Results 1 to 6 of 6
    Chris King Fun Bolts-Trail Removal
    What exactly are you carrying in the woods, in case of flatting the rear? I have a feeling the standard 8mm L-Allen is not going to cut it, considering the 25ft-lbs they are tightened to.
    Civilization ends at the waterline. Beyond that, we all enter the food chain, and not always right at the top.
    Reputation: J.B. Weld's Avatar
    You should be able to crack those with the 8mm on a compact multi-tool, especially if you put a little grease (or anti seize) on the threads. Try it at home and see.
    MTBR Member
    Reputation: ncfisherman's Avatar
    Standard 8mm allen works fine.
    Reputation: boostin's Avatar
    Before you head out, make sure your trail tools are sufficient to do the job. I use a standard 8mm allen key on my fun bolts.
    Standard 8mm Allen works for me. My compact multi-tool, however, doesn't work so well. As such, I put the 8mm in my pack if I'm on that bike.
    Quote Originally Posted by mr7q View Post
    This^
    And make sure you grease the threads
    Lead by my Lefty............... right down the trail, no brakes.
  1. King fun bolts vs. 142 TA...
    By Miker J in forum All Mountain
    Last Post: 04-23-2012, 07:05 AM
  2. Chris King BB, or Enduro?
    By Borgschulze in forum Fat bikes
    Last Post: 12-31-2011, 07:35 AM
  3. Chris King 20mm Front Hub Bearing Removal
    By Freerider in forum Wheels and Tires
    Last Post: 11-24-2011, 01:24 PM
  4. New Chris King Hub
    By Frac in forum Wheels and Tires
    Last Post: 10-06-2011, 07:35 AM
  5. Chris King BB...
    By Scottyman in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-22-2011, 07:01 AM
