Results 1 to 2 of 2
    Oct 2014
    Best tires for tubeless ZTR Crest wheels and hard AZ desert riding?
    I currently ride on Maxxis Ignitors on my Tallboy with ZTR Crest wheels in a tubeless setup, and I am looking for new tires. I've gone through a few Ignitors, and I recently took off the front tire to clean it remount it because I was losing air almost daily and I was able to remount it onto the rim way too easily -- almost as if it had stretched. I'm assuming this is due to the tire getting old?
    My rides are on the McDowell mountains, and the terrain is very loose rock to hard jagged rocks, very little little sand or dirt. I've had a few sidewall cuts on the Ignitors from sharp rocks, and I am looking for new tires. I don't race, and am not a speed junkie, I'd prefer durability and something that is cost conscious.
    What recommendations would you guys have for tires that fit this situation? I know I can get ignitors for about $45-50, but is there something out there that is just as good or more durable for cheaper that I can run tubeless on the Crest wheels?
    thanks.
    mtbpete
    Reputation: changingleaf's Avatar
    Most tires will stretch after having been mounted on Stan's rim for a while. The bead seat on the Crest is larger than ISO 622mm in order to have a tight, burp resistant seal.
    Your fairly in luck about cost since Stan's rims work well with tube-type tires which are the least expensive. But, adding sidewall protection will increase the cost.
    The basic tube-type GEAX tires work great on Stan's rims and have a fairly stiff sidewall.
    Wire-bead tires usually have a lower thread count which often results in a thicker casing. They are also less expensive, heavier and can be a little difficult to mount on Stan's rims.
  1. ZTR Crest 29 compatible tubeless ready tires
    By Srdan in forum Wheels and Tires
    Last Post: 01-23-2014, 10:37 AM
  2. Best tires for desert riding? El Paso area
    By Ro_bby in forum Wheels and Tires
    Last Post: 01-02-2014, 09:38 PM
  3. 650b tires for desert/rocky riding
    By Jasonstiller in forum 27.5 - 650b
    Last Post: 10-04-2013, 12:32 PM
  4. desert riding, best 26" tubeless tire?
    By On the Rocks in forum Arizona
    Last Post: 10-02-2013, 06:46 PM
  5. Tires for riding in bahrain/desert
    By dareverend in forum Titus
    Last Post: 05-24-2011, 07:33 PM
