Results 1 to 16 of 16
    Reputation: LarryFahn's Avatar
    Changing sealant brand question
    I set up my new ride as tubeless using DT Swiss XM 481 rims, stans tape and sealant, and Maxxis HR2(front) and Minion DHR2(rear). Both constantly lose air while between rides. I'd like to change to Orange seal. Do I just empty out the Stans and load the Orange in there or do I have to really get all the Stans off of the tire/rim for it to work?
    Hubbard Bike Club
    Nat
    Nat is offline
    Reputation: Nat's Avatar
    I'd just empty the Stans, replace with Orange Seal, and see what happens.
    turtles make me hot
    Reputation: NYrr496's Avatar
    I replaced Stan's with Truckerco Tire Cream. I just replaced the stans with the Truckerco.
    I like turtles
    I think truckerco might be Stan's with some ground up rubber added in.
    I wouldn't imagine they're incompatible (any sealant)?
    Positively negative
    Orange and Stan's do not mix. Orange will dry out very quickly with it comes in contact with Stan's. You will want to make every effort to get any Stan's sealant and residue out of your tires to give yourself the best chances.
    turtles make me hot
    Quote Originally Posted by One Pivot View Post
    Truckerco is definitely LIKE Stan's but it is way better. It isn't bleeding through my sidewalls and drying out prematurely like Stan's.
    I like turtles
    Reputation: blacksheep5150's Avatar
    Oct 2014
    Quote Originally Posted by big_papa_nuts View Post
    Thats what the orange seal reps said and did when they changed mine out at a event, they pulled the tires and washed then out with rag and water .. nice not having stans seep through side walls
    turtles make me hot
    So... We're all in agreement.
    Stan's sucks red monkey ass.
    I like turtles
    MTB B'dos
    Reputation: LyNx's Avatar
    Me personally, I'd mix up some soapy water and put all over the rims and tyres to try and find why they loose so much air so easily, if it's the valve interface or if the tape wasn't put down good or the tyres them selves are leaking. If I didn't find a definitive answer, I'd strip the tyres off, check the valve is seated properly, then strip the tape off and re-tape the rims and do it right this time instead of trying to put a band aid of different sealant to do what a good tape job should do.
    Can't count the amount of Maxxis tubeless tyre setups I've done and the only time they've not held air without minimal loss over days without sealant is when either the valve wasn't seated/tighten correctly or something was wrong with the tape.
    Sep 2016
    Quote Originally Posted by blacksheep5150 View Post
    I can attest this isn't just some company ploy. I tried to refill a stans tire with Orange seal and ended up with a dried out sealant in about a week. So yeah, clean your tires.
    because GIANT
    Reputation: 127.0.0.1's Avatar
    Nov 2013
    just dump orange seal into stans. no need to dump old stans (unless you need
    to pull stanimals out). it'll work fine
    my fatbike hodags were losing air on stans and stans was weeping...dumped in 3 oz stans front and back and it sealed right up and holds pressure forever
    Positively negative
    Quote Originally Posted by NYrr496 View Post
    Umm, no. Out of all the sealants I have used Stan's has been the "best". It's not perfect, but has worked better for me than any others.
    Barely in control
    Reputation: Schulze's Avatar
    Feb 2007
    You should empty out all the old sealant and clean the tire. The chemistry of the sealant changes as it reacts with air. Mixing the old sealant chemistry with the new sealant is contraindicated for successful sealing.
    Interesting. I've found it lasts about the same, but seals up a lot better! It's a lot cheaper, plus works better, so it's my preference.
    turtles make me hot
    And it's made in the USA.
    I like turtles
    turtles make me hot
    I'm glad it works for you. In another thread, Mendon mentioned that Stan's changed at some point. It definitely did. It started seeping through sidewalls. It still sealed but really well but I grew tired of having to scrub the sand and dirt that was glued to my tires. Switched to Truckerco which is also a white liquid latex and no more seepage. Truckerco is like Stan's without the nasty side effects.
    I like turtles
  1. New tire sealant from Continental, Revo Sealant
    By CrozCountry in forum Wheels and Tires
    Last Post: 02-03-2016, 03:25 PM
  2. Replies: 12
    Last Post: 11-15-2013, 12:24 PM
  3. Slime "Tire Sealant" vs. "Pro Tubeless Sealant"
    By FTC Rider in forum Wheels and Tires
    Last Post: 12-23-2011, 02:26 PM
  4. Sealant or no Sealant
    By FreakyStuie in forum Wheels and Tires
    Last Post: 04-16-2011, 02:19 AM
  5. Stans Sealant vs. Slime Sealant --> for Stans Wheels
    By LandSpeed in forum Wheels and Tires
    Last Post: 03-20-2011, 11:16 AM
Members who have read this thread: 22
