    Can a bent rim be straightened
    I did some riding in Mammoth for the first time recently and came back with a pretty good wobble in my rear wheel.
    My bike is an inexpensive Marin HT with the stock rims. I was riding the basic green and blue trails and the braking bumps were allot worse than expected. Being a novice rider I was spending to much time sitting down and I'm pretty sure I felt when the bend occurred as I went over some rocky bumps leading into a corner.
    I just want to know if its fixable or am I stuck buying at least 1 new rim?
    What could go wrong ...
    Reputation: Zoke2's Avatar
    Nov 2007
    is it just a wobble or is it bent ... pics would help
    I used to ride to Win ... Now I ride to Grin
    While my guitar gently weeps, my bike sits there mocking me
    I'll have to add some pics later.
    I can't see any dents or anything so i think it's just a wobble. I'm not sure I guess.
    Nov 2012
    If you look at the wheel from *above it* and spin it in the frame, and the wheel moves back and forth, it's probably a spoke tensioning issue, and likely is easily fixed.
    If you look at the wheel from *the side* and spin it in the frame, and the wheel moves up and down, it could be a spoke tensioning issue, and again, likely is easily fixed or it could be a bent rim, which may or may not be fixable.
    Take the wheel to a shop or two or three in your local area and then use your best judgement.
  1. Bent Rim?
    By CrashDummy31 in forum 29er Bikes
    Last Post: 10-10-2013, 03:26 AM
  2. Bent something or other?
    By Bruce in SoCal in forum General Discussion
    Last Post: 07-03-2013, 09:47 AM
  3. Bent axl or bent hub?
    By El Sapo Rojo in forum Vintage, Retro, Classic
    Last Post: 03-19-2013, 08:39 AM
  4. Bent cog
    By Glynn Sluder in forum Singlespeed
    Last Post: 05-06-2012, 10:33 AM
  5. Bent rim
    By Koin in forum Wheels and Tires
    Last Post: 03-12-2012, 11:22 PM
