Thread: Chris king 15mm
    Chris king 15mm
    I just purchased a set of wheels with king hubs. I need to convert the front hub to 15mm. There are 2 parts listed when I serch this. The thru axle conversion and the clamp. Do I need both peices? CAn I do with out the clamp?
    You need the clamp. I bought the complete set up from King, direct. Maybe try that..
    Reputation: clydecrash's Avatar
    Apr 2005
    Well, do you have a QR or 20mm hub right now? If a 20mm, then you just need the LD axle (you already have the clamp). If a QR, then you need the SD axle and clamp. SD conversion usually comes as a kit. King seems to have changed the specs of some of their hubs (LD hubs I believe), so be certain to get the correct version.
    Mar 2014
    Me 20mm Chris King, You 15mm Chris King, - Im looking to swap with anyone. We swap axles, clamps are standard.
  1. Confused about spoke length for 15mm SD ISO Chris King Front 28hole
    By camelunderwear in forum Wheels and Tires
    Last Post: 04-15-2013, 08:10 PM
  2. Chris King 15mm to 9mm QR conversion kit?
    By Call_me_Clyde in forum Wheels and Tires
    Last Post: 10-23-2011, 08:11 PM
  3. New Chris King Hub
    By Frac in forum Wheels and Tires
    Last Post: 10-06-2011, 07:35 AM
  4. Chris King Conversion Kit: 15mm -> QR
    By estabro in forum Wheels and Tires
    Last Post: 08-14-2011, 09:53 PM
  5. Chris King Hub Question 15mm axle
    By Phalophalot in forum Wheels and Tires
    Last Post: 07-25-2011, 07:37 PM
