Results 1 to 2 of 2
    Cheap Front Disc Hub with High Flange
    Basically, I would like to use the same length spokes all around. That would involve using a front hub with a disc side flange of at least 61 mm, but preferably 63mm+. Anything below the high 70s. The non-disc side doesn't matter really.
    I haven't found any hubs around there except the old XT M756 hubs, which weight a ton. I'm not looking to spend above around $50. Would prefer to be convertible. I don't mind used. Heck if there is a really good deal on a quality 58mm (common size) disc side flange, I'll take it.
    Maybe something similar to a Spec Stout, except lighter? I found that they have a 62mm flange. Thanks.
    Just measured my bitex hub, its 58. $30 shipped and its yours. Brand new, 9mm and not convertible though. MTF10 Bitex + Bicycle & Wheelchair hub
