Results 1 to 2 of 2
    Can Michelin AirComp Ultralight C4 tubes be used with a 1.5 tire?
    Hello, i have several Michelin Air-Comp Ultra Light C4 inner tubes.
    Currently, im switching from 26X2.0 tires to 26x1.5 tires.
    In Michelin's web site, it says that my tubes can be used with a 1.5 tire
    However over the box, it says the tubes can be used with 1.6-2.1 tires.
    Another problem is that, over the box it also says the tube can be used with 37/54-559 tires.
    Since 1.5 tire is 40-559, the box contradicts itself
    Im confused :S
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by Floriante
    Im confused :S
    Welcome to the wonderful world of nominal sizing. Because tires and tubes are a flexible item (except for the bead seat diameter) the actual size can vary widely.
    The tubes should fit. Try them. If they do not fit, get narrower tubes.
    mtbtires.com
