Results 1 to 8 of 8
    Reputation: Gabe3's Avatar
    Can I use tubes in stans ztr crest 29 wheelset?
    curious if I can use tubes with stans ztr crest 29 wheelset and schwalbe racing ralph 2.25" tires?
    Former Bike Wrench
    Yes, you can use tubes in Stans rims
    max_29
    Reputation: max_29's Avatar
    Oct 2007
    you sure can.
    been there, done that. with racing ralph 2.25" tires.
    from my experience, it was nearly impossible to mount a tire with a tube inside.
    finally i got it on and started thinking, what if i need to repair a flat on a trail during black flies
    or mosquitoes season
    so i sold crests while still new and got myself wheels built on TL28 and Blunt SL rims.
    night and day to mount a tire with a tube.
    slightly heavier than crest but i can live with that.
    or maybe i just need to practice more
    derp
    Reputation: danielsilva's Avatar
    Well i've beem forced to use a tube on my rear Crest, i could mount it easily with some plastic levers and could even mount them by hand if i wasn't such a wimp
    Quote Originally Posted by max_29 View Post
    you sure can.
    damn its that hard with racing ralph tires? why is it so hard? maybe i'll be buying the sealant sooner than later then.
    max_29
    Oct 2007
    Quote Originally Posted by Gabe3 View Post
    try first, maybe you'll have it easier
    should I try using a smaller tube? like a 1.9-2.1? or is that a no no? maybe it would help since the rim has the yellow strip in it leaving less room for a tube.
    max_29
    Oct 2007
    there's a room for experimenting - you could try a narrower rim tape (for road rims) or veloplugs to create more space for a tube. also make sure all air from tube is squeezed out.
    i used 26" 2.25 tube with a wider rim tape, ran out of tapes for road rims @ that time.
