Results 1 to 5 of 5
    Comparable tire to the IRC Kujo DH
    Hi folks..
    I am looking for some new tires that are comparable in performance, width, rolling weight, wear, etc. as the IRC Kujo DH tires that I used to run and loved.. I am a cross country rider and enjoy the stability of a wider tire but need them to hold my weight in the corners and resist pinch flats..
    Thanks,
    Jerid
    2007 Specialized Stumpjumper FSR Expert
    Check out my rides/routes on Geoladders.com
    8/23/2007 292 lbs.
    6/6/2007 330 lbs.
    Quote Originally Posted by SKINNY_
    Hi folks..
    Thanks,
    Jerid
    I think you might still find em if you look, I've seen them listed online occasionally.
    I don't know the tire well enough to suggest something the same, but some tires that might be similar, you'll have to check them out and decide:
    Schwalbe Big Betty
    Nokian NBX or Gazza
    Hutchinson Barracuda
    Maxxis Minion (2.35 or 2.5)
    Nashbar has em for $14.99 plus the discount
    I just got some, but have not tried them yet. They are a lot heavier than I expected them to be
    Reputation: EDDIE JONES's Avatar
    Mar 2005
    They are pretty much bulletproof and grip good. I doubt you could pinchflat those things because the sidewall is so stiff. Shutterbug is right. They are still being sold.
    Cool!... i'll go check nashbar.. Thanks guys..
    8/23/2007 292 lbs.
    6/6/2007 330 lbs.
