Page 2 of 2 FirstFirst 12
Results 101 to 183 of 183
  1. #101
    Reputation: oaklandish's Avatar
    Quote Originally Posted by Marc Lindarets View Post
    Aah- got it. Specialized tried to do something similar with the introduction of 28mm QR end caps several years back. Thanks for bringing this up- we don't have any immediate plans, but if it catches on (and proves beneficial) then it's certainly something that we could do.
    Marc
    Yeah it looks like it might catch on as this seems to be the way almost all the new Rockshox offerings are going to be made. Their website is notoriously behind their actual current products so always double check for yourself. Not on this list, but I can assure everyone, my new Boost 29 140 RCT3 solo air is definitely torque milled:
    https://www.sram.com/rockshox/technologies/torque-caps
    First Ride: 2016 RockShox Lyrik - Pinkbike
    The Boost extender caps you are making, which are a very much appreciated product by the way, might need to be produced in two variants for each hub manufacturer, one with this "torque cap" 31mm dimension that RS is making and one with the standard size for other fork manufacturers.
    I'll galdly send in my p321 hub as a test mule in exchange for a set of these
  2. #102
    Rick,
    The Kings are a little more involved, unfortunately, as adapting their hubs (front or rear) requires replacing the entire axle. Not that it can't be done, but we'll have to spend some more time and price it out before committing.
    Marc,
    This is Paul...the guy who's been talking to you about the FR440. About the King...I'm not sure if you're aware of this but on the disc side of the 12x142 King axle there is a lip onto which a steel end protector is clipped. If you do something like a DT end cap ala the 240/440 where it's clipped on w/ a rubber o-ring, it might be all that's needed as the axle will keep the whole thing together. So long as the frame contact portion is 19mm OD, the part that would fit over the King axle could be any OD so long as it doesn't obstruct the caliper, no?
  3. #103
    Marc, any update for I9 hubs?
    Sent from my SM-G920V using Tapatalk
  4. #104
    Goat Wrangler
    Feb 2015
    Quote Originally Posted by mhopton View Post
    Sorry for the delay- things got slowed down a bit with the transition to Wolf Tooth. We're getting close on those- the fronts are machined and at anodizing and the rears are being machined now. Probably 1-2 weeks and you can sign up for a stock alert now on the Wolf Tooth website!
  5. #105
    Nov 2007
    Keep up the good work Marc! I'm in the process of building a boost frame with "old" parts and the Boostinator was a very welcome find. Question though: I have a non EVO Hope Pro 2 front hub (100x15) I see on your site that this is not compatible with the Boostinator. Is this correct? Or did you mean for the non EVO rear hubs?
  6. #106
    Goat Wrangler
    Feb 2015
    PlanB,
    Thanks for the shout-out! We've only tested the HF kits with Hope's Pro 2 EVO hubs- I believe that the non-EVOs had the same hub shell but that there were axle changes. I think that the only change in the fronts was a shift to stainless bearings (in which case the HF would work), but as we haven't tried the combination can't swear to it. I hope that helps!
    Marc
  7. #107
    Jun 2015
    Hi Marc,
    Any updates on the Chris King hubs?
  8. #108
    Goat Wrangler
    Feb 2015
    Quote Originally Posted by kava72 View Post
    Hi Marc,
    Thanks for your interest. At the moment, we have no plans to pursue a Chris King model- their hubs don't lend themselves to a cost-effective solution. Sorry not to have better news,
    Marc
  9. #109
    Oct 2014
    Can someone link me to a front spacer kit for 15x100 to 15x110 on ebay? I cant seem to find it. THanks in advance.
  10. #110
    Formerly of Kent
    Reputation: Le Duke's Avatar
    Quote Originally Posted by Averbuks View Post
    Can someone link me to a front spacer kit for 15x100 to 15x106 on ebay? I cant seem to find it. THanks in advance.
    106mm?
    Is that a typo?
    Never seen a 106mm fork...
    Sent from my XT1585 using Tapatalk
    Death from Below.
  11. #111
    Oct 2014
    I meant 15x110
  12. #112
    Formerly of Kent
    Look at this on eBay http://www.ebay.com/itm/252191498198
    Death from Below.
  13. #113
    Reputation: manchvegas's Avatar
    Mar 2011
    So Ive got a question on the I9 conversions with dishing the wheel. I have a set of I9 32 hole standard jbend spoke hubs laced to NOX composite XCR 29 assymmetric carbon rims. Is my wheelset compatible with the conversion kit feom 142 to 148?
  14. #114
    Goat Wrangler
    Feb 2015
    Quote Originally Posted by manchvegas View Post
    As long as your wheelbuilder wasn't right on the margin spoke length wise, you're good to go- the 9TF and 9TR hubs will work with standalone Torch series hubs. I hope that helps,
    Marc
  15. #115
    Oct 2014
    Quote Originally Posted by jon123 View Post
    I went out on my first ride with the simple spacer kit from eBay while I await the dedicated end caps from Taurus mtb solutions.
    So 3mm spacer on either side and a 3mm spacer for the rotor.
    I could not notice a difference between shifting with this set up and on my previous 142x12 bike (everything the same - rear dérailleur, cassette, chain).
    Attachment 1037788
    Did you re-dish your wheel? Sorry for the novice question here is it correct to assuem that without doing so my cassette will be 3mm inboard? Meaning my chainline on my 1x11 will be even worse? Thanks in advance for the advice.
  16. #116
    Apr 2016
    Boost 148 adapters
    So, I used these spacers and they're great however my crank is moved out ward affecting my chain line too much.
    My bike has a PF30 fitted with a wheels mfg PF30 to shimano outboard BB. What BB do I need to move my crank back in 3 mm ?
  17. #117
    PlanB,
    Marc
    What about Hope Pro 4 hubs? Is there a difference in the hubs so you can't use the pro 2 adapters?
  18. #118
    Apr 2016
    Quote Originally Posted by PurpleMtnSlayer View Post
    FWIW I was able to get away with just 4 mm of rotor spacing with a Saint caliper on a pivot mach 6 C2. I was also able to re-dish the wheel mounted on the bike using just a standard caliper, a pencil and spoke wrench. I started by loosening the drive side spokes half a turn then tightening the non-drive side half a turn. The seat stays on the frame are symmetrical so I just continued to move the rim over a quarter turn at a time until the spread between the rim and seat stays was equal on both sides. I didn't have a spoke tension wrench to use so I just went on a quick ride and checked the spokes by hand. Lastly I used the pencil to mark any high spots and fine-tuned from there.
    If you want to do it in a truing stand just drop the wheel in the stand with the 6 mm axle spacer on the non-drive side and center the rim from there.
    When you dished your wheel did you do it for one on each side of the wheel or all one side then All the other ?
  19. #119
    Goat Wrangler
    Feb 2015
    Quote Originally Posted by philreske8614 View Post
    Phil,
    I'm probably biased, but if you have a compatible hub it might be less expensive to go to a Boostinator than replace your bottom bracket to correct your chainline. You'll get a stronger, stiffer wheel out of the deal and your pedals won't be offset either...
  20. #120
    Goat Wrangler
    Feb 2015
    Quote Originally Posted by BluePitch View Post
    BluePitch,
    The Boostinator HF and HR are in stock and now approved for use with Hope Pro 4 hubs: Boostinator ? wolftoothcomponents.com
  21. #121
    AKA Mr.Habanero
    Reputation: panzer103's Avatar
    Anyone use some of these Boost kits with Profile Elite hubs? Ive been trying to contact Profile about their own boost kits but they are being annoyingly quite about it.
  22. #122
    Reputation: Rngspnr's Avatar
    Feb 2016
    I have the Boostinator on my dt350 hubs. Works great had to re dish wheels which might be a pia for people who don't do there own wheel truing. Took about 20mins to do both wheels. Like Marc states it gives the spokes a more even angle. No shifting issues in drive train either. Great solution for this new coming "standard". Thanks Marc and Lindarets.
  23. #123
    Goat Wrangler
    Feb 2015
    Quote Originally Posted by Rngspnr View Post
    ...Great solution for this new coming "standard". Thanks Marc and Lindarets.
    Thanks Rgnspnr!
  24. #124
    Formerly of Kent
    How much lateral adjustment does the average brake caliper have?
    Wondering if 142x12mm DT Swiss 240 hubs could somehow work in a Boost 148 rear end.
    I'm wondering if you could use:
    1) 2x3mm thick spacers, one on each side
    2) centerlock to 6-bolt adapter with a couple of thin Syntace rotor shims between adapter and rotor
    to get the rotor far enough out, and the brake far enough in, that they'd function.
    Death from Below.
  25. #125
    Feb 2016
    The idea of 3mm spacers on axle ends will work, only consideration is the hassle it creates when taking wheels on or off. Lining up the spacers as you try to install your wheel seems like a headache to me. That's why I went with the Boostinator. The end caps become part of the hub. They also look factory being anodized black. Also moving your cassette inboard is a potential for shifting issues. I have M7000 drivetrain on my bike with a 50mm chainline and it shifts flawlessly. Better than my M875 xt derailleur does.
  26. #126
    Formerly of Kent
    The Boostinator isn't compatible with my Centerlock hubs.
    Death from Below.
  27. #127
    Reputation: Mcl2u2's Avatar
    Nov 2016
    Quote Originally Posted by Le Duke View Post
    Get 6 bolt adapters.
    That probably won't work for some reason, but you can run it on the front.
  28. #128
    Formerly of Kent
    Quote Originally Posted by Mcl2u2 View Post
    I have them. Using them doesn't change the relative position of the rotor unless you take additional steps to move the rotor outwards.
    Maybe I'm not taking something into account, but 6 bolt adapters allow you to run a 6 bolt rotor on a 142x12 centerlock hub on a 142x12 frame. That's it.
    Death from Below.
  29. #129
    Nov 2016
    Yeah I edited my post after thinking about that for a minute. I thought maybe you could add the Boostinator adaptor on top of the 6 bolt, but looks like the spline cap gets in the way.
  30. #130
    Formerly of Kent
    Yeah. I'm thinking/hoping/praying that I can get enough from a bunch of shims and the amount lateral adjustment in the caliper to account for 3mm.
    This is all just a theoretical exercise; I don't own any Boost frames, just want to have this stuff handy in my traveling repair kit in case I decide to hop on a Boost bike at a demo or something.
    Death from Below.
  31. #131
    Formerly of Kent
    Also of note:
    The CL to ISO/6-bolt adapters that DT Swiss provides have much, much longer "bolts" than Alligator or similar equivalents.
    Death from Below.
  32. #132
    Jan 2014
    I would really love to see a CL solution.
    In addition to 6bolt adaptors, need a new lock ring with deeper threads I think...
  33. #133
    Goat Wrangler
    Feb 2015
    Quote Originally Posted by Doingitright View Post
    Doingitright is correct- you would need an offset (by 6mm) Centerlock adapter and lockring. Unfortunately for the Centerlock fans in the crowd (myself included), we haven't seen the demand that would be required to tool up for a CL Boostinator kit.
    Like Rngspnr says, 3mm spacers on each side are a huge hassle when it comes time to remove and replace the rear wheel and already-marginal Shimano 11s chainlines are further compromised. We also can't endorse the use of our kit with threaded CL adapters- there are just too many pieces of the puzzle that we don't control to have the confidence to recommend their use in a safety-critical system.
    I wish that I had a better answer but the good news is that, especially with road disc exploding, DT 240s hold their value very well and when the time comes it should be no problem resell your hubs and/or wheels if in decent condition.
  34. #134
    Formerly of Kent
    Yeah.
    My plan right now is to use the wheels in question on a gravel bike. 1450g DT Swiss 240 100x15/142x12 + ENVE XC wheels are "older" but they are still a damn nice wheelset. They are in great shape, but since building up another wheelset, they've become my "backup".
    Death from Below.
  35. #135
    Reputation: Trailfreak's Avatar
    Dec 2004
    Can anyone tell me why Kings are left out of up boosting with spacers? I can't seem to find spacers anywhere for them.
  36. #136
    Feb 2016
    Quote Originally Posted by Trailfreak View Post
    If you look back through this thread I think someone mentioned on a Chris King hub you need to change the axle also. Post#84
  37. #137
    Dec 2004
    Can't find the thread you were talking about, but my user skills lack on this site.
  38. #138
    Reputation: stonedead's Avatar
    I am in the same spot-trying to come up a good solution for a King rear hub. I know someone else mentioned this, but the King hubs have a steel cover/spacer that slips over the axle at the ends. It seems like all you would need to convert the King hub would be to machine a longer spacer cover that slips over the axle.
  39. #139
    Dec 2004
    I almost think King has legal involved? I contacted defender and they don't make the spacers and would not say much else.
  40. #140
    Reputation: DeeZee's Avatar
    Jan 2005
    Good job! Wollf Tooth Front adapter for DT 350
    Purchased one of these adapters and have to say it looked like a DT Swiss OEM product. Put it on and dished the wheel.......just perfect.
  41. #141
    AKA Mr.Habanero
    ProfIle racing has been lame. They won't even respond to my inquiries about adaptors. They are really piss on me off..
  42. #142
    Reputation: terrible's Avatar
    That's a pisser about the King hubs. All they would have to is make a new axle and supply a NDS spacer. They could even go so far as to sell the spacer in whatever hub color you have.
    "I'm the fastest of the slow guys"
  43. #143
    Aug 2005
    Looking for a 'help me not break my ass' (or more importantly, bike!) conversion thoughts... I'm glad MRP is making a caliper adapter to Boost for Centerlock rotors up front, but they're not making them for the rear. I'm entertaining questionable hacks myself for the rear centerlock wheel. From an engineering/materials standpoint is it likely to overstress the frame mounts (carbon) or bolts, if I add another IS disc adapter next to the normal one, side-by-side, with longer, stronger horizontal bolts tying both IS disc adapters together to the frame, to move the caliper inboard ~6mm? (Actually looks like the adapters are more like 8-10mm wide... might have to machine one down, unless the caliper bolt holes do have enough play to compensate).
    No one has found a way to make any version of Centerlock-to-6-bolt adapter work? (by piggybacking them similar to above, or other...?)
  44. #144
    Reputation: jon123's Avatar
    Quote Originally Posted by Woodsy View Post
    I'm not sure this is accurate.
    I believe the MRP boost adapter is 6 bolt only -- NOT centerlock
  45. #145
    Jun 2015
    Can someone explain if there are any issues with running the universal type adapters? Velofuse makes them in most configurations. The boostinator type end caps are better when removing the wheel because the spacer is the end cap and it stays in place. But when installed on an enduro bike are the universal type lower performing?
  46. #146
    Aug 2005
    Current kit yes, but CL Front kit announced on the way
  47. #147
    would rather be ruined
    is the chainline issue only a thing if you fit a boost crank, this moves the chainline out 3mm a non boost crank and 3mm end caps means the wheel is undishished , the disc is moved 3mm out with a spacer but chainline is the same as 142? non/yes?
    , but your derailleur may/maynot have enought reach?
  48. #148
    I have done something similar with a DT 240s rear single speed hub, which is centerlock. I used two 3mm plastic washers from the hardware store, one on each end of the hub, then for the centerlock rotor I dug around in my LBS parts bin to find a very thin spacer (maybe 1mm thick) that fit over the centerlock splines. I sandwiched that spacer between the 6 bolt adapter and the hub. so instead of spacing out the rotor relative the the adapter, I spaced out the whole adapter/rotor assembly relative to the hub.
    Using that spacer I found that the adapter/rotor assembly only had to be moved outboard 1mm in order to have enough clearance for the brake caliper. The main issue is finding a centerlock lockring with the most amount of threads though; since those lockrings only have a few threads to start with, moving the rotor out 1mm also means 1mm less thread engagement for the lockring, which is a lot considering you only had about 3mm of thread engagement to start with.
    Whether this works at all would be highly dependent on your frame/caliper combo, too. For me this worked for a Trek Stache and XT M785 caliper.
  49. #149
    Aug 2015
    Any solutions for Stans hubs?
  50. #150
    still no update for chris king?
    has anyone tried the generic adapters for king hubs?
    Intense Carbine C
    Intense Spider 29 C
    Ventana El Comandante
    Borealis Yampa
    9:Zero:7 Al
    Soma Wolverine
    Surly LHT
  51. #151
    trail "cleaner"
    Quote Originally Posted by lifeis11 View Post
    I would really like to know if someone has purchased the kits sold on eBay (the ones with 3mm spacers) to be used on Chris King rear 142mm hubs... I'd hate to get rid of my CK wheels.
  52. #152
    Oct 2016
    I use a problem solvers 6mm NDS spacer and 6mm rotor spacer with my king.
    Works just fine.
  53. #153
    Apr 2013
    Great thread. I recently purchased a Top Fuel 9.8 (17MY) and I need to find away to convert my 12x142 / 15x100 240s and Enve over. They unfortunately are centerlock.
    Given that all the adapters are 6-bolt only for the rear, has anyone tried to do a centerlock to 6 bolt conversion, then using the hub adapters to make work? Anyone think that would be a bad way to go?
    I'd hate to see the 240 hubs go to waste...
    Thanks in advance!
  54. #154
    Quote Originally Posted by dubdubinto View Post
    Thanks in advance!
    see post #148
  55. #155
    Apr 2013
    Hey ta88, thanks for the callout. Did you consider an actual conversion for centerlock to 6-bolt (using the below item) and getting a boost adapter (boostinator, mrp, etc.)? That's what I thought about using.
    DT Swiss Centerlock Adapter > Components > Brakes & Shifters > Rotor Bolts | Jenson USA
  56. #156
    GUIDANCE COUNSELOR
    Reputation: NoahColorado's Avatar
    That doesn't fly, the DT CL to 6-bolt adapter is just a splined adapter with a lockring to hold the 6-bolt rotor. You can't space the rotor out with this. Plus, putting adapters on adapters sounds like a bad idea in general.
    We (MRP) are going to have a front Centerlock solution soon for Boost conversions, but rear conversions are a can of worms and not a product we're going to ever make.
    NOAH SEARS
    MRP - Brand Manager
    Pivot Cycles - Team Rider
  57. #157
    I am using a very similar CL to 6 bolt adapter. I only shimmed the adapter outward about 1mm. biggest issue was finding a locking with enough threads
  58. #158
    Thanks in advance!
    I've spaced out centerlock rear rotor by doing the following :
    1. Get a 2.5mm BB spacer, and fit it over the hub splines before putting on the rotor. Your CL rotor will now be spaced out by 2.5mm
    2. Get a machine shop to recess the outside of the centerlock rotor down by ~2.5mm. You will now be able to use your lockring, engaging all the threads.
    I wouldn't recommend going more than 2.5mm. Hope this helps!
  59. #159
    Reputation: griffsterb's Avatar
    May 2014
    Edit: All my questions were answered after carefully reading through the thread
  60. #160
    I thought about machining down the centerlock rotor, because there is plenty of material to remove off the lip... but then you'd have to do that for every rotor you ever had on the wheel. better always have a spare special rotor on hand.
  61. #161
    Apr 2013
    Thanks all!
  62. #162
    West Chester, PA
    I posted this in another thread. Re-posted for the people that asked about King hubs.
    ISO rear - They will never offer any sort of axle conversion. They do not want rotor spacers on their hubs.
    ISO front SD - They kept the bearing spacing the same for the boost hub. So you can swap their front boost hub axle into this hub and no rotor spacer will be required, just adjust the dish and you're good to go.
  63. #163
    Ole
    Ole is offline
    Quote Originally Posted by 92gli View Post
    So, having owned their old Universal Disc hubs, you HAVE to use a disc spacer with those hubs. They could make a spacer that bolts on to the hub with 6 counter sunk bolts, and have another 6 threaded holes in the spacer for the disc bolts.
  64. #164
    West Chester, PA
    Quote Originally Posted by Ole View Post
    Well, they COULD. But they WON'T. Although the design of the universal hubs makes the rotor issue a little easier, there is still the axle problem. Plus the market for such parts would be miniscule.
  65. #165
    Ole
    Ole is offline
    One could take the 157mm axle and machine the threads in to the correct position for a 142mm hub., and then cut the axle to 148mm and remove the unneeded section of threads.
  66. #166
    West Chester, PA
    For the 99.9% of people who aren't machinists, or have a close friend that is a machinist, that's a bit much. Yeah, I can hire a local machine shop but they'll either say no or quote a price so ridiculous that I'll leave.
  67. #167
    Jun 2015
    True.
  68. #168
    Reputation: 1-bar's Avatar
    Big thumbs up for the I9 boost conversion. I recently used the Wolf Tooth brand to convert my I9 Utlralites to boost standards and it’s a really clean looking solution. Plus it saved me bank over buying another wheelset.
    OPEN Cycles One+ in stealthy black
  69. #169
    turtles make me hot
    Reputation: NYrr496's Avatar
    I just got a set of Wolftooth adapters for my 135/100 Hopes to fit in my Krampus. Works mint.
    I like turtles
  70. #170
    Reputation: manwithnoname's Avatar
    Apr 2005
    For rear Centerlock, has anyone considered something similar to this?
    Name:  Screen Shot 2017-10-18 at 11.13.59 PM.png
    Problem Solvers Centerlock Adaptor for 6-bolt Rotors in Tree Fort Bikes Disc Rotor Adaptor
    Looks like this particular product is no longer available, and reading the description, it doesn't look like it was compatible with most centerlock hubs lol.. But still its an intriguing idea. Maybe it was just too sketchy to run without a lockring?
  71. #171
    turtles make me hot
    ^^ I don't think that will help in a boost application.
    I did use them once for the intended application and they worked fine.
    I like turtles
  72. #172
    ^^ I think it could work but you would need to pair it w a boost spacer kit. With that said, it would be a mess putting an adapter w a spacer kit. Not ideal at all but it is a potential option.
    There are a lot of centerloc adapters on eBay.
  73. #173
    Apr 2013
    I have no clue how reputable this would be, but has anyone tried this:
    https://r2-bike.com/NOW8-Conversion-...k-12x148-Boost
  74. #174
    Apr 2005
    ^^ Nice find! That looks like a perfect solution, might have order one just so I'm future proof.
  75. #175
    Reputation: JokerSC's Avatar
    Quote Originally Posted by NoahColorado View Post
    Hi Noah, Do you have a time table for when MRP might be offering the front center lock option? Thanks!
    RideMFRide
  76. #176
    Reputation: spookyload's Avatar
    When talking wheel dish, wouldn’t it be better to tighten drive side one half turn and loosen non-drive side? Seems like it would keep from increasing spoke tension on the drive side needlessly.
  77. #177
    Jun 2015
    Boost 148 adapters
    Quote Originally Posted by spookyload View Post
    I’m just randomly dropping in with a reply to this post. Not sure what’s been discussed. But yea. Dishing is super easy. A 1/4 or 1/2 turn all the way around and on both sides can move the rim pretty far laterally. Before you start you want to lube all the nipples, trying to get it down in the threads and around the spoke bed. You want to start with loosening the side you want to move away from then tightening the side you want to move to. It’s super important to not just go all the around tightening or loosening but to skip a few spokes as you go around, eventually getting to all the spokes. This will ensure the wheel stays radially true and reduces spoke twist and fatigue. Twist is something to look out for when dishing. Making little flags with tape on all the spokes is a great way to know if you’re getting spoke twist and tells you how far to unwind to get back to the starting point.
  78. #178
    Ride On
    Reputation: geraldooka's Avatar
    I now find myself in a position to need to use a boost adapter set.
    Has anyone had success with the simple 3mm either side with 3mm rotor spacer? I can't imagine 3mm negatively affecting the derailleur and presume chainline remains the same with my existing non boost 1x crankset/chainring which I plan to transfer over... Thoughts?
    Michael
    Ride on!
  79. #179
    Land of the 230+
    Reputation: GuitsBoy's Avatar
    Sep 2013
    Quote Originally Posted by geraldooka View Post
    I'm running 3mm/3mm spacers, and only needed 1mm brake rotor shim. Both 11 and 12 speed derailleurs have plenty of throw to cover the extra 3mm. In the SRAM world, running a 6mm offset chainring is ideal, but I had to move to a 3mm offset boost ring for chainstay clearance.
    Anyway, I have 500+ miles on the setup, and not a single worry at all about using adapters. I did RTV the adapters into the frame recesses just for ease of rear wheel removal and re-installation.
  80. #180
    I have been running that with a Shimano 1x10 drivetrain plus a one-up 40T cog. No problems at all. Your wheel remains centred, so the chain line is unchanged.
  81. #181
    That Now8 centerlock converter dubdubinto mentioned looks VERY interesting. Hope it’s the real deal. Couldn’t find any review of it.
  82. #182
    Feb 2014
    Hey guys,
    Is there any hope I can convert my old sram X-9 142mm hub to boost with on of these kits?
    MY HUB = https://www.chainreaction.com/produc...b-227422-1.htm
  83. #183
    Quote Originally Posted by chaddwick25 View Post
    Hey guys,
    You sure can!
    Without dishing the wheel, go for the 3mm + 3mm spacers. That'll bring you from 142 to 148 width.
    You'll need a 2-3mm rotor spacer to align your brake rotor with the caliper. Your RD will have to be adjusted 3mm inwards (adjust cable + both limit screws.) Good luck!
  1. Boost Standards 110/148 and adapters
    By PHeller in forum 26+/27.5+/29+ Plus Bikes
    Last Post: 02-13-2017, 09:20 PM
  2. 26 with boost?
    By clbaumer in forum Fat bikes
    Last Post: 08-16-2015, 08:03 PM
  3. 26 and 148 Boost?
    By ehigh in forum 26
    Last Post: 06-30-2015, 01:57 PM
  4. Want an ego boost - look up your name here
    By CHUM in forum Off Camber (off topic)
    Last Post: 01-08-2014, 05:07 PM
  5. VO2 BOOST**anyone try this yet??
    By iwantalitebike in forum Nutrition and Hydration
    Last Post: 07-13-2011, 08:47 AM
Members who have read this thread: 182
