Results 1 to 5 of 5
    DFMBA.org
    Reputation: MTBeing's Avatar
    CO2 vs Big Air for (Stan's) tubeless?
    Currently using CO2 with an Ultraflate Plus and both CO2 and Big Air will fit the head. Are there advantages/disadvantages to these? The 16gm CO2s are certainly cheaper in bulk and fill my 29er tires just fine. Why pop for the more expensive Big Airs?
    Please donate to IMBA or your local IMBA chapter. It's trail karma.
    Reputation: kithannah's Avatar
    The Big Airs are a rip. Same thing. I purchased a few today and they were like $3 each, you can get the regular ones in bulk for $.50 each.
    Quote Originally Posted by CCMTB View Post
    2.5 times the capacity for only 40gr. For me it's only good on a race course when you want to extend a slow leak to finish a lap before going to the pit. The ones I tested did not have a big enough force to pop the beads on my ZTR race wheel. For regular riding I use regular 16grs also.
    DFMBA.org
    Thanks. I'll stick with CO2 for now.
    Trail Tire TV on blogger
    Reputation: thomllama's Avatar
    Oct 2007
    shouldn't use CO2 with tubeless tires with sealant... the CO2 will basically freeze/rapid dry the liquid and cause the dreaded latex ameba.
    Going to try and bring Trail Tire TV back. go take a look... http://trailtiretv.blogspot.com/
