    Can these wheels fit ?
    can this wheels Mavic Crossride Disc Wheelset 2010
    fit my '05 specialized hardrock comp frame ?
    Reputation: 4slomo's Avatar
    First thing you want to check is if they will fit the dropouts. Your Hardrock probably has standard QR dropouts. Are the Mavic hubs QR models?
    Hey everybody, ride my wheels! They ride good, real good.
    I'm a wheel builder. SRLPE Wheel Works. Send me a PM.
    I assume it is, and i asked the people from the site where they sell it and they said yea it will fit. Heres the wheels spec just to give you an idea: it was cheap $136 for set free shipping.
    Entry level at Mavic always means quality, efficiency and reliability.* The Crossride offers performance with a focus on value.* Features include reinforced rims, high quality FTS-X freehub and a low weight-1905 gram for the set.*
    Disc brake specific profile
    Black anodized 6106 alloy rim w/ internal width of 19mm
    Bladed black spokes w/ brass self lock nipples
    Aluminum hub shell
    FTS-X freehub body
    For use with 26" tires
    Max tire width 2.3"
    Works with schrader or presta valves
    Includes rim tape, rear QR, 6-bolt adapters
    Works with 6-bolt or centerlock rotors
    Wheels labeled "15mm" only work with forks designed around the 15mm integrated thruaxle system. A quick release skewer is not included. Compatible forks already have a suitable axle built in. 15mm wheels will not work with forks that use a seperate quick release skewer and traditional open dropouts.
    Compatible with 8/9/10 speed SRAM/Shimano cassettes
    Approximate weight 1905 grams, set
    Sold as a set, includes front and rear wheel
    Looks like you need to determine if the front hub is a 15mm hub or not.
    Also know that the Mavic rear hubs have had a reputation for wearing out a plastic bushing.
    Check to see how many spokes each wheel has: 32 spokes each will be more durable.
