Results 1 to 78 of 78
    Reputation: Drth Vadr's Avatar
    Black Chili in new Trail Kings 2.2?
    Does anyone know if the trail king 2.2 coming with black chili? I still haven't decided on the TK/RQ or the Ardent 2.25 and this will weigh on that decision. If any opinion between the two it will be much appreciated.
    g3h6o3
    Reputation: PissedOffCil's Avatar
    Oct 2007
    Mmmmmmm chili!
    Edit : Answer from Conti's site : "Rubber Queen 2.2: 3 plies / total 180 tpi / foldable / Black Chili Compound / Handmade in Germany"
    Check out my SportTracks plugins for some training aid software.
    Reputation: Dex11's Avatar
    May 2005
    In the Race Kings, the Black Chili makes all the difference..they feel like Velcro !
    Dec 2009
    Ardent 2.25 would be a world a part from a 2.2 trail/rubber queen even without black chilli. I've got Geax Seguaro which has better cornering grip than the Ardent, and the Seguaro is certainly no All Mountain tire like the trail/rubber queen.
    Dirt Deviant
    Reputation: savagemann's Avatar
    The only RQ/TK available in the USA with black chili is the 2.4.
    No 2.2 black chili.
    I believe they have them across the pond though.
    Look, whatever happens, don't fight the mountain.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by Drth Vadr
    The standard TK 2.2 is Black Chilli, The UST/Tubeless TK 2.2 is not.
    mtbtires.com
    Alt-132
    Quote Originally Posted by shiggy
    Darn, it looks like I'll be waiting even longer to try the Trail King/Rubber Queen. As soon as they make a 2.2 UST or tubeless ready with Black Chili, I'll buy a pair.
    Dec 1998
    There is talk the 2.2 UST may be Black Chilli soon. Now they just need to put a hot stamp on the sidewall so we can tell which are which.
    mtbtires.com
    Dirt Deviant
    I recently talked with someone from Conti, and they told me there was no 2.2 TK in the USA in Chili.......hmmmm
    Dec 1998
    Quote Originally Posted by savagemann
    I have RQ 2.2 w/BC. Double checking on the current TK status.
    mtbtires.com
    CHOP!
    Reputation: MartinsMental's Avatar
    Dec 2005
    ...Interested in this...
    Black Chili in the 2.2 UST would be pretty much amazing...
    It's not where it's made but how it's made.
    Bike Breaker.
    Thinking of Rubber Queen up front and MK out back. Running rim-strips for tubeless set up (traversee) which versions would be successful with Stans?
    Religion = Non-thinking
    Reputation: louisssss's Avatar
    My lbs spoke to their conti rep in the us and confirmed the regular 2.2 TK has black chili
    RH SL Pro
    Dec 2009
    To end all the speculation about black chilli on these tires ,just bypass the RQ/TK 2.2 and go straight for a Nobby Nic 2.4 Triple nano compound for the terrain you are talking about. As big as the 2.4 RQ/TK as light or lighter than the RQ/TK 2.2, even with snakeskin sidewall protection, better ride with the bigger volume[ it's huge] , better rolling resistance[ very quick for a big tire],probably better grip and cheaper. What more can you ask for!
    Going by those stats I'm not sure the RQ/TQ deserves all the latest attention it is getting on this forum.
    http://www.bikeradar.com/gear/catego...-nic-24in-9271
    That's what I'm talkin about.
    Quote Originally Posted by gvs_nz
    where can u get the schwalbe tire cheaper than $45?
    RH SL Pro
    Dec 2009
    That's a good price if you can get rubber queens with black chilli for $45. I have got Nobby Nic 2.4 evo snakeskin from across the ditch at wiggle Uk for $48. Buy two and you get frree shipping.
    In Germany this is how the prices stack up.
    rubber queen 2.2 folding black chilli $58
    rubber queen 2.2 UST no black chilli $44
    MK 2.4 protection black chilli $48
    MK 2.4 supersonic black chilli $42.25
    RK 2.2 supersonic black chilli $44
    nobby nic 2.4 triple Nano $48
    So $45 does sound cheap in comparison, unless the new Trail kings for the USA market are a std folding Indian made one and they are now using black chilli?
    Reputation: crank1979's Avatar
    Feb 2006
    Did you read the downsides in that article?
    I prefer the RQ to the NN. The NN wear too fast, don't grip as well as the RQ for me and the sidewalls are too thin.
    Dec 2009
    Quote Originally Posted by crank1979@optusnet.com.au
    I suspect both tires are pitched at different markets. The RQ 2.2 is all mountain/trail crossover little brother of downhill/all mountain RQ2.4. The NN 2.4 is XC tire on steroids for the xc/ trail crossover. So when used as intended the NN 2.4 lasts ok. I don't care anyway as it just comes out of the beer budget. It's all entertainment, drinking or riding
    The 2.4 NN is only available in snakeskin so sidewall damage is now limited. I've got black chilli tires and they also wear very quickly. I suspect the RG in black chilli being similar? The RQ does have longer ridge style knobs so I suspect will not tear or wear as easily as NN smaller block style knobs?
    Bicyclochondriac.
    I would want to see measurements to believe the NN 2.4 is as big as a RQ 2.4. The RQ 2.4 casing is MASSIVE.
    In regards to Black Chili vs Triple-Nano, I have used tires with both triple-nano compound, and IMO, Black Chili is better. Better grip on wet surfaces. I have three Black Chili tires (RQ 2.4, RK 2.2 SS, MK 2.4 Prot) and so far I find that they stick like a soft tire, but wear like hard ones. After about 12 or so, my RQ still has all of its "whiskers", even on the center tread. Granted, it is on the front, but that is still pretty durable rubber to do that. My MK 2.4 protection has about 9 months in the rear and is wearing as well as any tire I've ever owned on the rear.
    Also, similar to the Big Betty, you can run the RQ at very low pressure without it rolling/folding in turns, due to the thickened sidewall near the bead. The Big Betty is similar in this respect.
    trail kings 2.2 black chili will exist. I saw in some forums that they showed them at taipei bike show...
    Dec 2009
    Quote Originally Posted by kapusta
    NN 2.4 stretched overnight at 40 psi casing width 59mm tread 60mm. Give it time to stretch it will be over 60 mm.
    MK supersaonics after 2 rides centre knob ridges worn smooth. NN still look prestine?. I think Black chilli gives someting like 5 to 10% more life than normal soft compound according to continental. Not ground breaking and not the same as hard compound. NN uses dual compounds[harder in the centre] it appears that continental do not vary black chilli compound across the tire? They do however change balck chilli across tire range. MK may be designed for soft conditions so may have one of their softest compound black chillis?
    Bicyclochondriac.
    Mountain King 2.4 Protection after about 9 months of rear use: I cannot remember the last time a tire still looked this good after 9 months on the rear. Most are about done at this point.
    Rubber Queen after around 12 rides, still got the whiskers:
    Race King 2.2 SS after about four months of rear use (maybe 20 rides). They still have the little ridges around each center knob.
    I have a very hard time believing anyone could call any of these fast wearing. The MK and RK have both held up at least as well as any tire I have run in the back.
    Bicyclochondriac.
    No, they do not vary the compound across the tire, because they do not need to. My photos above show why. They absolutely wear as long as hard tires. You get that sort of longer wear, but the benefit of a tire that is NOT hard in the middle, and superior wet traction is a result, without the wear of typical softer tires. I do think they vary it from model to model, however. I think the RQ is softer than the others.
    I've used triple nano-compound, (Fat albert) and I am not too impressed. Not bad, but just another dual tread as far as I was concerned.
    Also, my RQ measures 61mm at the casing with 21mm (inner diameter) rims, and I am having a hard time the NN measures 60mm at the casing with similar rims unless it is sporting some seriously tissue paper thin sidewalls at the weight you are talking about.
    I beg to differ wrt to the Mountain kings. Absolutely the worst tires i had ever used. Knobs fell off after 2 rides. zero pinch flat protection. thin sidewalls. bad grip.
    the rubber queens i have are awesome stuff. like what u said
    Dirt Deviant
    Quote Originally Posted by Jhanney
    Which version Mountain King did you try?
    Was it the Protection? Wire Bead? Regular Folding? UST?
    This makes a huge difference.
    I ran a wire bead set just to try out the tread pattern before commiting to buying the protections. They were absolute garbage. But I love my Protections.
    Dec 2009
    Original post is for xc trail type tires not down hill. I have no experience with triple nano when used for all mountain/downhill. Continental website says black chilli varies from model to model. My Mountain king 2.4 supersonic looks like that after 2 rides on the front wheel so maybe the protection has a harder compound than supersonic as it is targeted at all mountain use?
    Here's the press release from Conti. Black chilli gives 5% increased tire life.
    http://www.conti-online.com/generato...kchili_en.html
    NN 2.4 is 59mm across the casing. Calipers don't lie. Measured on DT swiss 5.1D rims[28mm]. I measure all my tires at 40 psi. Reduces to 57mm at 25psi. Haven't got a RQ to compare with but i have race kings and like the race king, the RQ 2.4 could be a much higher profile tire than the NN ? This gives illusion that it is wider than it is ?
    Schwalbe have broken the mould on their latest incarnation of their 2.4 xc/ trail tires. They actually measure true to size unlike their smaller sizes. I have a racing ralph 2.4 and it measures 58/61mm and actually has reasonable edge grip for general use at that size.
    Not saying triple nano is anything special. But black chilli is not the magic bullet. I've got a wire bead Barro mountain which i've been trying to kill all season and it is hardly showing any wear at all[ less than the mountain king] and i have been using it on the back. it is geax sticky soft compound which grips wet tree roots very well.It was a $10 bargain bin tire. Tread shape and spacing has a lot to do with grip and tread life.
    Bicyclochondriac.
    Yeah, I've got the standard folding version on my 29er, and it is a pretty mediocre tire, and wears pretty fast. Nothing at all like the Black Chili Protection pictured above.
    Bicyclochondriac.
    Where did the OP specify xc, rather than AM use?
    I checked that link, and I think you are missing the point. They don't say 5% more than soft tires, they are not really specifying what they are comparing it to. I think the point they are making is that it is softer AND more long lasting than standard compounds, which in my experience owning three BC tires is a very legit claim, and IS actually a pretty significant development in tread material in mtb tires. Magic Bullet? Well that is a bit dramatic, but it is very significant.
    I cannot explain your experience with the MK SS, but something sounds a little fishy to me in the claim that it looks like my Protection version above after only 2 rides on the front. If it were a standard (non-bc) I could possibly believe that (those are pretty bad), but I have to be honest, I'm really not believing this claim. To address speculation on its intended use, the SS is definitely NOT intended for the AM market.
    No offense to Geax, but I am very suspicious of the claim that a soft rubber compound run on the rear for a full season (if by "season" you mean riding year) is hardly showing any wear.
    Bicyclochondriac.
    I run a RQ/TK 2.4 on the front right now, and use an Ardent 2.25 on the rear last summer / fall.
    Black Chili questions aside, these are pretty different tires. The Ardent (the 2.25, at least) is a fast rolling tire that corners really well, but it gives up a bit of drive and braking traction for that low rolling resistance. Also, I find that sparse intermediate zone can sometimes get me off-guard on wet surfaces, with the tire kicking out sideways when hitting some off-angle roots or rocks. A concern with any tire, but I notice it with the Ardent more. This is not that big an issue to me on the rear, but it has me leery about running it in the front. I think the sparse intermediate zone is what lets the side knob bite really well when leaned over. Overall, I think it is a really good rear tire in the drier months, and will likely be going back to it a month or so. It wears really well, too. My only complaint is that the tread is too hard, overall. It would be great to have that in a dual tread compound, with just the center tread being hard rubber.
    Also, the Ardent is a bit thinner in the casing, at least compared to the RQ/TK 2.4. Could be a good thing or bad, depending on if you are looking for toughness or durability.
    If you are able to get the RQ/TK 2.2 in black chili, it will positively spank the ardent on any wet surfaces.
    I don't have the 2.2 RQ/TK, but from what I gather, it is a very similar tread to the 2.4, which would tell me it is slower rolling, but have pretty good drive and braking grip. I can't speak for the cornering, as that could well be different in different sizes.
    Dec 2009
    I've tried the Ardent and sold it after a couple of rides. Scary in the front with anything but a ight coating of soft over hard and didn't roll that well either .I've got 2.1 tires which corner much better and have amuch more compliant ride.It was ok on the back as the por edge edge grip you could weight shift on the pedals and make the rear end step out for tight corners. I try a ot of tires and it didn't kae the grade so I sold it. I didn't like the captain but it was a better tire for the same weight.
    Dirt Deviant
    I haven't tried the Ardent before, but I did run a set of RQ 2.2 UST for a bit.
    It is absolutely amazing with drive and braking traction.
    Cornering traction is very predictable, as well as it's breaking point.
    We have alot of chunky rock sections that lead into baby head rock gardens. Alot of them seem to be leading into turns. The RQ is a joy to have on the bike when hitting this stuff at speed.
    My first run on them I must have hit several 2 wheel drifts through these rocky, wide switchback turns and never felt like I didn't have control, which is great to have such a controlled feel on a set of tires that I'd never tried before.
    So far I'm sold on the MK 2.4 Protections as I have run them from the end of last summer until now.
    They seem to do great in all the conditions I have run them in.
    From loamy damp forest littered with off camber moss covered roots and rocks, to sandstone outcroppings, deep sand where my nevegals used to completely give out, chunky clay, hardpack, deep mucky mud, river crossings with lots of slippery rocks. I haven't really found a condition where they don't do well. Even over wet leaves and pine needles. The only thing that get me with the MK is 1 section on our regular ride which is really steep and narrow, with large marble sized rocks. Braking can be a bit scarry coming down this 42 percent grade as things dry out.
    I am switching over to the 2.2 TK from here through the end of summer. As it gets drier and the dirt gets more powdery, I think the TK will hold on a bit better braking down really steep sections.
    I also got a set of TK 2.4 for Downieville and Northstar visits this summer.
    1 thing I noticed about the MK, is it's performance is very dependant on PSI. The lower the better.
    I found the sweet spot for me is about 25-28psi front and 28-30 rear.
    I was pushing my front as low as 22psi this weekend and rolled the tire twice and ate $hit........hahaha
    The TK seems much less sensetive to pressure. I run those closer to 30f 35r
    Dec 2009
    THe 2.25 Ardent was narrow with tread width at only 2.15.The 2.4 Ardent seems to get better press.As in most brands there is usually a jump in tread size for the 2.4's. Better comparison and possible match for the 2.2 RQ. Both OTT for normal xc trail riding IMO. But I come from a xc race background and are used to slipping and sliding on minimalist rubber.
    Reputation: mnster's Avatar
    So does anybody know where I can get a pair of 2.2 RQ or TK black chilli's online?
    err, 27.5+
    Reputation: AL29er's Avatar
    Quote Originally Posted by mnster
    BikeBling and a good price to boot
    Several others, just google or bing to find others. BB's price will be hard to beat.
    Quote Originally Posted by saturnine
    that's the stupidest idea this side of pinkbike.
    Reputation: Bikeon's Avatar
    TraiK king
    Please to correct the title of the topic.
    Reputation: Bubba74's Avatar
    Feb 2007
    Quote Originally Posted by AL29er
    BikeBling and a good price to boot.
    I just ordered a 2.2 RQ from them. I called to make sure it was black chili and they said it was. I'll let you guys know when I get it. That price is awfully low
    Dec 2009
    check when you get them that they are made in Germany. If not , then it isn't black chilli.
    Feb 2007
    Thanks for the info. I am already aware of this. I found out about it when I ordered my MKs last year
    Thanks for the comparison. I was looking at the Adrent solely as a summer tire that rolled fast. and was soft. Looks like I'll still be looking.
    I'm almost positive that Continental made two limited RQ UST 2.2 in chili. First was a pink tread for breast cancer awareness and later in red.
    Thanks, I swear I've been looking for them the last 5 months using every search engine imaginable. Nobody had the 2.2's in stock. But, just ordered a set today FYI the REALDEAL coupon code gets you 10% off as well.
    low speed, high drag
    Just got my 2.2 TK's from BikeBling that I ordered months ago. Yes, there is plenty black chilli to go around. Excellent tires. Definitely worlds apart from the Nevegal...
    Reputation: ridetheridge's Avatar
    Can anyone comment on a comparison with these RQ/TK 2.2 blackchili with the Excavators in terms of rolling resistance and grip ? Sir Shiggy, I know you've ridden these two..
    Ouroboros.. you mention "worlds apart".. in terms of what ? Rolls faster than the Nevegal and provides as much or better grip ? More volume ?
    Dirt Deviant
    Well, we got the TK 2.2 in at work today, and they DO have Black Chili...........Ahh, I love the smell of fresh Contis.....= )
    Quote Originally Posted by ridetheridge
    Yeah, roll resistance is a lot lower. Don't have a lot of experience with high end tires. Nevegals and Moto raptors are all I really have to compare to, but these are definitely my best tire to date. Tread width is the same as my moto raptor, but the casing is huge. Lots of volume. These look more like 2.3, 2.4 tires. Took a brief ride in the rain over some roots, berms, etc and I was pleased. Looking forward to my first real ride on them this weekend.
    Bike Breaker.
    Have a set of RQ 2.2 coming this morning, trouble is wont be able to get out on them because of night shifts. Been a long time since I got excited about a set of tires (apart from Vittoria Pave).
    Reputation: Tinshield's Avatar
    WUT?? Do you ride on sandpaper. The MK's are one the favorite tires in our group. Very good grip and they wear fine.
    Quote Originally Posted by Tinshield
    he probably got 1 flat, and had a bad experience. single instances dont tell anything,
    RH SL Pro
    Mine came in today. 766grams yikes so much for the stated 650grams. Volume wise they are a little smaller then my 2.4 Mutano Raptors. Tire looks rather tall and narrow and measured a little under 2.2 wide with the caliper. Time will tell how they work.
    Feb 2007
    Just got my 2.2 TK from Bikebling and they are indeed Black Chili. The order says "rubber queen" denoting the old name, but my TK is def BC
    ^^ got some pics of it on your bike?
    RH SL Pro
    Feb 2007
    My bike is at my girlfriend's house. I can take some pics tomorrow. I got the 2.2 TK on the front and my old 2.4 MK protection on the back. Did my first ride yesterday. So far so good, but not enough ride time to give a full review.
    Quote Originally Posted by Bubba74
    nice combo of tires, why did u chose this combo? i had something similar in mind, but something like the 2.4MK protection was too wide for my XC riding and had too much rolling resistance.
    RH SL Pro
    Feb 2007
    Actually the tire choice was more of quick switch for the terrain I am riding. I originally had the MK 2.4 on the front and a Maxxis Ardent 2.25 out back. I ride in the northeast with a ton of roots and rocks. It was a little slick yesterday so I wanted something a little more aggressive and tacky than the Ardent. I don't know if I'll leave the MK on the back or not. We'll see....
    i ride in the NE also, NY/NJ/PA fyi. It is very wet here and can get muddy. why not put your 2.4MK in the front (better handling) and your 2.2TK in the rear (slimmer profile, lower rolling resistance)
    RH SL Pro
    Bike to the Bone...
    Reputation: rzozaya1969's Avatar
    I had some Nobby Nic 2.4 w/snakeskin front and 2.25 Evo rear, and it was, for me, one of the tires that I've liked the least, I think I only did like 3 rides on the front, then replaced it with a 2.35 Stick-e Nevegal, and then replaced both with 2.4 RQ with black chili, and, the RQ are, for me, the best tires for the terrain that I've ridden, I haven't tried them on thick mud, but everything else they're golden.
    Bike to the Bone...
    Chain Reaction, I've just orderd a 2.4 and 2.2 RQ (or TK).
    http://www.chainreactioncycles.com/M...?ModelID=29789
    Feb 2007
    Quote Originally Posted by louisssss
    Do you think the TK has lower rolling resistance?
    Anyway, I gotta say I'm not too excited about the MK protection in the front. It's pretty good in almost anything, but not great at any single thing. I put the TK in the front because it's supposed to have a softer black chili compound. IMHO it's about the same size as the 2.4 MK. I may try switching it to see the difference. At $40 at bike bling, I may just get another 2.2 TK for the rear
    FYI I live in central NY and ride in Saratoga all the time (very techy, rocky and rooty). I've also ridden Ringwood and loved it and plan on heading out to Blue Mountain this year as well.
    nice, it looks like we do different kinds of riding, you're more AM/DH or somewhere inbetween that. i'm more XC/hardpack/easier stuff.
    Thats probably why i got the 26x2.2 MK Protection for my F&R.
    RH SL Pro
    Dec 2009
    [QUOTE=Bubba74]Do you think the TK has lower rolling resistance?
    [ I put the TK in the front because it's supposed to have a softer black chili compound. ]
    I know the 2.4 RQ/TKhas a soft version of black chilli because it is a downhill competition tire like the Minion DHF. The 2.2 has a harder black chilli.than the 2.4. Is the the 2.2 RQ/TK a softer black chilli than the 2.4 MK?
    Saving lives with knives.
    Reputation: frank daleview's Avatar
    I have a MK 2.4 and a TK 2.2. The TK is a little smaller than the MK. Both are bigger than my favorite rear tire: the Vertical pro 2.3. I wanted to used the MK as a rear tire on my fango, but the knobs occasionally hit my rear triangle, so I opted to for the TK which by the looks of it seems to be very well suited for rear tire use. I'll post after a few rides on it.
    Formerly known as iceaxe
    Feb 2007
    Not 100% sure, but I believe the 2.4 and the 2.2 are the same. Both have the same compound and the apex sidewall.
    Dec 2009
    Just curious because Chain Reaction say differing compounds and side walls in their add. They all get it wrong plenty of times though. I know Continental website say only 2.2 tubeless has apex side walls so CRC have at least got that bit right.
    They could get away with a softer compound on the RQ/TK though as the MK side tread flex gives it grip as well as the surface contact grip technology that black chilli gives.
    Dec 2009
    Maybe trail kings sold in USA aren't Rubber queens after all? Previous posts on rubber queens made in Germany were down below 650gms. Maybe they have increased the tread or casing size on the Trail kings?
    Continental have just updated there international site with latest black chilli details for Rubber Queen, so Rubber Queens are still current and are still stating 650gm. It's not unusual for tires to be different to OEM specs but not that different.
    Any ride reports on these yet ? Rolling Resistance, Grip, corning etc ?
    Based on the lack of side nobs it looks like the front end could be prone to washing out...
    Bike to the Bone...
    I think that the first lot of RQ in 2.4 size were around 750grms, for the second lot Conti made the sidewalls a little more strong, and went to 850. And that's the advertised weight, not by users, I think.
    I would love to have the 2.4 RQ or TK at 650! Regardless of weight, these are the tires that I've tried that suited me the better, I don't regret having them one bit!
  67. #67
    Dec 2009
    Mnster was talking about his new 2.2's not 2.4's being 766gms . Just shows you there is still a lot of confusion out there about these tires. There is no OEM info on Trail kings. Maybe it's a cunning marketing ploy by Conti. to create discussion in forums.
  68. #68
    Yeah these are definitely all mountain tires. The carcass is very thick and meaty. They make every XC race tire I've ever owned look weak. Correct on my 2.2's TK BC Kevlars being over 100g over weight. Rear weighs 761g while the front weighs 766g. Figured it was worth mentioning in this thread for the WW's among us. I'm a little disappointed with the weight of the tire. Also the vibe that I've seen on the forums that stated these tires are huge, they honestly really are not all that large in comparison to their competitors. If I knew at the time of purchase what I know now I would have most likely went for the 2.4's
  69. #69
    wuss
    Reputation: dropadrop's Avatar
    That could mean they would work better in a ghetto tubeless set up.
  70. #70
    Yeah I wouldn't hesitate to try to run them tubeless. They mounted up snug on my ZTR Flows.
    Did a little ride today. I'm very impressed with the trail performance. They rolled nicely for a aggressive tire. Had a nice firm bite on the loose stuff I usually ride on. Very predictable tire I could really put some trust into it in the corners. On the hard pack or pavement they felt a little sloppy because the lugs were so tall. Yet they still rolled better then I would have originally thought. I couldn't feel the weight when pedaling but I could feel the additional weight on the down hills and at speed as the bike was had notably more gyroscopic force. As others have said these tires throw stuff I went through a sandy wash and was blasted by sand. As a loose conditions tire these are awesome.
    These tires have girth but are still narrow from above.
  71. #71
    Reputation: wormvine's Avatar
    Dude WTF is in front of your tire on the ground in the 3rd pic?
  72. #72
    gravedig... I've 'read somewhere' the 2.2 UST now ARE black chilli. Can anyone confirm/deny? The conti website is useless & seems to be permanently a year out of date.
  73. #73
    Perpetual Hack
    Reputation: mykel's Avatar
    Heard the same thing about a running change; that the 2.2 ust are now BC. It was on one of the other boards about a month ago. Don't remeber the board. Have heard nothing else, so still just hearsay / rumour...
    michael
  74. #74
    ups and downs
    Conti still don't appear to be letting their secret Black Chili compound loose in their Asian plants, so unless it says Made in Germany it almost certainly isn't Black Chili.
  75. #75
    I got TK BC 2.2 from Performance for $34.99. I replaced my RK SS in the front
    with TK BC and my Trance X weight jumped from 25.4 to 26.02 pounds. The extra weight
    is worth trade off for not washing out. I'm running RK SS 2.2 rear.
    I still have to try them.
  76. #76
    Reputation: Tim-H's Avatar
    Been looking at these tires for a while. I'd like them for a tubeless setup but want the 2.2s and black chili. Does anyone have an opinion on running the non 2.2/black chili on a tubeless setup(UST rim)?
  77. #77
    To bump this thread, anybody running the non ust 2.2 Trail kings (black chili) tubeless a la stans? Or would I be better off with the UST version of the tire?
    I've had great success with converting the 2.4s, and wanted to try a 2.2 on the rear.
  78. #78
    Reputation: castnblastut's Avatar
    New question here.
    Second the bump, I was just gonna post-up asking about the UST 2.2 in Black Chili rumor. I would buy a pair today.
    Locally I got 3 different answers from 3 shops. One shop that sells a lot of Conti's even swore Conti is going away from UST / Non-UST specific as soon as current inventory runs out and will build models with a slighty beefed bead that will mount either. Logic being that you don't need the sealed casing because everyone runs sealant anyhow. Just what the mech @ one shop said.
    Intel appreciated.
