.35 and rolls much faster.
    Dec 2009
    Maybe at a glance?.Mine measure out quite a bit bigger than Ikons.From memory about 58mm vs 54mm in width and at least 5 mm taller.
    Yeah, it's more of a line of sight. Didn't measure it though.
    Quote Originally Posted by outofdoors View Post
    My thoughts exactly. I am still lazily searching for a similar tire, but with more pronounced side knobs. Maybe Baron 2.3 could be the choice, but it is a good bit on the heavy side (850g for the handmade in Germany version if I'm not wrong). I would prefer something under 700g like the TK/RQ 2.2.
    Slightly off topic, but what store are you guys buying the 2.2 protection TK from? I'm having a heck of a time finding them.
    Is not amused
    Quote Originally Posted by wheatgerm View Post
    Just checked for you in both 29er and 26 on all my online go to places. All out of stock. Might want to hit up your LBS for this one.
    Haven't had much luck there. Thankfully, I'm not in dire need of tires, yet...
    Gnar
    Reputation: Jet Fuel's Avatar
    Not advertised as the protection version, Performance has these:
    Continental Trail King 2.2 MTB Tire -
    At that price and 180 TPI, they should be Black Chili compound.
    Just a suggestion, let the buyer decide...
    JGL
    JGL is offline
    I just had one delivered via amazon.com from Nashbar for $40+$7 shipping. "Handmade in Germany," 652 grams (weighed), black chili, has crosshatch pattern on sidewall.
    Does it say Protection on it? The non-Protection model (Race Sport) weighs 660 while the Protection weighs 750, according to the Conti catalog.
    Is not amused
    In stock now in 26/ 2.2 or 2.4 protection version.
    Universal Cycles -- Continental Trail King ProTection Tire
    I need 2
    Is not amused
    I need 2
    Order two then.
    Order two then.
    Ha ha!
    Tee hee!!
    I see my browser didn't show me the updated site before I responded above... the update showing 8 tires in stock.
    Now they only have 6!
    LCW
    LCW is offline
    Reputation: LCW's Avatar
    wheatgerm - go here:
    http://www.biketiresdirect.com/produ...ction-mtb-tire
    Ordered mine on wed... Will get mon
    Santa Cruz Hightower LT
    EVIL Following
    LCW
    LCW is offline
    Beware about universal cycles... I ordered a 2.4 a couple weeks ago... Description said Protection... Got it and it wasn't Protection... I returned it. Emailed a Conti rep and he said the 2.4 Protection will only be avail in spring... 2.2 protection just became available.
    Protection meaning the RTR version to be clear.
    EVIL Following
    The 2.2's are on the way from Universal. I'll make sure to check that I have the correct tire. Thanks for the tip.
    LCW
    LCW is offline
    Got the 2.2 TK Protection RTR today... Tried everything... Floor pump - no go... compressor - NO GO... seated with a tube - worked!... Take tube out... F***er won't seat no matter what I do... No flex in the sidewalls... They feel like plastic...
    I have UST shimano XTR Trail rims... Combo just doesn't seem to work...
    So f*** it... I'm too impatient, just going to put High Roller 2.35 UST in front like i have on the rear... That tire seats tubeless with a floor pump...
    EVIL Following
    LCW
    LCW is offline
    As a last ditch effort before giving up - I reinstalled the tube, pumped it up to 40 psi and got the beads nice and seated. Going to leave it for a bit hoping the tire beads takes a bit of a set confirming to the rim (a few kinks in it from being folded). Hopefully in a day or two or even a week, it will want to seat a tubeless...
    EVIL Following
    Got my Trail King 2.2 Protection RTR today. I did get them to seat tubeless on a Mavic 819 but only after I used a tube to get the bead set on one side. Had to use CO2 to set the other bead up. My small compressor doesn't move enough air to set the bead. Thankfully, when the bead is set, I can let out all of the CO2 without breaking the bead then add Stan's and air. Tires seem to be holding air fine. There's no Stans seeping thru the tire. The tires held air fine even without the sealant.
    I've never had luck setting up tubeless -ready tires without compressed air or CO2. When I used UST tires, the beads set easily with a floor pump.
    LCW
    LCW is offline
    Agreed - the High Roller UST 2.35 I put on the rear seated easily with floor pump.
    Got my TK 2.2 RTR seated finally tonight. Like you I set it up with a tube first. That was Monday. I purposely waited til today to try to get it to seat tubeless, let the tire take a set against the rim (smoothing out the kinks from being folded up).
    I unseat part of the bead on one side - 1/3 to 1/2 worth. Had to use TWO tires levers alternately to get the bead pried off the rim. These bastards are TIGHT! Then I sacrificed the tube by cutting it so I could snake it out rather than unbead the whole one side.
    Poured 2.5 scoops of Stan's. Tugged the tire against the rim best I could where I had unseated it. Boom!! - installed and bead snapped in place with floor pump! I was happy! So far holding air tight as it should. Nice and beefy too. Gotta be one of the larger 2.2's out there.
    EVIL Following
    Oct 2012
    Quote Originally Posted by Kaizer View Post
    Am not familiar with the Ikon you mentioned, but I'm using MK2 2.4 up front also on Crest, and it looks really nice confidence-inspiring fat. Sure looked massive - until a friend came with Minion 2.5. I then felt really really small.
  1. tips on sealing conti trail king
    By b-kul in forum Wheels and Tires
    Last Post: 07-09-2011, 08:59 AM
  2. Conti Trail King Question
    By dreampath in forum Wheels and Tires
    Last Post: 06-25-2011, 03:45 AM
  3. Conti Trail King up front?
    By Fastcars12 in forum All Mountain
    Last Post: 06-02-2011, 06:26 AM
  4. What's the deal with Conti Trail King UST tires?
    By steiny in forum Wheels and Tires
    Last Post: 10-13-2010, 06:02 PM
  5. Conti. Trail King Sealing
    By Lennard Sheley in forum Wheels and Tires
    Last Post: 08-29-2010, 08:13 AM
