Results 1 to 5 of 5
    skaterqwertyuiop
    Reputation: skaterqwertyuiop's Avatar
    Can I use Presta inner-tubes in a wheel drilled for Schrader valves?
    Can I use Presta inner-tubes in a rim drilled for Schrader valves?
    I want to make the switch to Presta inner-tubes, because, well....
    They look fancy Also, I've gotten sick of my Schrader valves sinking down into my tires.
    It may seem like a stupid question, but I just want to be sure.
    Thanks,
    Tim.
    It's not about what bike you ride, but how hard you tear it up
    Reputation: dirthead's Avatar
    Yes, no problem
    "Confidence is the feeling you have before you fully understand the situation".
    skaterqwertyuiop
    Thanks, Tomorrow I'll be at my LBS picking up a Presta inner-tube, and a $1 pump adapter.
    Reputation: ebotto's Avatar
    See if they have some adapters for the wheel itself. They just pop into the valve stem hole and then the prestas will fit nice and snug.
    meow meow
    Reputation: b-kul's Avatar
    yes but get some rim plug things that make the valve hole the correct size.
