Results 1 to 14 of 14
    That's right....
    Reputation: Jersey's Avatar
    BIGGEST volume 2.0-2.1" XC tire
    my pythons have a real good volume for a 2.0
    which other tires offer BIIIIG volume for a 2" size
    No good in rock gardens..
    Reputation: Sideknob's Avatar
    big 2.0's and 2.1's
    Hutchinson Spiders, Scorpions, Kenda Nevegal 2.1s, Tioga Extreme XC 2.1.
    Kenda Karma's aren't bad for a 2.0 either.
    Less isn't MOAR
    Reputation: shiggy's Avatar
    Dec 1998
    Most current Specialized tires, especially the Resolution (Adrenaline) and Fast Trak.
    mtbtires.com
    That's right....
    Quote Originally Posted by shiggy
    yeah, thats what a couple people have told me. unfortunately ive never been a big fan of specialized tires. ive always found them to be terribly slow
    Dec 1998
    Why does it have to be a 2.0-2.1 tire? Just pick the tire with the volume you want regardless of the numbers on the sidewall.
    mtbtires.com
    That's right....
    ahh yes, i should have added that i was looking for a 2.0 sized tire trying to keep weight an issue i dont need anything bigger than a 2.1 for my riding and anything bigger than that will just bring more weight with it.
    thats why ive always been fond of the pythons - 2.0, 480g, BIG volume, fast
    so basically im looking for something with similar specs.
    Dec 1998
    Not true and does not make sense. The MutanoRaptor 2.4 is lighter than many "2.1" tires. The Schwalbe Fast Fred 2.35 Is bigger than the Mutano 2.4 and weighs less, under 530g.
    Many 2.0-2.1 tires are larger than other 2.3-2.4 tires.
    Ignore the labels and buy the tires.
    mtbtires.com
    Dec 2005
    Quote Originally Posted by Jersey
    Highly reccomend the adrenaline, 630g and VERY large volume...Biggest 2.0 I've seen so far.
    Reputation: flipnidaho's Avatar
    Yo Shiggy
    I've ridden the Mutano 2.4's and I really like them for a front tire but I was wondering how the Schwalbe Fast Fred 2.35's compared with the Python 2.3. I was thinking of using it as a rear tire on my 575 (currently using Python 2.3's for the rear).
    Neg reppers r my biatches
    Reputation: FoShizzle's Avatar
    speaking of Resolutions Shiggy....I thought it was funny when I went to pick mine up a couple of days ago. The tire does indeed say Resolution but the packaging still said Adrenalin which confused the shop guys till i tried to explain that had happened best I could. Looks like a sweet tire....only got one for the rear but will probably get one for the front. I was impressed with the volume too.
    cheers
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Yes, and due to the lack of tread, it also doesn't have as much traction as some 2.1 tires either...
    Dec 1998
    Quote Originally Posted by flipnidaho
    MUCH thinner (road race type) casing (the 2.3 Python uses a DH type casing). Almost no tread (works great on hardpack and sand).
    mtbtires.com
    Dec 1998
    Quote Originally Posted by Jayem
    Which can be said of many other tires, too. It depends on the conditions and your needs.
    The point is still ignore the stated size and pick the tire for its actual characteristics.
    mtbtires.com
    That's right....
    i give up
    thanks everyone
